E46 emmision variants and how to - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 8 votes, 4.50 average. Display Modes
Old 10-11-2013, 11:59 AM   #1
new//M3fan
My Ride: 77' 924 87' E30
*ROUGH DRAFT*
10.11.13 -- 0.9
10.11.13 -- 0.9.1 - added State Inspection OBDII Reports section
*This write up (software versions, variant codes, etc) applies to MS43 M54B30 equipped E46's for now.
Most of you know it is now possible to flash different exhaust emission standards. However, what is not documented is how to actually deal with the specific VO's that are documented below.
EU4 - 7545670
For vehicles with:
EU4 exhaust emissions standard (S167A) = Yes
EU3 - 754670
For vehicles with:
EU3 exhaust emissions standard (S169A) = Yes
EU2 - 754671
For vehicles with:
EU2 exhaust emissions standard (S168A) = Yes
Or:
Without catalytic converter (S199A) = Yes
Or:
Data record without EOBD (S861A) = Yes
What does this mean? it means that if you flash 754670 into a US spec car it will default to EU4 instead of EU3. This how to will show how to choose between EU3, EU4 and EU2.
EU4
Simply flash the ZUSB.
EU3
Remove Secondary Air Pump relay underneath glove box.
EU2
Remove Secondary Air Pump relay.
*Remove fuse #4 (EF4) on the fuse holder inside the DME box.
Fuse Holder
EF1 = 30A, MAF, Cam sensor #1, DME, T-Stat, Evap emission valve (some say it's 30A - DME, Injectors, SMG Hydraulic unit)
EF2 = 30A, Fuel injectors, Both Vanos solenoids, Cam sensor #2, SAS pump electrical valve (some say it's 30A - DME, Idle control valve, Fuel tank ventilation valve, Fuel pump)
EF3 = 20A, Cam sensors, MAF, Crank Sensor, Heated O2 sensors (some say it's 30A, others say 25A - E-box fan, Transmission RPM sensor, CPS, MAF sensor, Fuel pump relay, SAP relay, A/C Compressor relay, Fuel tank leakage diagnostic module, SMG selector lever)
EF4 = 30A, Oxygen sensors and oxygen sensor heater circuits
EF5 = 30A, Fuel Pump Relay
Now I haven't had a chance to study the WDS to figure out exactly what is ran on fuse 4. But based on how my test vehicle performs it leads me to believe this fuse is for the post cat 02 sensors and heater circuits. While EF3 handles the pre-cat 02 sensors. What I am not 100% sure about yet is if the motor is still using the pre-cat 02 sensors to trim fuel. I do see the adaptive and multiplicative values updating. Again the WDS will confirm this. However, I think removing the fuse tells the DME to stop using the post cat 02 to further trim the fuel mixture which caused rough idle and hesitation when driving on my test car. (headers+no post cat sensors connected)
I was able to see the pre-cat 02 sensors fluctuate and work through INPA. didn't verify the posts since I had them disconnected and showed a steady .42 Volts.
Here's a link if you'd like to take a gander at the WDS and find out for me (Lazy) I' will find out when I eventually un-lazy myself...
http://www.bmw-planet.com/diagrams/release/en/
Final Step
After finishing the steps above go into INPA or GT1 and clear your adaptations ; that's it!
EU2 - Special Notes
Now through GT1 you will be able to access the test function "set idle mixture"
This will also tell you if the DME is in true EU2 mode as it typically throws an error if ran on the other variants.
EU4 - SAP and catalytic 02 Sensors present and Ready. PASS
EU3 - SAP monitor N/A (not applicable) 02 sensors present and ready. PASS
EU2 - SAP monitor N/A (not applicable) 02 sensors (? not yet tested) EOBD not on. FAIL
EU2 - the EU2 software will require the EOBD ( engine light on key on ) to be manually coded into the DME via tuning methods for it to pass)) that is depending on how the 02 sensor heaters show up i.e N/A will pass, not ready will not.
Flash file with EU2 EOBD turned on
https://forum.e46fanatics.com/showthr...0#post15766530
The reason EU2 works flawlessly on cars with cats is because it's running a hybrid setup
I.E EU3 exhaust emissions standard (S169A) with the EU2 exhaust emissions standard (S168A) data map (tuning map) which I think is not ideal without a remap.
I will also open up a comprehensive DME tuning thread in the DME tuning subforum (similar to the one found in m3forums) when I start getting into tuning the test car.
<-- Mango *F-BOMBS IN SIGS*PRIUSCRISIS
Bilstein HD's | E30 M3 FCAB's | H&R OE Sports | F+R strut bars | Self tuned 027 93 octane chip | KoseiK1's on R888's | + crazy OCD maintenance
new//M3fan is offline   Reply With Quote
Old 10-11-2013, 12:09 PM   #2
Llink78
My Ride: 2002 330i
Finally. On the 26th my car will be running EU2. Working on getting an inspection here in NYS. From what i hear this will pass the computer test. Not worried about visual at this point. Since ill be running EU2 iv been looking for tuning for it also, since having no Catalytic converters, and 3" exhaust i want to try to gain the most from my NA power. Your last sentence you will be tuning using EU2 on a M54?
