Bombshell - Shark Injector on 330i ZHP Loses Power - Dyno Proven - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 5 votes, 2.60 average. Display Modes
Old 10-24-2017, 04:21 PM   #1
zander271
My Ride: 6spd ZHP/5sp XI
More information to come.
Old 10-24-2017, 04:30 PM   #2
zander271
Working with TurnerMotor Sport/ECS Tuning, hopefully this nightmare gets resolved. (Not resolved) DO NOT WASTE YOUR MONEY
First before I start I would like to go over a few things. This review/data I am giving out only pertains to 330i ZHP or 330's running MS45.1 software.
My car is a 2003 330i ZHP 6 speed manual
Claims of from Turner Motorsport are the following from their website.
This year I decided to kickstart my NA build and had a baseline dyno done at a local tuning shop. My car is stock.
Here are my first 3 baseline pulls. (Ignore that blip my foot slipped for a second on the first pull)
1 - 194 WHP/191WTQ
2 - 194WHP/195WTQ
3 - 197WHP/198WTQ
Fast forward and I purchased the Shark Injector a few months ago, when it popped up on sale.
I installed the software following the directions to the letter. The lights on the Shark Injector confirmed the install was successful. My first impression post install were "meh". I felt no change in power, throttle response felt the same, and for some reason the redline was not changed (Hmmm). My first thoughts about all of this was maybe I was expecting too much. The claim of 14hp/11tq is only a 7% increase in power which is small enough that you won't feel it. Most of the time people won't feel a power bump unless its 10%+. So I was like "ok" let's get this on the dyno (same exact dyno, same exact settings, same gas, tire pressure, everything was the same period) so I can see the increase and get on with the rest of my built. I was expecting a bump of 8-9WHP what the dyno told me was shocking. I lost power (WTF) and low and behold the redline didn't change, had anything for the Shark Injector(MS45.1) worked it would have changed to 6920k.
4 - 189 WHP/192WTQ
5 - 190WHP/190WTQ
6 - 186WHP/192WTQ
Note: Airfuel ratio is missing from the first pull. They didn't have the sniffer connected
It's always great to see lower numbers from a tune
My next move while I was at the same dyno session was to remove the Shark Injector tune per the instructions given with the unit. It takes about 10-15 minutes to remove, again the device confirmed removal of the software.
Guess what...I gained power back with the stock BMW tune. You could also say there was no change, but it's it a far cry from the 14hp/11tq Turner Motorsport has on their website.
7 - 191 WHP/196WTQ
8 - 193WHP/193WTQ
9 - 186WHP/190WTQ
So lets break this down, here is what the Turner MotorSport website says Shark Injector(MS45.1) will improve.
Unlock the torque and horsepower - Loss of power/No gain
Smoother engine with less hesitation - No change
Improved Throttle response - No change from stock
Rev Limit increased to 6920 - Nope mine was at 6840
Installs in minutes - Yep, that was normal
Note: I was running OBDFusion on a pull down the street testing the new Rev Limitor and found this little nugget. That's me hitting the redline with the Shark Injector Installed on my car.
So Turner Motorsport/ESC Tuning has cost me $265 dollars in wasted dyno time. They have my receipts as proof.
My advice would be to not purchase the Shark Tune for a MS45.1 330i or 330i ZHP save your money. Not only will your time and money be wasted on a dyno, but Turner Motorsport/ECS Tuning is not willing or able to rectify the problem. I need to be repaid in full for my wasted dyno time period. Turner Motorsport/ECS Tuning should pull the product off their website and stop selling it so that others don't make the same mistake I did.
It gets better not only did they say I would be given store credit(Which is a total joke) for my wasted dyno time but now because of this post they are only willing to give me $165 out of the $265 I paid. The only silver lining is I did get my money back for the tune itself. If you purchased the Shark Injector tune and have not used it I would call back today and get your money back.
Old 10-24-2017, 04:52 PM   #3
kaLinski
My Ride: 2003 325i
Subbed for the madness & I want to see proof.
Good luck to you.
2003 325i, 200K mile club.
kaLinski is offline   Reply With Quote
Sponsored Links
Advertisement
Old 10-24-2017, 04:53 PM   #4
jfoj
My Ride: 330CiC, M5, X5, E93
Did you ever flash the DME with the most current BMW firmware before installing the Shark Injector??
Do the folks using the dyno have the ability to overly the ignition timing curve on the HP and Torque curve? If they did, they might be surprised what they find!
Solve your misfires, lean codes, rough idle -
Fuel pump failures -
Temp Info -
Hidden OBC Menu - Check Voltage, Temp, Fuel Level -
E46/E39 GM5 Door Lock Info -
Old 10-24-2017, 05:05 PM   #5
e46fan4life
My Ride: E46 330ci 2001
Good luck to you.
me too
e46fan4life is offline   Reply With Quote
Old 10-24-2017, 05:23 PM   #6
SCain
My Ride: 2002 330i
SCain is offline   Reply With Quote
Old 10-24-2017, 05:24 PM   #7
Captain_BMW
My Ride: 330i
You posted a title, but you have made no comments about your claim..
