Need a DME or EGS flash update? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > BMW Regional Forums > Regional Forums > California
California
Northern California Southern California
Old 07-18-2015, 02:08 PM   #1
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
What I Do
I'll update the software in your DME (engine control module) or EGS (automatic transmission control module) to the latest BMW factory version for free using WinKFP. I've done over 400 of these for various friends and forum members over the years. You can drive out to my house in Riverside, CA or I can do it remotely over the internet. PM me to get started.
Why Update?
I recommend every car be updated to the latest. There are three main benefits.
  1. Bug fixes: there are many bugs in various DME families that have been revealed over the years, including the 2800 RPM stutter in MS45.1, inability to get O2 emissions monitors to pass in MS42, transmission shifting maps in GS20, etc.; if you look at the software version history, some have over 20 revisions!
  2. More responsive: the throttle, timing, fuel control, and shifting maps have all been improved over time to make it feel more responsive, everyone notices their car feels quicker and less sluggish after an update
  3. Smoother: the overall driving experience feels more refined and smoother, transitions over the acceleration bands and shift points is less jerky
Which BMWs?
BMW models: E39, E46, E53, E83
DME: MS42, MS43, MS45.1, MSS54
EGS: GS20, GS8.60.4, SMG2
What Do I Need for a Remote Update?
  1. Windows laptop, can be 32-bit or 64-bit XP, Vista, 7, 8, or 10
  2. K+DCAN cable with the switch https://drive.google.com/file/d/1DzN...w?usp=drivesdk (or already soldered pins 7 and 8).
    Currently recommending this cable: https://www.amazon.com/dp/B0817D2L9J
  3. Downloaded the software files from my Google Drive (PM me for download links)
  4. Strong Internet and phone connections at the car
Windows 10 Note
There is a minor issue on Windows 10 with downloading and running the installer EXE file. Defender recently started reporting it as having a trojan. It's only the installer file, all the installed files are fine. I'm guessing because it's such old software that there's some vulnerability related to the installer wrapper BMW used. You can download the same file from another source and see it's also flagged, so you don't think only mine is flagged.
You'll need to disable Defender and possibly other anti-malware before you can download and install the software.
https://answers.microsoft.com/en-us/...a-601385b961db
After the installer finishes it prompts for a Windows reboot. Rebooting automatically turns Defender back on.
How to Install the Software
I'm happy to install and configure the software for you. If you want to try, this video shows how to set up the software after you've downloaded the files from my Google Drive.
Why Is It Free?
https://forum.e46fanatics.com/showpo...&postcount=295
How to Check Current Version
https://forum.e46fanatics.com/showpo...15&postcount=3
How to Update?
https://forum.e46fanatics.com/showpo...0&postcount=94
Version History
The following links list version histories for each module. The history is a daisy-chain from top going down. You find your current version in the left column, then take the version to its right and search again. Keep doing this until you don't find a newer version and that is the latest available.
Old 07-18-2015, 04:29 PM   #2
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
Im in. Any way I could check for my existing software numbers with PA Soft?
Edit: Also anything specific for MS45 ZHP?
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 07-18-2015, 09:49 PM   #3
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
This describes how to find your current DME or EGS version number using either BMW Scanner 1.4 or INPA. Itís called the Assembly number by BMW.
BMW Scanner 1.4
  1. Run PA Soft BMW Scanner 1.4
  2. Let it come up with the initial screen that displays the car details
  3. Close it down
  4. Open its log file in Notepad
  5. Scroll down to the USER INFO FIELDS section
  6. Find the Assembly, a seven-digit number usually starting with 7
This is an excerpt from my PA Soft log file. The DME and EGS versions are in bold.
# USER INFO FIELDS
Unit Date VIN Odometer Assembly Software Service Dealer Tester Program ver.
DME -> 28.01.04 WBABD33404PL03707 0 km 7.540.384 7.540.385 0.000.000 012321 42324
EGS -> 28.01.04 WBABD33404PL03707 0 km 7.535.060 7.535.061 1.000.000 012321 42324
INPA
  1. Run inpaload.exe
  2. Choose your BMW model from the main screen
  3. Choose Engine for DME or Transmission for EGS and select your appropriate module family
  4. At the moduleís main page, choose F3 for Code or UIF
  5. Find the Assembly number, a seven-digit number usually starting with 7
Sponsored Links
Advertisement
Old 07-19-2015, 01:00 PM   #4
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Edit:
# USER INFO FIELDS
DME* -> 15.03.04 WBABW53414PL46300 0 km 7.540.382 7.540.383 0.000.000 012321 42324 0044570LL00S
06.07.06 WBABW53414PL46300 19200 km 7.561.520 7.561.521 0.000.000 012321 42324 0044570LO00S
EGS -> 15.03.04 WBABW53414PL46300 0 km 7.535.062 7.535.063 1.000.000 012321 42324 -
Old 07-19-2015, 07:08 PM   #5
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Originally Posted by CarbonZHP View Post
Edit:
# USER INFO FIELDS
Latest versions for your car.
