Xi Lowering / Have Your Cake & Eat It Too - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Thread Tools Search this Thread Rating: Thread Rating: 15 votes, 4.73 average. Display Modes
Old 10-08-2015, 01:58 PM   #1
Rob43
Rob43's Avatar
My Ride: 03 331Ci 5spd R1200R
For the last 6 months I've been working hard at lowering the E46 Xi chassis suspension, through a cumulative effort with different forum members I've accomplished my goal of not only Lowering the Xi chassis but also providing a smooth & compliant ride at the same time. (Having Your Cake & Eating It Too)
The drop will be about 1.00 to 2.00 inches in the front (Depending on Spring Choice) & about 0.25 to 0.75 inches in the rear, this drop will "Even Up" your current look because as you know the front sits Much Higher than the rear. All in all this will make your Xi chassis E46 look Great while still maintaining its AWD capability with ease. Some of the best points about this suspension system are:
1) You'll still have a nice factory OE ride with planted handling that's very smooth feeling.
2) The price is Very affordable at roughly ~$799.
3) The Front & Rear shocks are BOTH Externally Adjustable, meaning you can make strut or shock adjustments in seconds by twisting a knob.
The four major components to making this Xi Lowering a reality are:
1) Sport Front Xi Struts.
2) Rob43 Special 9 Way External Adjustable Rear Shocks, these special shocks are not only a bigger diameter (they fit perfectly) than any other E46 shock, but they're priced right too.
3) RWD* Lowering Springs.
4) Supreme Power Drop** Hats.
This suspension can also be easily fitted to an Xi Touring chassis, it was tested on several with excellent results.
If you'd like one of these Xi Lowering suspensions for yourself, shoot me a PM & we'll discuss it.
Rob43
Review Of This Setup !!!
https://forum.e46fanatics.com/showthread.php?t=1112564
****** UPDATE: For those of you on a tight budget, I've tested a Non-Adjustable option that gives a nice looking drop that "Evens" things up and rides like Stock OE for comfort. Price shipped is roughly ~$549 for this option !!!
* It's NOT well known, but certain RWD suspension parts fit the Xi chassis perfectly; Choosing the "Correct" RWD Springs are one of those items. Only one or two RWD springs can actually lower the Xi chassis the way you'd want.
** Depending on options these might NOT be needed, this could save you ~$90 dollars.
SUMMIT POINT WV 1:24:229 SCCA
(DynoDynamics
Dyno Video)
Old 10-08-2015, 08:05 PM   #2
SeattleLSB
My Ride: 2003 330XI, 2003 M3
PM Me the Details.
2003 LSB/BLK M3/SMG/Premium/Cold Weather/Nav
2003 AW/BLK 330XI/AT/Sport/Premium/Cold Weather
SeattleLSB is offline   Reply With Quote
Old 10-09-2015, 11:03 PM   #3
Rob43
Rob43's Avatar
I cleared my PM box.
Rob43
(DynoDynamics
Dyno Video)
Sponsored Links
Advertisement
Old 10-10-2015, 09:02 PM   #4
jmo69
My Ride: 03 325xi 98 328is
I wish I had known about this before I dropped $400+ on new front springs and used rears. Too late now.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
jmo69 is offline   Reply With Quote
Old 10-11-2015, 09:53 AM   #5
Rob43
Rob43's Avatar
There are components of my Xi lowering suspension that would benefit your current ride, that could be front or rear dampers or maybe front drop hats & spring pads to help with how it sits/looks.
Rob43
(DynoDynamics
Dyno Video)
Old 10-11-2015, 05:32 PM   #6
PeteyEsco
My Ride: '02 325xiT
Thankfully I didn't redo my suspension for my touring last year. PM'ing you. Click image for larger version
PeteyEsco is offline   Reply With Quote
Old 10-13-2015, 08:59 AM   #7
jtyghter
My Ride: 03' 330xi
I'm interested in the drop hats and maybe rear shocks
jtyghter is offline   Reply With Quote
Old 10-13-2015, 01:44 PM   #8
Rob43
Rob43's Avatar
Originally Posted by PeteyEsco View Post
Thankfully I didn't redo my suspension for my touring last year. PM'ing you. Attachment 614849
I haven't seen your PM yet ?
Tell me what your current Exact suspension setup is ?
