398.5 whp and 498.8 lb ft. M54B30 ESS Twin Screw. - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Australia
Old 08-12-2015, 01:15 AM   #41
Davconelectric
My Ride: 2 dog powered sled
Twin 2.1/4" Headers were made by a local exhaust shop a few years ago, they do the job. I'm not looking at huge numbers over reliability, This engine needs to hold its **** together whilst being thrashed like its stollen.
Cars been off the road for so long now I'm in no great hurry.
Davconelectric is offline   Reply With Quote
Old 08-12-2015, 11:05 AM   #42
cosmos328Ci
My Ride: 403whp. 500.4ftlb
Transmission: 5 Speed Manual
2 1/4", now that's the gear, what did they set you back?
Well, it will definitely be a blast to drive.
M54B30, ESS TS2, Schrick Cams, S54 Cam Chain Tensioner, ATI Super Damper 6.8", 3.5" Throttle Body, XForce Headers, Custom Twin Exhaust, Quaife LSD 2.93:1, UUC Twin Plate and Lightened Flywheel, GSR Four-bolt Oil Pump, M56 Engine cover with Built-in CCV.
https://forum.e46fanatics.com/showthr...619&highlight=
cosmos328Ci is offline   Reply With Quote
Old 08-27-2015, 07:12 PM   #43
cosmos328Ci
new exhaust dyno today. 398.5 whp
398.5 whp on a Mainline Dyno - (Previous best on same dyno was 370 whp on same day as Dyno Dynamics 375whp)
Name:	New Exhaust Dyno Today (2).jpg
Sponsored Links
Advertisement
Old 08-28-2015, 01:07 AM   #44
spacemaster
My Ride: E46 328i
I want it !
spacemaster is offline   Reply With Quote
Old 08-28-2015, 01:16 AM   #45
cosmos328Ci
Originally Posted by spacemaster View Post
I want it !
LOL.
Still got more to go yet.
Cheers
Old 09-03-2015, 01:22 PM   #46
cosmos328Ci
New exhaust sound on Dyno.
Old 09-03-2015, 10:37 PM   #47
Tiag46
My Ride: e46
Solid
*Wrecking* - Heaps of parts available.
https://forum.e46fanatics.com/showthread.php?t=1103190
Tiag46 is offline   Reply With Quote
Old 09-03-2015, 10:53 PM   #48
KendrickC
My Ride: '03 325i
Year: 2003
Model: 325i
Transmission: 6MT
I like that sound more than the previous one!
'03 325 6MT Estoril Blue
KendrickC is offline   Reply With Quote
Old 09-03-2015, 11:24 PM   #49
cosmos328Ci
Originally Posted by Tiag46 View Post
Solid
Thanks Tiag46.
Lol, sounds good when reving but has drone at part throttle.
May add another 2 3" bullet muffles or move the current 3" bullet mufflers from before the diff to just before the tips and see if it reduces the drone.
Thanks Bafffyyy.
Old 10-23-2015, 04:35 AM   #50
cosmos328Ci
Originally Posted by cosmos328Ci View Post
Thanks Tiag46.
Thanks Bafffyyy.
Fitted "J" pipes to reduce the drone.
Old 11-02-2015, 04:41 PM   #51
cosmos328Ci
Re-tune for new exhaust system.
Re-tuned for new exhaust system last Fri, 30 Oct 15.
with the new exhaust with-out re-tune gained 28.5 whp, with tune.... no change to max whp.
Re-tune benefits... better throttle response down low and mid rpm and part throttle drive ability around town.
Did gain more whp across whole rpm range with increasing timing by 2deg (about 5-7whp) but took it back out for safety margin. With old exhaust it would not make anymore whp even with 2deg.
Pics of "J" pipes, 3inch. (to reduce exhaust drone)
ID:	616934   Click image for larger version
ID:	616935   Click image for larger version
Old 11-04-2015, 08:20 AM   #52
jdjg
My Ride: e39, m52tub30
Year: 1999
Model: e39
Transmission: Manual 5 speed
Was: at 375 whp and 450 ft/lb at the flywheel on a Dyno Dynamics.
