FS: new Powerflex “XI”-only FCABs / LCABs – prepressed front control arm bushings - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Classifieds > For Sale, For Trade or Wanting to Buy > Suspension and Braking
Springs, shocks, struts, coilovers, camber plates, sway bars, strut bars, suspension bushings, control arms, brake pads, big brake kits, etc.
Old 08-10-2013, 03:09 PM   #1
the fly
My Ride: '95 m3, '03 m3
Pair of new Powerflex polyurethane e46 325xi/330xi FCABs (front control arm bushings) already pressed in to OE lollipops. These are the 60mm dia bushings and lollipops for the all-wheel drive XI only. Ready to slip on to your control arms and bolt on to tighten up your front end handling. No messing around with DIY swearing at improvised bushing pressing or going to a machine shop pressing out/in the bushings while your car is jacked up. Powerflex bushings already pressed into housings are not sold anywhere online for the XI. These are the “updated” Powerflex PFF5-4601xi units designed specifically for the xi. These updated PF units prevent the issue of the inner bush “riding up” the control arm.
Selling for $169 shipped + $60 core charge. Once complete, you send back your old lollipops to me (in good shape) and I refund the core charge. Just for reference, that’s a good bit cheaper than the $231 (without shipping) that stock rubber bushings go for pre-pressed from the one online retailer that offers pre-pressed units.
If you check my sig, you’ll see that I’ve been doing a similar swap service for others with positive results…
Need FCABs? I sell them pre-pressed...
the fly is offline   Reply With Quote
Old 08-11-2013, 07:06 PM   #2
the fly
pix...
ID:	521333   Click image for larger version
ID:	521334   Click image for larger version
Old 08-13-2013, 05:06 AM   #3
lethe46
My Ride: '02 330i
Re: FS: new Powerflex "XI"-only FCABs / LCABs - prepressed front control arm bushings
Interested PM me with payment info thanks
Sent from my cm_tenderloin using BimmerApp mobile app
lethe46 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-16-2013, 12:16 PM   #4
the fly
Sold to Lethe46. Will post again when I have a set ready again...
Old 09-01-2013, 01:33 AM   #5
ZemogFC3S
My Ride: '02 330xi
I'm ready to do mine. Has lethe sent you his yet?
~ '02 330xi
~ '89 RX7 TII
ZemogFC3S is offline   Reply With Quote
Old 09-01-2013, 11:38 AM   #6
lethe46
My Ride: '02 330i
Sending it this week highly recommended saved me alot of work
Sent from my SAMSUNG-SGH-I997 using BimmerApp mobile app
Old 09-01-2013, 03:10 PM   #7
ZemogFC3S
My Ride: '02 330xi
Nice, thanks for the update. the fly will you PM me the details?
~ '02 330xi
~ '89 RX7 TII
Old 09-15-2013, 03:18 PM   #8
the fly
Zemog, I sent you PM last week 'cos you're next in line. Haven't heard back and will sell to the next interested person soon...
Old 09-16-2013, 03:50 PM   #9
the fly
Ok, I have a set up for grabs and ready to ship. PM me if interested.
Old 02-04-2014, 09:33 AM   #10
the fly
Should have another set ready to go by Friday...
Old 04-03-2014, 04:51 PM   #11
MoveIt
My Ride: BMW 330xi
I'm ready for a pair of the new Powerflex. Whacha need from me??
MoveIt is offline   Reply With Quote
Old 04-06-2014, 08:44 AM   #12
the fly
PMed ya. I do have a set ready to go.
Old 04-28-2014, 09:19 PM   #13
chsu74
My Ride: 550XI,993TT,GL320
Hi There
Looking for a set.
chsu74 is offline   Reply With Quote
Old 05-06-2014, 06:15 PM   #14
limpiabota809
My Ride: 330 XI
What if I send you the bushing and you press it in a lollipop for me then when I have it installed I'll send you my old lollipop with old bushing
How much is that? Since I'm providing the bushing and returning a lollipop
Instagram - @Limpiabota_e46
limpiabota809 is offline   Reply With Quote
Old 05-06-2014, 06:53 PM   #15
the fly
I will have to pass on even trying that. Reason being that XI fcabs are especially a PITA to press and that the fluid filled stock rubber is known to suck and not last long on the XI.
If you end up with extra XI lollipops, I may be interested in buying them.
Old 05-06-2014, 06:59 PM   #16
limpiabota809
My Ride: 330 XI
I was referring to having you press the powerflex bushings for me not the stock ones
Old 05-14-2014, 07:59 PM   #17
the fly
All, I have a fresh set of pre-pressed Powerflex XI FCABs ready to go.
Old 06-28-2014, 11:13 AM   #18
scott_321
My Ride: Ram Truck
hey the fly I'm curious about the eccentric orientation of the bushing inside the housing. I see you have lined up the small skinny portion of the bushing with the mounting arm, as shown in your set of directions. The powerflex website pdf directions show the opposite. http://powerflexusa.com/images/insta...5-4601xifi.pdf Any knowledge of them changing this recently?_nr_
scott_321 is offline   Reply With Quote
Old 06-29-2014, 08:50 AM   #19
the fly
Good question. I have seen those PF instructions and think they have mistakenly applied the orientation of other 3-series offset FCABs to the XI. The XI has the lollipop mounting holes/arm on the flipside to most bimmers. Hence, their mistake.
See the orientation in this xi DIY. It also has the skinny side towards the mounting arm like mine.
https://forum.e46fanatics.com/showthread.php?t=778979
Old 06-29-2014, 12:10 PM   #20
scott_321
My Ride: Ram Truck
Thanks fly for the response. The powerflex instructions even say, "The outer bush needs to be fitted so that the eccentric bush pushes the arm toward the outside of the car." And it does if installed that way.
If that is incorrect they really need to fix the instructions. I also found some pix of the oem setup which have the skinny side facing the mounting holes. A while back I installed aftermarket rubber bushings (junk - wore out in 6 mos) and found a detailed drawing of the orientation but can't seem to find it now.
I recently upgraded to powerflex and installed them per included instructions with skinny side facing mounting holes. Then a few days later I happen to see the powerflex website instructions which show the opposite, and thought oh crap did I mess up?