Llink78 is offline   Reply With Quote
Old 10-11-2013, 12:10 PM   #3
new//M3fan
Originally Posted by Llink78 View Post
Finally. On the 26th my car will be running EU2. Working on getting an inspection here in NYS. From what i hear this will pass the computer test. Not worried about visual at this point. Since ill be running EU2 iv been looking for tuning for it also, since having no Catalytic converters, and 3" exhaust i want to try to gain the most from my NA power. Your last sentence you will be tuning using EU2 on a M52?
No M54B30. You missed the big bolded red print at the beginning of my post...
EU2 as it is will not pass as is. Due to no CEL on when key on. That needs to be added later through coding into the ECU.
Sponsored Links
Advertisement
Old 10-11-2013, 12:13 PM   #4
Llink78
My Ride: 2002 330i
Woops i did read. my brain knew m54. Brain typed 52. I have a 330i thats why im going euro. Will keep up with your work! really excited to see where this goes.
Old 10-11-2013, 12:20 PM   #5
new//M3fan
As soon as I get my hands on a A2L or DAMOS for the MS43. I'll get to it. Granted this will take a community effort since I can't do it all haha.
However finding the byte that turns on EOBD for the EU2 software version will be easy. Since the EU3 and EU2 share the same program version.
Old 10-11-2013, 03:05 PM   #6
Hornung418
My Ride: '04 MB ZHP
I just ran a solid copper wire (insulated) from the oil light to the CEL. Just had to find the hot side of the solder points. passed inspection with EU2 on my 328i.
Hornung418 is offline   Reply With Quote
Old 10-11-2013, 03:08 PM   #7
new//M3fan
That's a neat way to go around it. I want to eventually fix it through the software itself.
Old 10-11-2013, 10:07 PM   #8
Hornung418
My Ride: '04 MB ZHP
Re: E46 emmision variants and how to
Yeah that woukd be a more reliable solution.
Old 10-12-2013, 08:09 PM   #9
new//M3fan
I have found the address that controls that
Old 12-28-2013, 07:32 PM   #10
unevolved
My Ride: 2003 325i
I apologize if this is a stupid question, but is it possible to run EU2 on an M54B25?
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 01-06-2014, 04:24 PM   #11
stefm5
My Ride: 2001 530i
so, is it possible to run the engine without pre-cat 02 sensors? what about mixture?
stefm5 is offline   Reply With Quote
Old 01-06-2014, 06:31 PM   #12
unevolved
My Ride: 2003 325i
I'd say no, not anywhere close to well. That's going off of what I know about other modern fuel injection systems, not these BMWs specifically. Never know, though, someone may come in here and surprise me.
Old 01-07-2014, 10:02 AM   #13
stefm5
My Ride: 2001 530i
but what is the purpose having 02 sensors in a factory catless setup?
if you look on bmwfans.info there are screw plugs instead of 02 sensors (for vehicles without catalytic converter S199A)
Old 01-07-2014, 11:28 AM   #14
unevolved
My Ride: 2003 325i
Pre-cat O2 sensors tell the engine how rich or lean it's running, so it can make corrections as necessary for optimum power and/or emissions. Otherwise known as a closed-loop control. Without any O2 sensors, you'd be running essential an open loop, where the ECU is basically operating in "eyes closed" mode guessing at its AFR based on the other inputs it can see. Possible, but not as accurate.
Old 01-07-2014, 12:59 PM   #15
stefm5
My Ride: 2001 530i
correct. open loop. like engines in europe before EU2. engines were stronger than US versions because the only reason for 02 sensors is emissions. i remember my m30b34 had 218hp and m30b34kat had 182hp
Old 01-07-2014, 01:08 PM   #16
GuiltySpark
My Ride: 02 325xi
You mean post cat o2 sensors, right?
GuiltySpark is offline   Reply With Quote
Old 01-07-2014, 01:11 PM   #17
stefm5
My Ride: 2001 530i
no i mean pre cat sensors. post cat aren't something special. they monitoring cats efficiency
Old 01-07-2014, 01:18 PM   #18
GuiltySpark
My Ride: 02 325xi
I mean pre cats are important, post cats are just monitoring the exhaust. An engine can't be too efficient without the monitoring capabilities of the pre cats.
I thought you were saying pre cats weren't important.
Old 01-07-2014, 01:27 PM   #19
stefm5
My Ride: 2001 530i
what i'm saying is that pre cats are important because of the engine's management structure. which is all about emissions. mixture adaptation to keep lamda 14.7:1 constant has nothing to do with performance
Old 01-07-2014, 01:43 PM   #20
GuiltySpark
My Ride: 02 325xi
Oh, cool. That's interesting.
02, catless, delete, emissions, sensor
