Intake Manifold and Vacuum Caps - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-27-2015, 10:00 PM   #1
Ceric
My Ride: 2005 BMW 325i
I decided to tackle the vacuum system on my car, next.
Based on my research, on a 2005 325i there should be two vacuum ports that are capped off and not in use, #1 and #2 in the picture below. There is no space in the engine bay to visually inspect that area so I stuck my hand in there and felt around. The #2 cap (larger of the two) feels very loose and is very easy to spin around and to take off. The #1 cap was half off the nipple and feels dry-rotted. Both of them have to go.
Does anyone here know their respective sizes? What vacuum cap size would fit on each one of them, and are those two the only two unused vacuum nipples on the intake?
Ceric is offline   Reply With Quote
Old 04-27-2015, 10:28 PM   #2
SilberVogel
My Ride: 2002 330Ci Conv.
The cap for number 1 is 3.5mm and item #15 in the diagram below (part #11611437560).
The cap for number 2 is 7.0mm and item #17 in the diagram below (part #11611727176).
Click to view on RealOEM.
Here's a thread that covers some additional diagrams and their corresponding vacuum lines that might be a useful reference, as well: http://www.bimmerfest.com/forums/sho...d.php?t=574814.
DIYs help you save money with repairs; let www.bmwpnpc.com help you save money with the parts.
Last edited by SilberVogel; 05-05-2015 at 01:41 PM. Reason: https://forum.e46fanatics.com/showthread.php?t=1075244
SilberVogel is offline   Reply With Quote
Old 04-28-2015, 04:04 PM   #3
Ceric
Thank you so much for taking the time to answer in such detail.
Sponsored Links
Advertisement
Old 04-28-2015, 04:19 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
If I ever have the intake off, I will epoxy any vacuum ports that are not used!!!!
Solve your misfires, lean codes, rough idle - https://forum.e46fanatics.com/showthread.php?t=897616
Fuel pump failures - https://forum.e46fanatics.com/showthread.php?t=929501
Temp Info - https://forum.e46fanatics.com/showthread.php?t=964491
Hidden OBC Menu - Check Voltage, Temp, Fuel Level - https://forum.e46fanatics.com/showthread.php?t=239619
Old 04-28-2015, 04:26 PM   #5
SilberVogel
Absolutely!
In case anyone needs the labeled version of that image, here it is as well:
Agreed! Sounds like a much better solution.
Old 04-29-2015, 10:03 AM   #6
nbesheer
My Ride: 2003 330Ci
And just to verify the vacuum reservoir is only used on 330 models for the exhaust butterfly valve ?
nbesheer is offline   Reply With Quote
Old 04-29-2015, 11:56 AM   #7
Dave1027
My Ride: '06 IR zhp coupe
Originally Posted by SilberVogel View Post
Absolutely!
Was not the case on my car. All three ports were capped.
Old 04-29-2015, 11:57 AM   #8
SilberVogel
Don’t believe it’s unique to the 330, as I’ve seen the “golf tee mod” done by some with the 325. On a 325, it’s likely going to be either an Xi or the SULEV.
Here’s one thread with some discussion: http://www.bimmerfest.com/forums/sho...17#post6717517.
And here’s the E46 vehicles RealOEM shows the vacuum reservoir on (#18101740207): http://realoem.com/bmw/partxref.do?p...ur=&series=E46
Old 04-29-2015, 12:11 PM   #9
nbesheer
My Ride: 2003 330Ci
Ah, I just assumed that 330s were the only one with the flap.
Old 04-29-2015, 12:20 PM   #10
jfoj
The mid 2004 and newer non xi/M cars do not have a vacuum controlled SAP valve so this is why one of the ports is not used.
I also expect the ZHP not to have the exhaust butterfly.
So this is probably why the newer ZHP do not have any connections to these ports.
Old 04-29-2015, 01:55 PM   #11
sam_e787
My Ride: 325ci MS43
Year: 2002
Model: 325ci
Transmission: 5sp
Just get the variety pack at autozone. They have the sizes you need. Ask for emissions plugs or vacuum plugs. They are on the wall.
sam_e787 is offline   Reply With Quote
Old 05-04-2015, 10:03 PM   #12
Ceric
As per what jfoj said, my 2005 325i does not have a vacuum controlled SAP valve.
In the picture below none of the crossed out items are present on my car, and the SAP check valve does not have a vacuum nipple on it
So when this is taken into the account; does this mean that the only vacuum lines on my 2005 325i are the small fuel pressure vacuum line from the F connector to the fuel filter, the larger vacuum line from the F connector to the brake booster sucking jet pump, and the big nice thick brake booster vacuum line? That is it?
And according to this I should have 3 capped off vacuum ports in total on my intake manifold, as per the image below? Because I am about to permanently seal them with epoxy. Vacuum leaks be damned.
Old 05-04-2015, 10:05 PM   #13
peytonracer4
:D
peytonracer4's Avatar
My Ride: '00 328i
^^ great info. thanks for the illustration!
Old 05-04-2015, 10:14 PM   #14
Ceric
You're welcome, it's my hope that they eventually help someone down the road.
Old 05-25-2015, 09:10 AM   #15
ff54976
I am so glad i found this. I have a 2005 325i. I have the p0171 p0174 codes. So i replaced my ccv and when i took off the intake manifold it didnt have a check valve or vacuum lines at the rear, 2 of the 3 port were capped off. The one port didnt have a vacuum line connected to it or anything. Im trying to figure out if that port was supposed to be capped of does something connect to it??
I still have the codes after changing the ccv and the intake boots. Im trying to figure out both issues.
thanks!
ff54976 is offline   Reply With Quote
Old 05-25-2015, 09:13 AM   #16
ff54976
ohh i do not have any of the parts ceric stated in the earlier posts. (no vacuum lines, valves, no nipple on the pump, etc etc
Old 05-25-2015, 11:28 AM   #17
Dave1027
That large port should be capped. Perhaps it fell off? I'd guess that's the cause of your vacuum leak.
Old 05-25-2015, 11:38 AM   #18
Ceric
Since you have a 2005 car, you will not have a vacuum controlled SAP, so you will not have a check valve in the back.
In a a 2005 325i all 3 vacuum ports should be capped off as they are not used for anything. The missing cap on your intake manifold is part #11611727176. When I went to check mine a few weeks ago it was in such a bad shape that it's a minor miracle that it did not fall off. Go to your local automotive parts suply store and look for some vacuum caps. They usually sell them in variety packs. For that particular port you need a 7.0 mm cap. If you can't find a 7.0 mm one use something close to it.
Old 05-25-2015, 05:53 PM   #19
ff54976
Thanks guys. I thought that and when i did the ccv i capped it off anyway. Sucks I still have the cel's but its one less thing it could be. So is this a 325i thing or only 05 models that dont have the check valves and everything?
Old 05-27-2015, 05:52 PM   #20
Ceric
It's a late model thing. They found a better way of doing the SAP and stopped using the vacuum line in the last year of the E46 production. They also stopped using the vacuum line and vacuum reservoir in late model E46 330i's for the exhaust flap, they started using an electronically actuated one instead.
