Air leak causing loss of power, oil & water? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-22-2014, 04:54 AM   #1
FurnicK
My Ride: BMW E46
Unhappy Air leak causing loss of power, oil & water?
Hello fanatics.
Problem: The last few months, my car has been very unstable when it's coasting(ranging from 250-1000 RPM). But that's not all. I am also experiencing loss in my water level, up to 0.5 Litres per week (wich is a lot i know) and also up to 1 litre of oil per month!
That is not all, i am also experiencing problems with the heating and cooling when it's on automatic(wont heat to +32 celsius if i set it).
Because of the above, i was needed to get it to a pro workshop, that
resulted in some heavy bodywork, so the money was too short for the idle, heating and cooling problem. But the mechanic was kind enough to tell me what he thought there was wrong with the idle thing, which was the "Profile Gasket" sealing on the intake manifold (see 1.png, part no. 2). More about this later.
In the last weekend, i removed the whole inlet manifold, checked all sealings & o-rings (also all air temperature sensor) they were all in good condition, even the gasket sealing was healty anyway, we changed the gasket sealing gave both that and all other sealings silicon for better a better seal.
We cleaned the intake for leafs and other great things to get into the intake
As i have experienced above, i cleaned and checked other parts as i already had the whole inlet off:
  • Cleaned The ICV
  • DISA: Cleaned and sealings got silicon for better seal.
  • Cleaned intakes for dust
  • Cleaned every place where seals was placed
As we put everything back together, the problem was the same, as if we haven't done anything.. The only output worth mentioning is this:
It sounds like a f*cking wind tunnel going on under the hood!
Can the vent pipe going to the Pressure Regulating Valve cause such an effect on my idle and on my heavy usage of oil & water? (see 2.png part no. 2)
My friend is afraid that it is the head gasket which is having a leak, can anybody decline or confirm his theory?
I am so lost, can't keep buying and changing parts that doesn't do any good for my car.
Need help guys
Best regards
ID:	566336   Click image for larger version
Realoem is a life savior!
FurnicK is offline   Reply With Quote
Old 07-22-2014, 08:51 AM   #2
lszlszx
My Ride: Z3, V50, 1.8T
Has the engine overheated?
Is there smoke at the tailpipe?
GM No Reverse - posts 427, 439
"Would the codes indicate if it's the carburator?"
lszlszx is offline   Reply With Quote
Old 07-22-2014, 11:22 AM   #3
jdstrickland
My Ride: '94 325iC & '00 323i
My money is on the head gasket too. Sorry.
I could be wrong, but by the report you gave, that was my first thought. Well, my second thought. My first was that English is not your native language and I am having trouble understanding you.
Sponsored Links
Advertisement
Old 07-23-2014, 01:49 AM   #4
FurnicK
My Ride: BMW E46
The engine has never overheated, and the thermostat is fully functional.
The smoke coming out is as normal as it could be. No white or white-ish smoke, and no milky oil.
Please point out what you don't understand. My english is, as you say, not my native language. But i should be able to write, so please correct my mistakes if you would
Anyway, would the head gasket be able to make such a loud whooshing without showing any white smoke?
Old 07-23-2014, 06:26 AM   #5
NumbaOneNewb
My Ride: 2003 330CI Silver
yes the vent pipe and the entire crankcase ventilation valve can cause anomalies. example, disconnect the pipe hooked to the valve cover while your engine is running. it starts acting up. try this test. open up your oil fill cap while engine running. describe the best way you can how strong of a suction you notice, if no suction or very little, state that
Portland Metro: ECU updates, Euro tune, euro corner delete, air bag light, DSC light, cluster and any led color change, soldering work, transponders for keys, and all custom work related to computer or electronics.DIY AK90 A walk through on coding your mcu and transponders EWS3 How to make your own key (ak90 review)
Old 07-23-2014, 08:40 AM   #6
lszlszx
Well, if the coolant isn't burned, there must be a leak.
Look for coolant leak, or pressure test the cooling system.
An airleak can cause fluxuating idle.
Compression test, or leak down test can tell you about a possible head gasket problem.
If it didn't over heat that is less likely, but it's a good idea to rule out the more serious issue.
Old 08-09-2014, 07:52 AM   #7
FurnicK
My Ride: BMW E46
Sorry for the late post, i got interrupted by vacation and holidays.