I dont believe this is true!
Why didnt you post pictures of your dyno runs? Etc.
Captain_BMW is offline   Reply With Quote
Old 10-24-2017, 05:56 PM   #8
showda711
My Ride: 2004 330i ZHP
showda711 is offline   Reply With Quote
Old 10-24-2017, 06:44 PM   #9
Sakebomb
My Ride: 330ci
Dat Click bait yo..
Sakebomb is offline   Reply With Quote
Old 10-24-2017, 07:11 PM   #10
My Ride: Lexus
Loses power in a particular range? or in totality. Either way, I believe it. I drove a friend's before with it and didn't notice a difference. I'd rather splurge on a new set of caliper, clutch pedal, and brake pedal bushings.
Complete E46 Info 5.7M VIEWS
Old 10-24-2017, 08:40 PM   #11
mtnbimmer
My Ride: 325xi
Not sure I'd call this a 'nightmare' although I didn't pay for the software either. You've been on here long enough to know that software gains on this car/motor are minimal at best. Do you have a stock motor or have you made other mods? Did you inform TMS/ECS if you made any mods? As you know, Jim Conforti has been doing this a long time and is well respected with results to prove it but if he doesn't know what he is starting with the results can be less than desired.
Hope you get it dialed and please provide the dyno results so we can all see what you are seeing.
mtnbimmer is offline   Reply With Quote
Old 10-24-2017, 08:55 PM   #12
Silverdogz
My Ride: '02 330Ci, '04 330i
Year: 2004
Model: BMW 330i ZHP
Transmission: Manual 6spd
You'd better back up these claims man. You can't go around pulling this without some dyno printouts.
DSC MK60 Replacement and INPA Install:
Silverdogz is offline   Reply With Quote
Old 10-24-2017, 09:56 PM   #13
thereem
My Ride: 330xi. kenworth t680
Yea, need more info, just post the dyno sheets since you have them.
Or maybe the software didn't flash. Did you buy a used one?
thereem is offline   Reply With Quote
Old 10-24-2017, 10:01 PM   #14
jfoj
Dyno results can be misleading at best without back up data.
I would want dyno results with the following overlaid: Ambient Temp, Humidity, Intake Air Temp, Engine Coolant Temp and Ignition Timing. IMHO without at least these items, I would say even a few pulls from the same session could vary and if the additional data is available then this could help explain variations.
I also do not like A-B comparisons from different days on the dyno.
Lots of variables that need to either be controlled and/or corrected for or to at least understand the different conditions the tests were performed under.
As for using the Shark injector, you REALLY need to update the stock DME software to the latest DME software BEFORE using the Shark injector. BMW has screwed up ignition timing Maps for the original DME flash and tools like the Shark injector tweak the timing stock ignition timing Map, so understand that Garbage In = Garbage Out!!
Temp Info -
Old 10-24-2017, 10:12 PM   #15
e46fan4life
I bought my shark injector less than 45 days ago, it is new, I would like you to confirm me before I install it. Maybe it's a problem with your vehicle and not the shark injector?
Old 10-24-2017, 11:11 PM   #16
TobyB
My Ride: 2004xit, 2001ci
Not so much of a bombshell. More of a mild 'really'?
...followed by silence....
t
TobyB is online now   Reply With Quote
Old 10-24-2017, 11:34 PM   #17
Geo31
Ironman
My Ride: 98 M-Z3/01 330iT 6MT
Indeed. Lots of variables. Even how the car is strapped down can make a difference. I'd assume only being a software change the car never left the dyno. It's important that the fluids all be at operating temp.
I'm going to assume all things were done right and suggest we all need to wait for things to play out. TMS/ECS are involved, so while this thread may be premature, let's not go off half-cocked. Lots of stuff needs to be divulged, including the stuff j posted.
George Roffe
Swim: 2.4 Miles
Bike: 112 Miles
Run: 26.2 Miles
Brag: For the rest of your life
Geo31 is offline   Reply With Quote
Old 10-30-2017, 03:55 PM   #18
TurnerMotorspt
My Ride: BMW F82 M4
Zander sorry the Shark Injector software hasn't performed near your expectation. We've extended a refund and hopefully, our other gracious offers will help ease the issues you ran into.
TurnerMotorspt is offline   Reply With Quote
Old 10-30-2017, 04:02 PM   #19
e46fan4life
Huh ? wtf is this ?? Zander did you create this fake account or what ?
Old 10-30-2017, 04:19 PM   #20
paraklas
paraklas's Avatar
My Ride: B30_TS2++
Year: 2001
Transmission: 5-Getrag
Originally Posted by SCain View Post
This thread is on countdown to getting locked i think..
