Xenon headlights blinking (not flashing) simultaneously for 5-10 minutes - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 07-09-2019, 11:59 PM   #1
SD Pete
My Ride: 2005 ILB E46 M3
Every time I turn on the headlights (low beams), they both flash simultaneously for about 5-10 minutes,. Then they both stop flashing at the same time.
Video
I just replaced the DS2s, but the problem's still there. Any thoughts?
TIA,
Pete
SD Pete is offline   Reply With Quote
Old 07-10-2019, 12:05 AM   #2
325ciLover
My Ride: 2004 325ci
I have no clue what it could be but I'm definitely following this one! Sounds interesting and that there is an easy fix using pa soft, but I don't know the setting.
Sent from my ONEPLUS A6000 using Tapatalk
325ciLover is offline   Reply With Quote
Old 07-11-2019, 05:35 PM   #3
TerraPhantm
My Ride: M3
Did it ever work properly? Any changes you can think of (even if not lighting related) around the time it started doing this?
TerraPhantm is online now   Reply With Quote
Sponsored Links
Advertisement
Old 08-01-2019, 10:21 PM   #4
SD Pete
Still trying to figure things out. Thankfully, they still come on after 5 minutes or so...
No other mods or work done for quite a while before it started occurring.
Old 08-04-2019, 02:55 PM   #5
G-Hots
My Ride: ///M3 & 328ci
Send a message via AIM to G-Hots Send a message via MSN to G-Hots
Video won't load up for me... but sounds like the issue I had years ago. Check your tail light ground wires until you find the corrosion/ wiring break/ burnt out connector. Trace the brown ground wire (tail light harness). usually the connector itself will either burn out / corrode & that's what causes what you described. LCM goes haywire over a lousy cable
G-Hots is offline   Reply With Quote