Rob43
(DynoDynamics
Dyno Video)
Old 10-13-2015, 07:01 PM   #9
jtyghter
My Ride: 03' 330xi
I have koni's all the way around and h&r springs for xi
Rob43[/QUOTE]
Old 10-14-2015, 12:34 PM   #10
Rob43
Rob43's Avatar
OK.
You want the Supreme Power $89 dollar Drop Hats, shipping included.
http://www.supremepower.com/57573/68...perch-bmw.html
"IF" you're Completely happy with your current ride, keep your rear Koni's. But if you perceive Any bounce/bounciness that you'd like to dial out, then my 9 way rear shocks are the ticket.
Rob43
(DynoDynamics
Dyno Video)
Old 10-15-2015, 09:57 AM   #11
groundshock
My Ride: 04 330Xi
I bought the Eibach Xi-specific lowering springs. I couldn't be happier. 6 months, 5000 miles, zero issues. I don't see any reason to go with anything other than that since the Eibach is tailored to the Xi chassis. Just my opinion.
2004 TiAg 330xi Sedan
2008 GTI DSG 5Dr
groundshock is offline   Reply With Quote
Old 10-15-2015, 10:25 AM   #12
wcushing75
My Ride: 2001 BMW 325xi
What's the price of that kit and does it level the car and how much drop? I'm only looking for about an inch or so as I have a lot of snowfall in my area.
wcushing75 is offline   Reply With Quote
Old 10-15-2015, 12:08 PM   #13
Rob43
Rob43's Avatar
That's good, I'm glad you're happy with the Eibach Xi springs because they are a fantastic choice. The problem with just buying springs is, you don't have all the other components that make an overall suspension package.
What I'm recommending is an actual "Package" that will transform the Ride & Look of the Xi chassis. Having the ability to instantly change strut & shock settings is a Huge plus for anyone that wants to obtain the ultimate ride & handling for their driving style and road conditions. Springs alone, or when matched to standard dampers can never achieve this.
Last, as almost everyone knows with an Xi, your front end is almost always sitting Higher than the rear; My Suspension System Fixes This.
Rob43
(DynoDynamics
Dyno Video)
Old 10-16-2015, 03:26 PM   #14
jtyghter
My Ride: 03' 330xi
I just ordered the supreme power drop hats. I'll post results when they come in so people can see what H&R springs paired with the drop hats look like.
Old 10-16-2015, 03:52 PM   #15
Rob43
Rob43's Avatar
That sounds great., I know you'll happy with your results.
When taking pics of the side of your Bimmer, try to frame the entire chassis as close as you can in the pic with the lens about 2 feet off the ground. If you need to make any adjustments to obtain front to rear "Perfection", I know how you can achieve that too.
Rob43
(DynoDynamics
Dyno Video)
Old 10-20-2015, 10:44 PM   #16
Rob43
Rob43's Avatar
Cleared my PM's again for the 3 guys that tried to PM me today...
Rob43
(DynoDynamics
Dyno Video)
Old 10-20-2015, 10:56 PM   #17
ItsAllAboutTheXI
My Ride: 2004 TiAg 330xi
Rob43
[/QUOTE]
How do you like H&R and Koni combo? Handling improvements, comfort compared to stock? Would love to see some pics.
ItsAllAboutTheXI is offline   Reply With Quote
Old 10-21-2015, 07:03 PM   #18
jtyghter
My Ride: 03' 330xi
I love the setup. In general I've always liked a sportier ride so I think the ride is firm without being too harsh. It's perfect for me.
Here is a pic from a few months ago. I'll be getting the drop hats early next week so I'll install them at some point next week.
https://forum.e46fanatics.com/attachm...3&d=1435189232
Old 10-21-2015, 07:06 PM   #19
jtyghter
My Ride: 03' 330xi
Oh yeah, handling is a night and day difference not even close to stock. very crisp and predictable
Old 10-21-2015, 08:41 PM   #20
Rob43
Rob43's Avatar
Has something recently changed ? When we last talked, you didn't even want to spend $500 on your Xi's suspension.
I just looked at your pic & your Bimmer looks good. The drop hats will lower the front about 1/2" more but in turn will "Lift" the rear end slightly more so be prepared to install thinner rear spring pads to even things out.
Rob43
(DynoDynamics
Dyno Video)
