Looks like the motor is done - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-28-2019, 07:16 PM   #1
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
Making 10.8 psi at the manifold, no misfire, but under boost its blowing oil out of the valve cover gasket. Getting a ton of crank case pressure. I measured compression low on one cylinder and when I dropped oil in the compression came up, pointing to piston rings. It also dynoed at over 100hp less than before. Going incredibly rich on boost. Looking at the mass airflow readings, seems like all the boost is going straight past the piston, causing very rich afr. Looks like Ill be building a new motor.
Planning on doing upgraded piston rings and the M50 manifold. I haven't decided yet on studs and head gasket change.
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 09-30-2019, 05:44 PM   #2
Dogthebountyhunter
My Ride: 03 M3 Vert 2005 745i
Jeez I bet that was fun while it lasted. What's the point of m50 intake? No disa?
Dogthebountyhunter is offline   Reply With Quote
Old 09-30-2019, 09:50 PM   #3
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Much higher flow while being simpler
Sponsored Links
Advertisement
Old 10-01-2019, 01:48 PM   #4
VitalyZHP
Ukrainian
My Ride: 04 330CI
Any idea what caused this? Mine's holding up strong at around 10 psi with decompression plate and 10mm ARP studs
VitalyZHP is offline   Reply With Quote
Old 10-01-2019, 01:56 PM   #5
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Iíll be doing 10mm arp and a vac gasket at 0.09. I think itís the piston rings. Maybe issues with the oil and ethanol
