FS: S54 BMW Inline 6 Cylinder Engine - Fully Built Long Block, Holds +1000WHP - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Australia
Old 07-13-2019, 01:18 AM   #1
brendan_select
My Ride: E46 330
As seems to be a habit with me - bought this a while back from the US and considering to sell if I can recoup my investment...
Is sitting in transport crate/sealed.
Posted on eBay.
Asking $15k AUD
SMS me on +61 433 880 915
S54 BMW Inline 6 Cylinder Engine BMW E46 M3, E89 Z4 - Fully Built Long Block
FRESHLY BUILT LONG ENGINE
RUN APPROX 800 MILES ONLY (MOSTLY ON DYNO)
BUILT BY REDLINE SPEED WORKS IN NEW YORK USA
(WAS A SHOP / DEMO CAR WHICH WAS PARTED OUT WHEN RSW NEEDED FUNDS FOR THERE EXPANSION TO NEW FACILITY)
(CAR IS DOCUMENTED ONLINE - SEARCH REDLINE SPEED WORKS S54 OR REDLINE SPEED WORKS E46 M3)
CAR MADE OVER 1000 WHP (WAS RUNNING A SAAD TURBO KIT)
(Turbo / Headers shown are NOT included)
Engine Balanced and Blueprinted 9.5:1 CR ideal for Turbo or High Boost Supercharged Setup. (11.5:1 stock S54 CR)
TOP END (pulling 20" vacume on the valves):
Supertech Black Nitride Intake Valves with Single Keepers
Supertech Inconel Exhaust Valves with Single Groove Keepers
Supertech Titanium Retainers
Supertech Dual Valve Springs
Dr Vanos Rebuilt Vanos with Cryo Exhaust Hub
Dr Vanos Drilled Oil Pump Disk
Dr Vanos REM Polished Cam Sprockets and Modified Splined Gears
OE New Vanos Solenoid Pack
Besian Vanos Solenoid Gasket Seals
OE New Head-Gasket
OE New Valve Guide Seals
OE New Timing Chain Guides/Runners
OE New Timing Chain and Tensioner
OE New Vanos Chain
OE New Oil Pump Chain
OE New Cam Gear Bolts and Hub Bolts
VAC Bronze Valve Guides
ARP L19 Head Studs
BOTTOM END (195-200psi compression, leak down 2-3% across all 6 cylinders):
Polished Crank
Wiesco Pistons (Ceramic Coated Head) & Armor Glide Coated Skirts
Weisco Piston Wrist Pin - Hardened with .220 Wall Thickness
Pauter Connecting Rods (X Beam Single Rib)
VAC / ATI Harmonic Balancer
OE New Oil Pan Gasket
OE New Valve Cover Gasket
OE New Rear Main Seal
OE New Crank Bearings
OE New Rod Bearings
ARP Main Studs (align honed)
Name:	1_Main Engine.jpg
ID:	779375   Click image for larger version
ID:	779377   Click image for larger version
Name:	2_ATI Balancer.jpg
ID:	779379   Click image for larger version
Name:	3_Assembled Pistons.jpg
Name:	5_Engine ARP Bolts.jpg
ID:	779383   Click image for larger version
brendan_select is offline   Reply With Quote
Old 07-14-2019, 12:13 AM   #2
Davconelectric
My Ride: 2 dog powered sled
Hi Brendan,
Would you consider taking my second child and a case of import quality beer as payment?
Child is disease and defect free
You have my number
Davconelectric is offline   Reply With Quote
Old 07-25-2019, 02:17 AM   #3
STAATS
My Ride: 2003 BMW E46 M3
Wow thats really good value... I paid a fair bit more for a fully NA built S54 from Lang Racing Development... if I was in for a blown build and this was around i would have pounced on this in a heartbeat. GLWS
STAATS is offline   Reply With Quote
Sponsored Links
Advertisement
Old 09-10-2019, 06:10 AM   #4
brendan_select
My Ride: E46 330
Thanks! SOLD to a really deserving new owner who has BIG BIG things planned!
Happy it's staying in the Melbourne area... Watch this space...
Old 09-14-2019, 02:15 AM   #5
STAATS
Excited to see where it ends up
Old 09-14-2019, 07:25 AM   #6
brendan_select
My Ride: E46 330
Yep - I'll leave it for him to divulge his plans but needless to stay it's going to be focussed on running in a straight line!
So I'm now thinking an N/A Stroker S54 with a CSL Airbox would be fun! Would SOUND pretty sweet.
I've also discovered a company called DKT in Europe who make plug and play solutions for DUAL CLUTCH on the S54!
A few E46 M3 Dual Clutches out there already apparently...
