O2 Sensor Gurus - P0430 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-20-2020, 11:23 AM   #1
bGTOb330ci
My Ride: 2003 330ci
Hello, I am trying to figure out if my cat is bad or there is some other cause of the P0430 code that I am getting.
The car is a 330Ci with 205000 miles on the clock. I just bought it in January, and since then I replaced the CCV and hoses, the MAF, pre-cat O2 sensors, and ET/water pump/thermostat. After the CCV, MAF, and pre-cat O2 sensors, I got it through smog and then a week or so later the P0430 started showing up.
Based on searches and research it sounds like if the rear O2s line up with the front O2 sensors, chances are the cats are bad, but it seems like from the data that sometimes the rear O2 data is very steady, and other times its moving around, so I'm having trouble interpreting the data. Can anyone help me out?
Log from my commute this morning: https://docs.google.com/spreadsheets...it?usp=sharing
2006 Pontiac GTO
2003 BMW 330ci
bGTOb330ci is offline   Reply With Quote
Old 02-21-2020, 01:48 AM   #2
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
P0430: Catalyst System Efficiency Below Threshold (Bank 2)
That's the typical code for a bad cat.
Exhaust back pressure test is the correct way to check. Google for details.
A quick test is to just remove both pre-cat O2 sensors, take it for a quick drive, and see if the power goes up noticeably.
Old 02-21-2020, 07:42 AM   #3
MrMCar
My Ride: E30M3 Track Car
If the catalytic converters are starting to clog....?
Two doses (two successive tankfuls of fuel) of BG 44K has a decent enough of a chance of starting to clear them.
Then if there is an improvement (predicated upon unconfirmed diagnosis above) you will need to get to the root cause. Chemically cleaning the rings & combustion chamber to restore normal function.
Let us know what you find and from there I can once again review the process of how to clean the rings/cats.
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Sponsored Links
Advertisement
Old 02-21-2020, 08:39 AM   #4
wasp9166
My Ride: 04 330i jet black
if your cats are clogged you're driving like grand ma
you gota beat on engines to keep them clean
aside from proper oil change intervals
"if polarity comes from protons, does morality come from morons?"
"Mommy and Daddy are getting a divorce now because wasp9166 had to piitb with Mom."
wasp9166 is offline   Reply With Quote
Old 02-21-2020, 01:41 PM   #5
bGTOb330ci
My Ride: 2003 330ci
Thank you, will look into doing this, though it doesn't necessarily feel like I am down on power. To confirm, running around with holes in your exhaust manifolds isn't going to hurt anything in the engine bay??
I've ran Seafoam through it front the brake booster line and the gas tank, as well as the CRC G2P stuff. I can try BG 44K though.
Yeah the car had 203,000 mi on it when I bought it last month so I'm not going to take responsibility for that one
It also had a large intake leak post MAF and reportedly bad CCV system (TBH I didn't see much wrong with it when I pulled it but oh well, its fresh now).
2006 Pontiac GTO
2003 BMW 330ci
Old 02-21-2020, 03:41 PM   #6
wasp9166
yeah, most of these cars are driven by women as a status thing , and they baby them
from my exp in my 54 yrs, the more you beat on a motor , the happier it seems in the long run
i've seen many motors babied and fkd up
i rem taking a kids motocross bike for spin , i screamed it out
he gets back on it and says, wow , it runs better now
they need to be blown out
my car sits all winter, but every month i take it out and make a point to let it scream thru all the gears up to about 80mph or so once , after it's warmed up
Old 02-21-2020, 04:30 PM   #7
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Itís pretty noisy and you donít want to leave it like that. But a short run for a few minutes wonít hurt anything.
Old 02-21-2020, 05:17 PM   #8
Sapote
My Ride: 2000 323i auto wagon
I'm not sure why grandma kept a constant rpm at 2500 rpm would cause a clogged cats, while beating on the engine (up 4000 rpm then close throttle like road race) is better for engine.
Sapote is offline   Reply With Quote
Old 02-22-2020, 11:17 AM   #9
markusmarkus
My Ride: 2018 M240i
Lower revs typically lug the engine. All modern BMW engines like to rev. They are designed to run triple digit speeds on the autobahn for hours.
