Monoball experience - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > Suspension & Braking
Old 07-02-2019, 02:23 PM   #1
76m2002
My Ride: 2002 325iT
Year: 2002
Model: 325iT
Transmission: 5-speed
Monoball experience
Has anyone tried the Turner (or other brand) monoball FCABs and RTABs? Can you compare them to polyurethane for NVH? This is for a 2002 325iT that is a dual-duty track/daily driver. I'd like the improved steering for the track and don't mind a little increase NVH, but I don't want it to clank like a full, metal-metal racecar. This is my daily driver, but it already has Koni sport shocks, H&R race springs, and Hotchkis sway bars, so its no longer stock.
'76
'02 325iT
'91 318is
76m2002 is offline   Reply With Quote
Old 07-05-2019, 07:42 PM   #2
Schmidty_
My Ride: 05 ZHP 12 X5M 14 235
Year: 2005
Model: 330i ZHP MBM Sedan
Transmission: A/T
I did the "Camry" upgrade RTABs in my ZHP, they tightened the rear up a little. They are a sealed spherical bearing from MOOG, PN# K200786.
2005 ZHP Mystic Blue Metallic Sedan - (1/19 in NA) Koni Sport M3 struts, Eibach M3 Springs, M3 rear brace, Powerflex Black FCAB, "Camry" MOOG RTABs, K&N Intake, G.A.S. DISA, G.A.S. Rad Cap, SAP Delete
2012 X5M Black Sapphire Metallic - JB4, DownPipes, Exhaust
2014 M235i Mineral Gray Metallic 6MT - JB4 w/ MHD BEF, CP, TIC, DP, I, E, Pure Inlet, N20 MAP, BMS Oil Cooler Valve, F80 Rear Brace, GC Camber Plate
Schmidty_ is offline   Reply With Quote
Old 07-06-2019, 07:00 AM   #3
Bmsluite
My Ride: 2004 330i
For FCAB I would go with Z4M bushings. They are solid rubber but offset. It greatly improves the steering feel. Basically transforms the whole car. No extra NVH
Sent from my VS988 using E46Fanatics mobile app
Bmsluite is offline   Reply With Quote
Old 07-07-2019, 10:03 AM   #4
Schmidty_
Year: 2005
Transmission: A/T
For the front, yes the Z4M CAB helps with the geometry. If you want monoball/spherical bearing for the FCAB, the M3 strut and top hat change the geometry a lot and was a significant improvement for the ZHP.
Old 07-07-2019, 10:10 AM   #5
76m2002
My Ride: 2002 325iT
Year: 2002
Model: 325iT
Thanks for the suggestions. I've been running the Z4M offset FCAB, and just ordered the Powerflex black offset equivalent. For the rear, I opted for the Bimmerworld RTAB bearing replacement kit, which replaces the bushing with a sealed bearing, as used in the rear outer control arm. This was not as cheap as the Camry option (which I really like) but was about half the price of the Turner or GC equivalent.
'76
'02 325iT
'91 318is
Old 07-15-2019, 05:34 PM   #6
E46Newbz
Sorry for the noob question but how does it being offset help? I'm in need of new front bushings myself. Thanks.
E46Newbz is offline   Reply With Quote
Old 07-15-2019, 05:45 PM   #7
76m2002
My Ride: 2002 325iT
Year: 2002
Model: 325iT
It changes the geometry of the control arm slightly, and gives you a bit of positive caster, which improves high speed stability.
'76
'02 325iT
'91 318is
Old 07-15-2019, 06:29 PM   #8
E46Newbz
Thanks, boss. I'll look into getting a set.
Old 07-24-2019, 11:24 AM   #9
the fly
My Ride: '95 m3, '03 m3
I pre-press OE Z4M solid rubber bushings for folks here:
https://forum.e46fanatics.com/showthread.php?t=1119519
It's a popular upgrade for non-M e46's...
Need FCABs? I sell them pre-pressed...
the fly is offline   Reply With Quote
Old 07-28-2019, 02:40 PM   #10
KlausH79
My Ride: 2001 325ti
Monoball experience
During my complete subframe restoration project I have designed my own RTAB “monoball bushings”
It’s basically a Meyle monoball bearing with two aluminum “adapter rings” around it so it fits the trailing arm. I haven’t assembled it all yet so I don’t know about performance but given the simple design my expectation is that it’s just like any of the other sealed bearing solutions out there.....at a fraction of the cost. I have two extra sets laying around due to the MOQ at the shop which made them. PM me if you want to have a set and we’ll figure something out.
KlausH79 is offline   Reply With Quote
Old 07-28-2019, 04:12 PM   #11
76m2002
My Ride: 2002 325iT
Year: 2002
Model: 325iT
Very nice! It looks very much like the Bimmerworld bearing. Thanks very much for the offer, but I just installed the Bimmerworld bearing.
'76
'02 325iT
'91 318is
Old 10-15-2019, 06:37 AM   #12
rkneeshaw
My Ride: 330i ZHP
Dude, that's awesome, nice job!
Very simple design. And you can replace those sealed bearings with readily available aftermarkets it looks like.
How do they fit?
You really should consider reselling them.
2003 BMW 330i ZHP
ESS Twin Screw Stage 2+ - Wavetrac - Headers - Borla - BMW Performance
Turner Motorsports - Powerflex - Hawk Performance
Build thread:
Wheelwell:
Fuelly:
rkneeshaw is offline   Reply With Quote
Old 10-20-2019, 06:49 AM   #13
KlausH79
My Ride: 2001 325ti
Monoball experience
How do they fit?
Hey thanks!
I just installere the trailing arms with the new mono ball RTABs yesterday and the fit is spot on.
They are press fit but I added some screws although I don’t think they are actually needed.
I have a few extra that I had made, but I was thinking of making the 3D CAD available for people to download and have them made themselves.
So if anyone’s interested.....
Old 12-23-2019, 04:49 AM   #14
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
We're always interested.....
TheRiddle is offline   Reply With Quote
Old 02-17-2020, 12:50 PM   #15
doukas007
My Ride: e46 320 coupe
Year: 2001
Model: 320ci
Transmission: manual
definitely interested cause they charge an arm and a leg for these adapters
doukas007 is offline   Reply With Quote
