More e36 parts on my xi, LCABs - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
E46 Xi Forum
Old 05-28-2018, 08:13 AM   #1
mtnbimmer
My Ride: 325xi
the Fly made up a set of these for me last summer and I have been running them since then. No 'night and day' difference but a nice little tweak to pick up some caster. I like the ride of rubber vs. poly for a daily driver.
I must be lucky since it appears that almost everyone else has problems removing/installing the lollipops. Using a ratcheting wrench I've had no problems with mine.
mtnbimmer is offline   Reply With Quote
Old 05-28-2018, 01:23 PM   #2
jmo69
My Ride: 03 325xi 98 328is
Year: 2003
Model: 325xi
Transmission: Steptronic
Took the test drive, and like mtnbimmer said, there was no night and day difference other than the brake shake is pretty much gone. These are the ones I used. https://www.fcpeuro.com/products/bmw...3-31129069035l and they are M bushings, not non as I stated in the original post, corrected that too. Pic of the bushings
Alternative to expensive xi control arm bushings https://forum.e46fanatics.com/showthread.php?t=1231503
Bad outer xi ball joint? https://forum.e46fanatics.com/showthread.php?t=1127077
2003 325xi auto Stahlgrau
1998328is 5sp
jmo69 is offline   Reply With Quote
Old 05-28-2018, 02:05 PM   #3
SaberLily
My Ride: E46 xi
Year: 2001
Model: 325xi
Transmission: MT
No troubles here with a plain ratcheting wrench. My Gearwrench XL wrenches were even better with extra leverage, cleared the subframe and body with tons of swing room.
SaberLily is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-29-2018, 08:45 AM   #4
jmo69
Year: 2003
Model: 325xi
Maybe I should have tried to access all the bolts from underneath, I didn't have the car lifted very high when I did the right side. From the outside I could barely get 2 clicks out of my Gearwrench.
1998328is 5sp
Old 06-11-2018, 12:41 PM   #5
jmo69
Year: 2003
Model: 325xi
Got an alignment today, toe was off front and rear.
Sent from my SM-G950U using Tapatalk
1998328is 5sp
Old 06-11-2018, 12:44 PM   #6
jmo69
Year: 2003
Model: 325xi
Pics wont load
1998328is 5sp
Old 06-11-2018, 10:28 PM   #7
jmo69
Year: 2003
Model: 325xi
I'll try the pics again. I was hoping the first picture of before and after would have turned out clearer, maybe I should have got a printout.
ID:	746110   Click image for larger version
ID:	746112   Click image for larger version
ID:	746114   Click image for larger version
1998328is 5sp
Old 06-12-2018, 07:23 AM   #8
mtnbimmer
My Ride: 325xi
Looks like the e36 FCAB's had a minimal effect on the caster (1/2 deg. ?)
Old 06-13-2018, 01:55 PM   #9
jmo69
Year: 2003
Model: 325xi
Seems that way, I was more concerned about toe, and he did all the adjusting on the right side. Not the side with the weld nut missing, go figure.
Sent from my SM-G950U using E46Fanatics mobile app
1998328is 5sp
Old 09-19-2018, 09:56 PM   #10
jmo69
Year: 2003
Model: 325xi
Could have sworn there were more posts in this thread, like my thread starter, wtf?
1998328is 5sp
Old 09-19-2018, 10:03 PM   #11
jmo69
Year: 2003
Model: 325xi
I had a few pics at least.Click image for larger version
ID:	755893Click image for larger version
ID:	755895Click image for larger version
ID:	755897Click image for larger version
1998328is 5sp
Old 09-23-2018, 03:26 PM   #12
jmo69
Year: 2003
Model: 325xi
Just put the same bushings on new control arms for forum member Yuh. Getting easier each time. His old bushing were still intact, liquid every place once I started cutting them out. Ball joints were loose, 132K on the car, he says steering feels tighter.
1998328is 5sp
Old 09-23-2018, 07:47 PM   #13
Yuh
Thanks for the help!!!
Car is driving great.
Yuh is offline   Reply With Quote
Old 11-02-2018, 03:36 PM   #14
E46 my favorite
I clicked on the link for the part listed in post #2. The description listed for the part on the FTP website is for a non-offset bushing. The later 96' up M3's went back to a traditional 'center' style bushing. To make sure I understand, was your bushing a 'center' style bushing? If this is the case then there should have been no impact to caster.
E46 my favorite is offline   Reply With Quote
Old 11-05-2018, 05:46 PM   #15
jmo69
Year: 2003
Model: 325xi
I used a centered bushing, the stock xi bushing is offset.
1998328is 5sp
Old 03-03-2019, 03:04 PM   #16
jmo69
Year: 2003
Model: 325xi
This is the centered bushing installed in the xi carrier.
1998328is 5sp
