BMW e46 344ci M62 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > Tuning & Tech > E46 Engine Swaps
E46 Engine Swaps
Replacing your motor? From direct replacements to more exoctic engines, if it's going under the hood of an E46 3 Series this is the forum to discuss it.
Old 12-31-2013, 09:29 AM   #1
MAXixt
My Ride: e46 335ci
BMW e46 344ci M62
This summer this project was finished ,few words abot modificatons:
Engine- m62b44 non vanos
gearbox-6speed manual
gearshaft - rear side m3,front side customized 540 e39
rear axel-M3
front axel -m3/330i
suspension -AP coil overs
Brakes-M3
We had problems with dash coding,because when ecu,ews and dash connected each other thru can ,dme coding failed. To solve this problem we cutted of the ews and made an emulator in ecu.
Engine mouns were made from 5mm stell so are the places where rubber mounting on subframe. If someone will swap V8 its easier to take subframe from e30 with fron stabilizator bar (e30 has it on the other side and dont disturb oil pan)Also 30mm spacers neede between subframe and body.
Oil pan also needs to be cutted a bit ,to get some free plase to mount engine max backside ang downside for better hadling.
Ehxaust headers are from X5 ,ehxaust piping made like this because e46 body doesnt have enough place for pipe on the drivers side as e30&e36.
If some one have any questions,please ask.
ID:	540632   Click image for larger version
ID:	540633   Click image for larger version
ID:	540634   Click image for larger version
ID:	540636   Click image for larger version
ID:	540637   Click image for larger version
ID:	540638   Click image for larger version
ID:	540640   Click image for larger version
ID:	540641   Click image for larger version
ID:	540642   Click image for larger version
ID:	540644   Click image for larger version
ID:	540645   Click image for larger version
ID:	540646   Click image for larger version
ID:	540648   Click image for larger version
ID:	540649   Click image for larger version
MAXixt is offline   Reply With Quote
Old 12-31-2013, 09:31 AM   #2
MAXixt
My Ride: e46 335ci
2nd start when the car was finished
Old 12-31-2013, 02:15 PM   #3
tuscan1205
My Ride: e46 325CI, w212 E550
awesome!
'02 e46 325CI & '12 w212 E550
tuscan1205 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 12-31-2013, 02:32 PM   #4
unevolved
My Ride: 2003 325i
Nice! Planning on repainting any of the mounts?
In a bacon and egg sandwich, the chicken is involved, but the pig is committed. Be that pig.
unevolved is offline   Reply With Quote
Old 12-31-2013, 03:05 PM   #5
MAXixt
My Ride: e46 335ci
Its already powder coated,just dont have photos of them.
Old 12-31-2013, 03:25 PM   #6
unevolved
My Ride: 2003 325i
That's cool, it looks really well done.
Old 12-31-2013, 11:02 PM   #7
jM2.me
My Ride: BMW
Do you have any pictures of exhaust headers? You did say that X5 headers were used, but were they modified?
Edit: Don't first gen X5s and e46 share the chassis? If they do, then I am curious if M62 swap could be done without custom made exhaust headers and/or steering link mods .
jM2.me is offline   Reply With Quote
Old 01-01-2014, 01:41 PM   #8
MAXixt
My Ride: e46 335ci
Left side needs to be modified because of the steering shaft position,right side fits perfect. X5 and any e46 are not the same chasis,some parts from e46 are in the X3 but X3 wasnt with V8
Old 01-03-2014, 01:50 PM   #9
Levim9
My Ride: S54 325i & LSB M3
Very nice swap!
Levim9 is offline   Reply With Quote
Old 01-03-2014, 01:55 PM   #10
jM2.me
My Ride: BMW
Ahh, neat. How about swapping wires and electronics?
Just some minor re-wiring and moving pins?
I have been eyeing M62 on local craigslist. Complete 4.6 engine for a grand.
Was thinking about taking break from college this summer and doing the swap since we already have welding machine, engine hoist and stand, and more than enough tools.
Old 01-03-2014, 02:12 PM   #11
MAXixt
My Ride: e46 335ci
4.4 is better than 4.6,not more powerfull but more relieble.With wires -not such difficult,just take both diagrams and connectIf you want abs and asc works,abs module,sensors etc must be from e39 (if engine is from e39)
Old 01-04-2014, 05:04 AM   #12
modjo
My Ride: 330XI
Dk projekts?
modjo is offline   Reply With Quote
Old 01-04-2014, 09:36 AM   #13
MAXixt
My Ride: e46 335ci
Old 01-05-2014, 03:10 AM   #14
tuscan1205
More pictures or videos? I still think this project is amazing. A swap like this would be awesome after college.
Old 01-05-2014, 03:30 AM   #15
modified
My Ride: bmw
Did you do all of the electrical wiriing by yourself?
modified is offline   Reply With Quote
Old 01-05-2014, 07:39 AM   #16
MAXixt
My Ride: e46 335ci
Our electronics foreman did
Old 01-05-2014, 07:42 AM   #17
MAXixt
My Ride: e46 335ci
What I have posted is all we have,it wasn't enough time for this project,so it is as it is. Maby our customer will send me some photos after the car will be with new interrior and after the paint shop.
Old 01-05-2014, 08:08 AM   #18
Brevik
My Ride: Tiag M3
Nice work OP!
In before 50/50 comments
Brevik is offline   Reply With Quote
Old 07-05-2015, 11:53 AM   #19
K15RVC
My Ride: 02 330ci Clubsport
Hi MAXixt,
I am planning this swap. you mention that the e30 subframe will be easier for the swap... what do you mean?
And what modification does the oil sump need to fit?
Also could e39 front subframe go into e46 for even easier install??
K15RVC is offline   Reply With Quote
Old 10-02-2015, 05:42 PM   #20
Taper
My Ride: Espaņa
Is possible to modify the oil pan to save front sway bar?
Taper is offline   Reply With Quote
