398.5 whp and 498.8 lb ft. M54B30 ESS Twin Screw. - Page 12 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Australia
Old 07-27-2018, 05:41 PM   #221
cosmos328Ci
My Ride: 400+whp. 500.4ftlb
Transmission: 5 Speed Manual
Comparing the two dynos, the positives are:
1. Hp peaks earlier,
2. Tq stays higher longer, and
3. Less boost.
Gotta have some positives.
M54B30, ESS TS2 Manifold, 4" Throttle Body, 108mm pulley - 4.25".
cosmos328Ci is offline   Reply With Quote
Old 07-27-2018, 09:31 PM   #222
cosmos328Ci
I didn't get a good run in but I have picked up 2psi Min.
The ESS TS throttle body snout is just under 2.6 inches, ID - now 3.5 inches.
Old 07-27-2018, 10:27 PM   #223
cosmos328Ci
Might put the 60mm pulley back on, LOL.
Sponsored Links
Advertisement
Old 07-30-2018, 06:20 AM   #224
cosmos328Ci
Going from 2.6 inch ESS TS Snout to 3.5 Inch netted 2.5 - 3.0 psi gain.
Old 08-01-2018, 05:15 AM   #225
cosmos328Ci
I have a dyno booked on Tue to see the changes of the 3.5inch ESS TS snout.
Not the same Mainline dyno but I have had a dyno on this Dyno Dynamics before, but with the "Old, Good Engine".
It reads lower than the Mainline by about 20whp - I will have to have a look at my dyno sheets.
Anyway, referencing to my old dynos should give an idea of any changes.
Old 08-06-2018, 02:03 AM   #226
cosmos328Ci
This engine seems to use about 1 liter of oil every couple of hundred km's.
I am going to measure it this time. LOL.
Old 09-07-2018, 11:23 AM   #227
jdjg
My Ride: e39, m52tub30
Year: 1999
Model: e39
Transmission: Manual 5 speed
any gain with the 3.5 inch ESS TE snout?
jdjg is offline   Reply With Quote
Old 10-04-2018, 08:12 AM   #228
cosmos328Ci
Got to Dyno place and the fuel reg was leaking, so I abandoned the dyno run - so, no... no time.
Going from just under 2.6" to 3.5" TS Snout, gained 2-3 psi - resulting in a small re-tune.
But, the ID1000's are running about 108% DC, so not going to do dyno run until that is resolved.
How is your beast coming along?
Old 06-14-2019, 03:34 AM   #229
cosmos328Ci
Whipple W140AX arrived today.
2.3L here to give the 1.6L Lysholm a well deserved rest.
The titanium valves have been fitted to the new head - hopefully to see current peak whp at 6600 rpm, that basically flatlines to 7600 rpm, start to go up with rpm instead of side ways.
The 1.6 is currently overspun to about 18000rpm with a 74.15mm pulley (thanks to Dave), maybe I put the 60mm pulley back on and see if it will be destructive either to the engine, headgasket or the 1.6...
Or... some one may want to save this 1.6 and buy it,
? Instead of sealing its possible fate with the 60mm destroyer?
...For some reason, I could not open an attachment to post pics...?
Old 07-14-2019, 12:18 AM   #230
Davconelectric
My Ride: 2 dog powered sled
How'd you go with this? Get the larger charger to fit in engine bay?
Davconelectric is offline   Reply With Quote
Old 09-20-2019, 08:23 PM   #231
cosmos328Ci
I have not installed it yet.
Been away on holidays for about 2 months.
There are a few things in in the process of doing that need tuning and dynoing, before the 2.3 goes on.
Cheers.