(Now Fri 28 Aug 15 - Now 398.5 whp on a Mainline Dyno, previous best on the same dyno was 370 whp)
Was: Single 2.5 inch exhaust, 2.5 inch 100 CPSI cat and one muffler with twin 2 inch in and out using M52TU headers.
3.5 inch throttle body and 4 inch tube to wheel well.
(Now Fri 28 Aug 15 - with twin 2.5 inch pipes with twin 2.5 inch 100 CPSI cats, goes to twin 3 inch pipes into twin 3 inch bullet mufflers before the rear axle to the rear bumper into quad 3 inch tips.
Up for sale (FS): Single 2.5 inch exhaust, 2.5 inch 100 CPSI cat and M52TU headers with 2.5 inch collector, plus M3 lookalike quad tip rear muffler.
The new system is twin 2.5" from header collectors with two 2.5"100 CPSI kitties to 3 " in and out bullet style mufflers before the axles with twin 3" inch pipes to the bumper finished off 3" tips (3" in and twin 3" out) e46 M3 look
Quad tips.
nice numbers!!!!
you get +20whp only with your upgrade exhaust system? (from 2.5" to 3")
jdjg is offline   Reply With Quote
Old 11-04-2015, 08:37 AM   #53
Custom3
My Ride: HellRot 330CI
I know its your car and all but man I would have thrown a mtech 2 front and rear instead. No need to try and make it look like a M3 when it can keep up or probably beat one. The tires chirping on that video you have when you redline it made me giggle with joy. What a beast.
Old 11-04-2015, 08:48 AM   #54
jdjg
Year: 1999
Model: e39
I didnt read this part..... nice bro.....
Old 11-04-2015, 04:27 PM   #55
cosmos328Ci
I would have still had my OEM coupe front bumper still but the car thief trashed it. I looked for a while for a new front bumper and nearly got a Mtech II but I already have a Bmer with one.
I like the look of the M3 Front bumper and Quad Tip look.
Basicly I like the look of the M3 but don't like the look of the wider front and rear guards.
(maybe I should have bought an M3 and cut the guards out?)
Cheers Custom3.
A standard M3 gets left behind pretty quick.
Thanks jdjg.
Old 11-07-2015, 09:32 PM   #56
cosmos328Ci
Meth/Water Installation when I get home.
Well, not much more I can do with the car power wise ATM.
Next on the to do list will finally be the Water/Meth install, Then Dyno. (now that summer is approaching soon. )
Still got cams to go in as well.
I have a 3.5 inch Throttle Body (TB) on ATM, but I have not opened up the twin screw snout where the TB mounts. I think the hole at the snout is about 2.6 inches?? I will have to look at my measurements I took when installing the TB. So, basically I can open up the snout more which should give more HP/Tq if it is a restriction so I will plug my Vacuum/Boost gauge in to see how much Vacuum it is pulling before deciding on removing the TB and opening up the Snout.
**when I installed the TB I lost 15whp before the re-tune, after the re-tune I gained back the 15 and another 17.8whp on top.**
Home in a couple of weeks to put in the Water/Meth.
The difference between 3.5inch TB Mounting Adapter and TS Snout mounting Hole.
And, the aftermarket OEM size TB next to the 3.5 Inch TB.
Positioning of Meth/Water Nozzle.
ID:	617412   Click image for larger version
ID:	617413   Click image for larger version
Old 11-09-2015, 05:25 AM   #57
cosmos328Ci
Added a couple of pics.
Old 11-17-2015, 02:00 PM   #58
Custom3
That spare tire compartment comes off like that or you cut it
Old 11-17-2015, 02:01 PM   #59
Custom3
Sh*t thats a huge difference between OEM.
Old 11-17-2015, 09:10 PM   #60
cosmos328Ci
Its been cut out.
LOL, yeah... Not as big as the 4 inch I wanted to use though.
