Top 10 E46 Failures - Parts you MUST replace (Mango Starter Pack) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Closed Thread
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 2.88 average. Display Modes
Old 08-18-2016, 10:21 PM   #1
My Ride: Lexus
Top 10 E46 Failures
These 10 parts will certainly fail on you
(For easier reading and info where to buy the parts, you can also find this post at my blog here.--Updated 9/27/16)
The BMW E46 3-Series produced from 2000 to 2006 is one of the more reliable BMWs you can buy. However, there are parts that will fail causing you to be stranded and/or cause major problems, including fires or destruction of more expensive components. These are the 10 most important and common failures on the BMW E46 platform.
You may have read my widely distributed and viewed post on the BMW E46 Cooling System detailing the common failures and the catastrophic results a single failure can result in, or you may have read my other posts on E46Fanatics.com which recommend full system replacements rather than picking, choosing, and replacing each individual part as they fail. I highly recommend you check out those threads including the links in my signature.
However I realize not everyone can afford to replace $3,000 worth of parts to restore their BMW E46 3-Series back to reliable and well handling condition. So I've created a top 10 list of must-replace items for your BMW E46 3-Series. These parts are the 10 failures of the E46 platform and are certain to leave you stranded, frustrated, or leave your car with dangerous sloppy handling. This is a great and inexpensive way to begin your BMW E46 adventure. Take it from me, I've replaced all these immediately upon purchasing my E46 and have never experienced a single breakdown or failure.
This is not meant to be a guide to every possible part to fail, just what I think the most commonly failed parts that make a significant impact on the reliability or safety of your BMW E46.
Number One - Expansion Tank
While I still recommend full replacement of the E46 cooling system, the expansion tank is an absolute must. It is not optional and it should 100% absolutely be replaced upon your purchase of an E46. Do NOT skimp on this. The common failure is for the tank to develop a hairline crack down the side of the tank resulting in a low coolant light and shortly (seconds) after that, an engine overheat which will destroy your soft aluminum engine in mere seconds. Many have been in big trouble because they've neglected to replace this $60 part. The links are to OEM expansion tanks. Do not buy this part aftermarket.
Number Two - A/C Blower Final Stage Resistor
This part fails on ALL BMW E46s. And E36s for that matter. The BMW E46 Final Stage Resistor is responsible for your A/C Blower Fan speed. The failure is erratic fan speed behavior or the fan completely failing to turn on. This is torture on a hot summer day. This failed part has also been known to cause car fires. Very dangerous.
Number Three - Fuel Pump
Experiencing long cranks? Hard starts? Does your engine just crank and crank but doesn't turn over? If you haven't experienced any of these symptoms, you will. This failure will happen. Don't forget the seal. Link to OEM fuel pump here.
Number Four - Throttle Body Intake Boots
Very common failure. The boots that connect your air filter box to your throttle body dry out and crack over the years. Will cause vacuum leaks and subsequent lean codes P0174. The symptom is poor fuel mileage and/or stumbling, idling problems and stalling. Replace your upper and lower intake boots. Cheap stuff. Don't skimp. Make sure you align the tab on the lower boot with the space on the throttle body. Very easy install.
Links to boots:
E46 323/325/328 set: lower and upper
E46 330 set: lower and upper
Number Five - Crankcase Vent System
Will certainly fall causing a vacuum leak. Poor idling, stumbling, poor fuel mileage, or even smoke out the exhaust at startup. Rubber and plastic cracks and fails over time. Replace it once and never touch it again. Buy it here on FCPEuro.com.
Bonus: Don't forget to replace the vacuum tubing that connects to the F connector to semi-hard line that goes to the fuel filter.
Info credit to HodgkinsC330i: Hose diameter: 5/32", available from O'Reilly part# P3340: $3.49 - Product Description: Thermoid Windshield Washer & Vacuum Tubing 5/32" x 6'
Post here showing diagrams of the system (see post #6): http://www.bimmerfest.com/forums/sho...d.php?t=574814
Number Six - Front Control Arm Bushings (FCABs)
The rubber in your front control arm bushings rot over time and will cause sloppy and loose steering/handling. If totally failed, your suspension will clunk as you brake and your entire front wheel will move forward 1 to 2 inches -- very dangerous at highway speeds as the wheel will turn violently when you hit the brakes. If you can't brake, you may crash. Easy install, two bolts hold it on. Get a 3-jaw puller and pull the old one off. Spray windex or soapy water on the new bushing and tap it on with a rubber mallet. Torque it down and enjoy your new handling. I recommend Meyle HD
Number Seven - Rear Trailing Arm Bushings (RTABs)
Same as above. These rot out and cause sloppy rear handling. Replace every 50,000 miles or 35,000 miles if you are really picky. These are responsible for rear wheel toe control. Give your car gas and if the rear end wags under acceleration, your bushings are toast. Very dangerous if they fail.