Back to question:
If i disconnect the pipe hooked to the valve cover, there is no suction when i place my hans on the oil cap hole there is more a pushing than a suction. I can also see white-ish smoke coming up from there when i remove my hand. If i put on the vent pipe, there is sucktion, but not much, and i can hear a loud whoosing when i place my hand on the hole, but can't identify where.
Do you have any clues to this?
There has never been an overheating. Can you post a link to a guide for making a compression test, and the leak down test just to check?
Thank you guys in advance.
One love
Old 08-09-2014, 08:30 AM   #8
jfoj
My Ride: 330CiC, M5, X5, E93
I hope you did not do all of this work for nothing.
RARELY do the intake manifold gaskets leak air on these engines.
You need to read the links in my signature.
The 1st link has to do with vacuum/crankcase air leaks that cause all sorts of idle related problems.
These engines do have a loud vacuum sound that has to do with the idle bypass system, this is normal, but without hearing your engine in person, I cannot tell you if your engine sound is normal.
As for engine coolant leaks, you need to replace the O-ring on the temperature sensor in the lower radiator hose. These leak all the time and often you never see coolant on the ground. The part number is in my signature and you do not need any tools to remove the switch. Leave the expansion tank cap in place, remove the switch when the engine is cold, you will loose very little coolant due to the vacuum in the cooling system.
Also search YouTube for Scotty Smoke Test. Smoke testing the intake and crankcase is an easy way to find vacuum leaks you cannot locate by visual inspection.
Also the brake boosters are failing on these cars as they age and people miss these problems often.
Good luck.
Solve your misfires, lean codes, rough idle - https://forum.e46fanatics.com/showthread.php?t=897616
Fuel pump failures - https://forum.e46fanatics.com/showthread.php?t=929501
Temp Info - https://forum.e46fanatics.com/showthread.php?t=964491
Hidden OBC Menu - Check Voltage, Temp, Fuel Level - https://forum.e46fanatics.com/showthread.php?t=239619
Old 08-09-2014, 12:24 PM   #9
FurnicK
My Ride: BMW E46
Good luck.
Well thank you for the advices, i think i will go through the links in your signature, as well as doing other researches on the Scotty smoke, and the o-ring in the lower radiator hose.
The brakes might also need a check, thanks for the heads-up on that, alsmost forgot it
This is just going to take a looot of time and money i guess...
Old 08-29-2014, 04:00 AM   #10
FurnicK
My Ride: BMW E46
After undergoing a minor repair of the rear end, the mechanic changed a lambda sensor, all 6 spark plugs, checked for leaks and the o-rings in the lover radiator hose. The idle is still rough and the car is still using water & oil.
All in all, the last thing i can think of, is the headgasket. Can anyone confirm that this could be the problem?
Thanks in advance
Old 10-14-2014, 11:47 AM   #11
FurnicK
My Ride: BMW E46
Thanks in advance
Just an update:
As time has been passing by, the problem was getting uglier. That said, my fear of the head-gasket was blown, has become an reality, almost.
The problem was my cylinder head was cracked, but my gasket were fine..
Aaand just a question:
Does anyone have a clue about why? I don't wanna undergo this kind of rep. again, it was expensive as hell!..
Old 10-14-2014, 12:11 PM   #12
jfoj
Most likely reason for a cylinder head to crack is overheating, freezing or a casting flaw that excessive/extreme temperatures may have caused a failure at the casting flaw. If there was a casting flaw, you would not need for the coolant to freeze or the engine to overheat for this type of failure, just extreme temperatures like very cold or upper end of hot before overheating.
Do not know if you know the full history on the car, but also note the temperature gauges are buffered on these engines, so it will always stay at the vertical position over about a 50F window.
Old 10-16-2014, 02:26 AM   #13
FurnicK
My Ride: BMW E46
The car has been driving in Germany from birth (1999) to around 2008, then got imported to Denmark, after that i have no clue until i got it in February 2013, the winter in 2013 was very bad, the temperatures was as low as -30C, you think this could do anything?
Besides that, the mechanic have changed the clinder head but the problem with rough idle is still ongoing, can the engine control adapt the setting if I've been driving with the problem too long? If so, is it possible to reset?
It's been 4 weeks since my car went up there, I'm starting to get worried about never getting it to drive probably again.
Old 10-20-2014, 08:35 AM   #14
FurnicK
My Ride: BMW E46
Now I've got my baby back, but not in the shape i wanted.
There has been several changes and a new cylinder head, after I've got it back, there is a drop in performance, it actually feels like it has lost around 20-50 HP, can the engine control mess this up? Do i need a reset or a brand new?
bmw #1, e46, gasket
