Clutch sensor doesn't work after gearbox swap - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 01-07-2019, 03:45 PM   #1
Kunio
Hello.
I can not deal with connecting the clutch sensor in my car. Well, according to the description at https://www.newtis.info/tisv2/a/en/e...el-electronics / Z2Pr1xk
I connected pin 2 of the sensor to pin 50 in ecu (Signal Clutch switch)
Pin 1 connected to pin 2 brake wiring (ground)
Pin 3 in sensor to pin 1 brake wiring (12V)
Unfortunately, the clutch sensor does not work and therefore the cruise control does not work.
Could someone in the topic help me?_a_
Kunio is offline   Reply With Quote
Old 08-25-2019, 09:50 PM   #2
RandallNC
My Ride: 2003 BMW 330i ZHP
I believe pin 2 should go to pin 23 in the ecu...
And pin 4 goes to the EWS pinout #8.
Confirm pins 1 & 3 for ground and 12v with a meter...
Hope this helps...
RandallNC is offline   Reply With Quote