Bonus: I recommend M3 rear trailing arm bushings as an upgrade for more solid handling. Direct fit. Plug and play. This kit comes with the famous shims for even greater control.
If you want to do these yourself, I recommend an RTAB tool. You can also search Google for an "MIS RTAB tool."
Install tip: Don't over-concern yourself with finding the magical mythical tool or technique to eliminate pre-load on your RTAB install. This isn't a big of a deal or that precise of a job people make it out to be. And coming from me, Mr. Precise, that should tell you something. If you have the magical alignment tool, great. Use it. If not, no big deal. Simply take note of the angle of the RTAB bracket in relation to the trailing arm. Mark it with a pen, take a photo, whatever. And simply re-torque the new RTAB in place with the bracket at the same angle as when you removed it. Voila! Every time I have done this job, the bracket always comes out perfectly lined up with a casting line of the actual trailing arm. I've often used that as a guide. Either way, I don't think millimeter precision is required here. The rubber is really flexible and your rear wheels are in a constant state of movement as you drive down the road or load your car up with passengers. I also doubt BMW factory workers are installing the RTABs with 100% millimeter precision every time. There's always going to be a +/- range of accepted tolerance with these types of things. If you're a fanatic, you should be able to get within that range. Eyeballing these should work just fine.
Number Eight - Alternator with Voltage Regulator
Battery light flickering? Constant dead batteries? Even if you don't experience those symptoms, you will. It's usually the voltage regulator that fails, but many just replace the alternator which will include a new voltage regulator (it's bolted to it.) Many figure "why not?"
MAKE SURE YOU GO LOOK AT YOUR CAR TO SEE WHAT CONNECTOR YOU HAVE. SQUARE OR ROUND? Also install the same or higher amperage as what your car came with.
More common square plug alternator for 325 and 330
Less common round plug alternator for 325 and 330
323/328 square 3-pin alternator
Number Nine - Pulleys and Belts
These pulleys carry your belt system and will dry out and rot over time. Do your pulleys sound like skateboard wheels when spun? Does your engine make a squeaky noise as it runs? Your pulleys are ready to fail. When they do, it will throw the belts off and take your engine down with it. Instant overheat. Instant engine rebuild. Don't risk it. Don't forget to get new belts. You may as well.
See my thread here for what parts you need and where to buy them: https://www.e46fanatics.com/forum/sho...d.php?t=974746
Number Ten - Battery - Autozone H8 DLG
Very simple. Replace with a battery from your local parts store. Personally I went with Autozone brand -- paid $200 for my battery. You may be able to find it for $150.
If any corrections need to be made, feel free to let me know! Thanks.
Complete E46 Info 5.7M VIEWS
Mango is offline
Old 08-18-2016, 10:49 PM   #2
Positive Jon
My Ride: 2003 bmw 325i
Nice thread Mango.
Positive Jon is offline
Old 08-18-2016, 11:09 PM   #3
lingon300k
My Ride: 2005 325xi Automatic
Did you intentionally link to the Meyle tensioner and idler pulleys on your parts page over the INA pulleys? INA is the OE part manufacturer. Are the Meyle pulleys better?
lingon300k is offline
Sponsored Links
Advertisement
Old 08-18-2016, 11:21 PM   #4
My Ride: Lexus
Originally Posted by Positive Jon View Post
Nice thread Mango.
Thanks Jon. I read it again myself and wish I had this when I was a new owner. These 10 parts will fix 90% of peoples problems, I imagine.
I still stand by my normal "replace it all" threads for 100% coverage, but really, these parts absolutely will fail and need replacing.
There's probably a whole list of other parts that will fail like window regulators, pillar covers, etc. But those failures won't really leave you stranded or cause big problems.
I think this is a good list and is definitely an inexpensive starting point to quality E46 ownership.
Yes. In my opinion, Meyle pulleys are the superior pulleys. I've used them all. Meyles instantly feel more robust in the hands than OEM. Instant confidence. Try it yourself, see if you agree!
Of course, new INA pulleys are better than no pulleys.
Mango is offline
Old 08-18-2016, 11:38 PM   #5
lingon300k
I might have, but I just changed everything out with INA. I even screwed up and ordered the whole hydraulic tensioner assembly instead of just the hydraulic and the pulley. So all the pulleys/belts/tensioners are new. All OEM Conti/INA.
Do you prefer the Dayco AC belt tensioner to the INA as well? Is INA no good, in your opinion?
I'm asking overall because I'm helping another member, locally, with a parts list, and I recommended all INA for these.
(Thanks for the post, by the way!)
Old 08-19-2016, 12:17 AM   #6
das_autobahn
My Ride: 2004 330ci coupe
nice list!
das_autobahn is offline
Old 08-19-2016, 12:22 AM   #7
Nate158
My Ride: 2004 E46
Maybe not a catastrophic failure item, but it seems like the valve cover gaskets should be pretty high on the list too.
