OBD Fusion & Oil Temperature - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-14-2020, 04:18 PM   #1
325ciLover
My Ride: 2004 325ci
Is there a way to get a readout in OBD Fusion for oil temp?
When the app isnt connected to the car I can add the oil temp gauge but when I connect to the e46 I get no readings...
325ciLover is offline   Reply With Quote
Old 02-14-2020, 04:37 PM   #2
BIC_BAWS
My Ride: '02 330ci
You get no readings because the E46 Non-M (at least) doesn't have an oil temperature sensor.
Sent from my ONEPLUS A5000 using Tapatalk
BIC_BAWS is offline   Reply With Quote
Old 02-14-2020, 05:21 PM   #3
Overboost
//Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
Not true. Part #13
  • To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
The older I get... The faster I was...
No Fear
Overboost is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-14-2020, 05:26 PM   #4
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Oh yes it does! It screws into the OFH.
https://www.realoem.com/bmw/enUS/sho...01#13621433076
The oil temperature is not available via an OBD PID. See this INPA screen shot.
Old 02-14-2020, 08:01 PM   #5
BIC_BAWS
My Ride: '02 330ci
Does this mean you can potentially figure out a way to get the data into a digital readout? Would be great for track.
Old 02-14-2020, 09:03 PM   #6
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Just need software that can speak the right protocol.
Carly does, for one.
Old 02-15-2020, 12:22 PM   #7
TobyB
My Ride: 2004xit, 2001ci
PASoft reads oil temps, too...
Why there are 2 pressure sensors on the brakes and even one on the air conditioning,
and yet none on oil just baffles me...
t
changing the subject
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
Old 02-15-2020, 12:46 PM   #8
LeverThis
My Ride: 2004 325i automagic
Hey, check out this post & thread where the Carly app was used to log oil temp vs cooling temp during warm up period. The interesting result is it takes oil temp a bit longer to reach operating temp than it takes for coolant to reach operating temps.
https://e46fanatics.com/forum/showpo...&postcount=107
Btw, this is post #107 in a big cooling system thread.
Originally Posted by emineid View Post
I finally got everything I need to run Carly on my BMW.
I recorded the ECT temperature, CTS temperature, and the oil temperature while warming up my car in the garage.
The graph above shows that the ECT eventually reaches 97.5C, and that the thermostat only opens once the ECT reaches around 97C.
Below 97C ECT temperature, the thermostat is closed.
Outside temperature is -6F, and in the garage, it is 0F.
20mm OD x 12mm ID x 4mm W : Viton O-Ring
3/4" OD x 1/2"ID x 1/16" Thick : Thrust Bearing/Washer
LeverThis is offline   Reply With Quote
Old 02-15-2020, 01:38 PM   #9
BIC_BAWS
My Ride: '02 330ci
t
Ah yes, that's where I got confused. No oil pressure sensor sucks. Would love to have one for track.
Old 02-15-2020, 01:41 PM   #10
LeverThis
t
So what triggers the red oil light if there is no oil pressure sensor?
On the realoem diagram, I see that #12 is an oil pressure switch, #13 is oil temp.
(EDIT: Ok, you are right TobyB. There is no actual sensor giving pressure readings, only a switch to turn red oil light on or off.)
https://www.realoem.com/bmw/enUS/sho...diagId=11_2201
12 Oil pressure switch M12X1,5 1
12618611273
13 Temperature sensor coolant / oil 1
13621433076 $16.27
Old 02-15-2020, 01:53 PM   #11
BIC_BAWS
My Ride: '02 330ci
I see your edit, I believe red/yellow oil light is just level sensor.
Old 02-15-2020, 02:19 PM   #12
LeverThis
Well, there is an actual oil level sensor in the bottom of oil pan that activates the yellow oil lamp to indicate oil level. The red oil light however is based on pressure only (in all cars as far as I know), and that is activated by the oil pressure switch (#12) on the oil filter housing. So there are two different "sensors" involved here.
Pressure sensor vs switch is splitting hairs a little, but that is what confused me at first when Toby said there was no oil pressure sensor. Turns out he is correct: the car knows if oil pressure is below a specific threshold, but it doesn't know specifically what that pressure is.
Like you said, it would be great to see actual oil pressure on the track. I wonder if it fluctuates as you go through turns.
