Alternative Fuel Injectors for E46 (FI-) Engines - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-18-2018, 08:31 AM   #1
sda2
My Ride: BMW E46 330i Touring
Hi mates,
I thought about opening a place where everyone can post deadtimes / lagtimes and general data about suitable fuel injectors for (forced induction) engine builts.
Even though the Siemens MSxx ECUs are like an open book now, there is no collection with different possibilities for going the FI road.
Please include the following values when posting injector data:
Manufacturer:
Model No.:
Donor Vehicle:
Flow And Pressure: in cc/m and bar/psi
Remarks: (direct fit or adapter needed?)
Minimum Injection Time: in ms
Deadtimes:
  • 0V -
  • 6V -
  • 8V -
  • 10V -
  • 12V -
  • 14V -
  • 16V -
  • 25V -
Let's make this the ultimate place for fuel injectors
sda2 is offline   Reply With Quote
Old 07-18-2018, 08:52 AM   #2
sda2
Manufacturer: Bosch
Model No.: 0280158123
Donor Vehicle: Porsche 997 GT2(-RS)
Flow And Pressure: 627cc/m @ 3.0bar
Remarks: direct fit
Minimum Injection Time: 0,499ms
Deadtimes:
0V - 2.94ms
6V - 2.94ms
8V - 2.94ms
10V - 1.58ms
12V - 1.15ms
14V - 0.73ms
16V - 0.55ms
25V - 0.55ms
Old 07-18-2018, 09:44 AM   #3
leonardo_
My Ride: 323CI Cabrio
Help on filling this:
Manufacturer: Siemens Deka
Model No.: 6900371
Donor Vehicle: Volvo s40 T4 (1.9 Turbo)
Flow And Pressure: 440cc/m @ 3.0bar
Remarks: direct fit
Minimum Injection Time: ...
Deadtimes:
0V - ...
6V - -
8V - ...
10V - ....
12V - ...
14V - ...
16V - ...
25V - ...
leonardo_ is offline   Reply With Quote
Sponsored Links
Advertisement
Old 07-19-2018, 03:56 PM   #4
jd improved
My Ride: charged 330i smg
Model No.: 6900371
Remarks: direct fit
Deadtimes:
0V - ...
6V - -
8V - ...
10V - ....
12V - ...
14V - ...
16V - ...
25V - ...
I have measured them in car with 1,5 x Flow of the stock b30 Injectors.
Dead times posted by rb01:
4.44
4.44
1.88
1.15
0.94
0.85
0.77
0.04
jd improved is offline   Reply With Quote
Old 07-19-2018, 10:13 PM   #5
rkneeshaw
My Ride: 330i ZHP
The 42lb/hr Bosch "green giant" is a popular choice. Fits the fuel rail and EV1 electrical connectors perfectly. I can't speak to whether they are too tall or not on the stock manifold, but they fit perfectly with the ESS twin screw supercharger kits.
Spec sheet is attached.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2+ - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - Hawk Performance
Build thread:
Wheelwell:
Fuelly:
rkneeshaw is offline   Reply With Quote
Old 09-20-2018, 01:35 AM   #6
Janis.P
My Ride: E36 M50TU2B23 turbo
4.44
4.44
1.88
1.15
0.94
0.85
0.77
0.04
Thanks. But what about the min ipv?
Janis.P is offline   Reply With Quote
Old 12-11-2018, 11:39 AM   #7
Johnny88
My Ride: E46 330Ci S/C
Any of you guys using the Siemens Deka 6900371 on the stock M54 intake manifold? I'm curious about the injector's spray angle, if there is any at all.
On the M54, BMW had injectors made with a 25 degree spray angle to point the fuel directly at the back of the intake valves.
When you put an aftermarket injector into the M54B30 intake manifold, it sprays fuel at the port floor, not at the back of the intake valves. This makes tuning part throttle tip-in, and even idle very difficult.
Johnny88 is offline   Reply With Quote
Old 12-12-2018, 03:38 AM   #8
leonardo_
Model No.: 6900371
Remarks: direct fit
Minimum Injection Time: 0.485ms
Deadtimes:
0V - 4.44ms
6V - 4.44ms
8V - 1.88ms
10V - 1.15ms
12V - 0.77ms
14V - 0.51ms
16V - 0.34ms
25V - 0.04ms
Old 12-12-2018, 06:30 AM   #9
Johnny88
Leonardo how did you came up with these dead times, since they are a little different than rb01's posted above.