DME: 7561520 - found in C:\EC-APPS\NFS\DATA\MDS451\MDS451.HIS
EGS: 7557994 - found in C:\EC-APPS\NFS\DATA\GD20\GD20.HIS
Old 07-19-2015, 11:06 PM   #6
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
So just trans
Sent from my LG-VS985 using Tapatalk
Old 07-19-2015, 11:44 PM   #7
mikeetastic
My Ride: lots of 3
wish i was in socal
edit: when you do one please create a video DIY from start to finish..
mikeetastic is offline   Reply With Quote
Old 07-20-2015, 12:11 AM   #8
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
So just trans
Yep. I see now that your DME is already at the latest version. I missed that second UIF entry earlier today.
Old 07-20-2015, 12:12 AM   #9
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Originally Posted by mikeetastic View Post
wish i was in socal
Road trip?
There are a few youtube videos out there. Here is one of a Russian guy doing a bench update so you can see WinKFP in action.
And another very simple update.
Old 07-20-2015, 11:53 AM   #10
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
When are you available
Old 07-20-2015, 11:54 AM   #11
mikeetastic
My Ride: lots of 3
can you do bench? ill send in my DME lol.
Old 07-20-2015, 09:24 PM   #12
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
How about this weekend? My wife works both days so I am available. I will PM you my contact info and we can set it up.
Old 07-20-2015, 09:26 PM   #13
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
I haven't tried, but watching that youtube video he has a power supply, the DME, EWS, and maybe some other stuff all wired up. TerraPhantm has stated on this forum that he can bench update so maybe PM him?
Old 07-26-2015, 11:38 AM   #14
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Went up there yesterday for the EGS update. First thing, if you are lowered, be very very careful getting to the location. Dragged my reinforcement plate over a few of the bumps. Other than that, OP is a great guy and the job only took about 15 minutes. The difference in my trans is night and day. Better shifts from high rpm, quicker throttle response, and a ton of overall refinement. I drive quite hard so I notice all the tiny things a regular driver might not see, but the EGS update is extremely worth the time. Thanks again!
Sent from my VS985 4G using Tapatalk
Old 07-26-2015, 02:16 PM   #15
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Thanks for the kind words. Always glad to help out a fellow forum member. CarbonZHP has one nice E46! Yeah, those speedbumps on my street are a royal bitch, the main reason I really can't lower my cars.
I can also set up your Windows laptop with BMW Standard Tools 2.12 (INPA, WinKFP, NCS Expert, etc.), and the latest daten files, and if you have a K-CAN cable we can test it on your car to verify it works properly. I will create another thread for that soon.
Old 07-26-2015, 02:17 PM   #16
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Yeah that would be great. There aren't any good up to date threads on setting that up.
Old 07-27-2015, 05:52 PM   #17
SoCalZman
My Ride: 05 BMW 330i ZHP 6MT
Riverside is 40 miles from me but....let me go home and look through my old PASoft logs and see if I can find the DME version for my ZHP.
2005 BMW 330i ZHP 6 speed
Stock: Nav, leather, PDC
Added by me: OEM Alarm, OEM heated seats, OEM aux kit, OEM Bluetooth, intravee, M3 strut brace, BMW Performance Intake, Nappa leather arm rest, updated LCM (triple blink, euro hazards, trifecta lighting, 3 stage brakes), temp gauge mod
SoCalZman is offline   Reply With Quote
Old 07-27-2015, 05:58 PM   #18
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Was 44 miles from me. I drove 80 miles each way for my coils as well lol
Old 07-27-2015, 07:23 PM   #19
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
Hey Zman, I work in Irvine and commute every day on the train. If you're not too far away, maybe a house call? You can PM me your contact info and we can figure something out. All I need is my laptop and cable, so it's pretty portable.
Old 07-28-2015, 11:54 AM   #20
SoCalZman
oh perfect Im in Irvine. Well I didnt get to my computer to look through my logs last night. Ill message you when I find my PASoft logs.