Nate158 is offline
Old 08-19-2016, 12:23 AM   #8
Nate158
My Ride: 2004 E46
Very nice list and thread. Subbed
Nate158 is offline
Old 08-19-2016, 01:39 AM   #9
RangerDave
My Ride: '00 328i ZSP w/ 257k
Year: 2000
Model: 328i
Transmission: 5MT
Great compilation. I've done all of these things over the years and agree they are probably the top 10 most important.
RangerDave is offline
Old 08-19-2016, 02:18 AM   #10
My Ride: Lexus
It's up there. Maybe #11? But doesn't quite work with the top 10 thing. People can deal with some oily engines. Their engines will be oily anyway from all the other stuff
No problem. They're all good. INA just came out with that stand-alone AC belt tensioner I think so really. Brand isn't a big deal. Just get them swapped out with whatever! All good in my book!
My personal preference is Meyle though.
Mango is offline
Old 08-19-2016, 06:48 AM   #11
Knight
My Ride: SL63 | SHO | E46
Good list and reminder.
FCAB link is pointing to RTABs.
Correct Link: https://www.fcpeuro.com/products/bmw...-31126757623my
Regarding batteries, the Duralast H8 DLG is a sound choice, but an alternative would be the Autocraft Platinum H8 AGM from Advance Auto. They tend to be more generous with promo codes, too.
http://shop.advanceautoparts.com/p/a...1&prefZC=07620
Knight is offline
Old 08-19-2016, 07:44 AM   #12
Spannerhead
My Ride: '02 330i/5 slicktop
Nice thread. Appreciated!
What about the auto headlight switch? That's been the cause of more than a few E46 fires.
Current:
Past BMWs:
Past Other: '85 GSL-SE '88 JZA70 '86 4K quattro '85 RX-7 S '85 RX-7 GSL
Spannerhead is online now
Old 08-19-2016, 07:48 AM   #13
Eagleeye504
Don't forget about oil filter housing gaskets on these cars
Eagleeye504 is offline
Old 08-19-2016, 08:04 AM   #14
LeMansteve
My Ride: sold - '04 330i
Chiming in with my personal experience. YMMV.
My 2004 330i has 177k miles, with about 1/3 of those miles being easy highway miles
Expansion tank - replaced preventively at 100k. Not much else to say here.
final stage resistor - could be starting to fail now. Have noticed very slight changes in fan speed at unexpected times.
Fuel Pump - replaced preventively at 150k. No signs of soft or hard failure when replaced.
throttle body intake boots - replaced at 45k and 130k due to cracks. Dammit, that probably means they need to be replaced again soon!
CCV - replaced at 130k due to oil consumption. New CCV did not solve the issue. Old one didn't have much life left in the hoses.
FCABs - failing around 100k, replaced at 120k. Was experiencing a slight steering tug during low speed braking. Currently running Meyle HD here.
RTABs - replaced at 165k preventively. Was not experiencing any symptoms of failed RTABs. The old ones looked and felt fine. Replaced with Genuine BMW. No noticeable change in ride or handling.
Alternator - original. Still putting out proper voltage. Have considered replacing preventively.
Tensioner pulleys - original. Will probably replace preventively at the next cooling system refresh coming soon.
battery - my original battery lasted 8 years! Replaced it with a Bosch battery about 5 years ago. Measured it just the other day at 12.34V.
LeMansteve is offline
Old 08-19-2016, 08:28 AM   #15
05SMG
My Ride: E90,F30,F80
Model: O5' 330ci (RIP)
Transmission: SMG
Great list Mango thanks!
Going down the list, I just ordered #1 from FCP.
Saved $4.35 with the code MangoFCP5
05SMG is offline
Old 08-19-2016, 08:31 AM   #16
Bigc2016
My Ride: 328i
Mango you are the MAN !!
Bigc2016 is offline
Old 08-19-2016, 08:54 AM   #17
WDE46
My Ride: '13 128i STX
I think the FCABs should be higher. Originals are ALL shot at very low miles.
WDE46 is offline
Old 08-19-2016, 09:02 AM   #18
orb
My Ride: 325Ci
Definitely agree with the final stage resistor being up there. Mine failed completely a few years ago in hurricane like 90+ degree Florida weather. Cabin felt like a rainforest and the windows were fogged almost entirely. Not fun.
orb is offline
Old 08-19-2016, 09:04 AM   #19
wallaby13
My Ride: '05 ZHP 6MT
The link for the FCAB is wrong unless FCP has the picture wrong...
Didn't know the FSR was that cheap or else I would have ordered one already.
wallaby13 is offline
Old 08-19-2016, 09:07 AM   #20
Nate323Ci
My Ride: 323 Ci
Great thread. I've had 5 out of the 10 fail. Expansion tank just blew up yesterday while in the drive thru lane. Not a fun experience.
Nate323Ci is offline
Closed Thread
e46 parts, maintenance