Also how are these injectors working for you overall? Do they have a spray angle similar to the stock ones or they stray straight down?
Old 12-12-2018, 06:47 AM   #10
leonardo_
They were provide by a user member - sda2 -
Old 12-23-2018, 07:30 AM   #11
indee321
Would really appreciate somene posting info on Bosch, White Giants, p/n 0280155868. Five o seem to give a bit of info but no dead times etc?
indee321 is offline   Reply With Quote
Old 12-24-2018, 06:25 PM   #12
Bmsluite
My Ride: 2004 330i
Buy VDO ones. Nothing else works right. Ask me how I know
Sent from my VS988 using E46Fanatics mobile app
Bmsluite is offline   Reply With Quote
Old 12-25-2018, 12:51 AM   #13
indee321
Ahh too late ive bought them a while ago... what problems did you have?
Old 12-25-2018, 08:06 AM   #14
Bmsluite
My Ride: 2004 330i
Lean codes on some rebuilt ones from trying to be the cheap bastard that I like to be. Then I had some non VDO ones, can't remember the brand, sorry, but my ass told me I wasn't getting way top end power. Finally laid out my dough for the VDO ones and I've got the progressive power build all the way to the top now
Old 02-18-2019, 07:36 AM   #15
Johnny88
Which VDO injectors did you end up with?
I've tried Bosch and Siemens DEKA injectors both with extended noozles, they worked fine at high revs but they are not smooth down at 1-2K RPM.
Old 02-20-2019, 10:12 AM   #16
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
Green giants are good but not suitable for E85. 123 are expensive. I am using a version of the 123 common in Fords, the 298. Ill post the latencies I extrapolated but I did rescale the voltage from 10 to 17v I believe
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 02-20-2019, 02:10 PM   #17
indee321
Anybody got info on White Giants, p/n 0280155868 ?
Sent from my SM-G920F using E46Fanatics mobile app
Old 03-19-2019, 10:42 AM   #18
TrippinBimmer
My Ride: 2005 330i
Originally Posted by sda2 View Post
Manufacturer: Bosch
Remarks: direct fit
Deadtimes:
0V - 2.94ms
6V - 2.94ms
8V - 2.94ms
10V - 1.58ms
12V - 1.15ms
14V - 0.73ms
16V - 0.55ms
25V - 0.55ms
I have a Brand New set FS if anyone looking
2005 AW/IR M3
BMB Stage 4
940whp/765wtq SAE Corrected
2005 JB/BLK 330i ZHP
NA Bolt-ons
207whp/216wtq SAE Corrected
1996 BLU/BLK M3
NA Bolt-ons
235whp/225wtq SAE Corrected
1988 SETA 325I
NA Bolt-ons
165whp/160wtq SAE Corrected
Old 05-07-2019, 01:55 AM   #19
armenh7
My Ride: 2002 325i
I've got a question about injector scaling. I am going turbo and started the tuning process to learn. I have Bosch green giants that are listed on the wiki. I have the spreadsheet with all the values needed but they are rated for 39.15psi. I know the stock fuel pressure is 50.76psi so do I divide 50.76 by 39.15 to get 1.296 and then divide or multiply every value in the spreadsheet by 1.296? I realized that it may cause issue for others thinking you can just plug in the numbers from the wiki. Thanks in advance.
I also did maf scaling using the PMAS transfer function tool. I only edited ID_MAF_TAB. Is there anything else I need to edit? I modified both x and y value axis to match the excel spreadsheet exactly. I set the multiplier in the excel spreadsheet to 0.944 so that the voltage and airflow is corrected to a max limit of 2048 kg/hr.
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 08-15-2019, 01:11 PM   #20
Iliyasuper
My Ride: 316 with M54b30
Does anybody know about Bosh 0 280 155 759? Was used on 1.8 turbo Volvo and was installed to some of ESS kits(m54b30).
Just know - 330cc at 3.0 bar
Bosch EV6CL fuel injector
Long size injector
Jetronic port
4 hole nozzle
Conical spray pattern
Flow rates @ 43.5 psi / 3 bar
31.4 lb per hour
237 G per min. (N-Heptane)
330 cc per min
15.95 Ohm resistance
100% fit to m54b30
Maybe somebody have settings? I am interested because current injectors is very cheap!
Iliyasuper is offline   Reply With Quote
