Help! Can't Remove Spark Plug #3! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 06-28-2018, 01:10 PM   #1
2001Silver330CI
My Ride: 2001 BMW 330CI
Year: 2001
Model: 330Ci
Transmission: Auto
I was changing my spark plugs today because of two things: Running rough and they are at least 5 years old with 100k. I got them all out except number 3. It gets tighter when I try to remove it and it feels like the racket is going to snap. What should I do?
See the pictures of the plugs I removed below.
ID:	747516   Click image for larger version
ID:	747518   Click image for larger version
2001 BMW 330 Ci - Production 10/00
* Saleri Water Pump & Wahler Thermostat - 1/19
* Bilstein Touring Shocks/Struts - 8/18 & 12/18
* Meyle FCAB - 9/18
* BMW CCV - 7/18
* Rebuilt DISA using GAS Kit w/Fluoro O-Ring - 3/18
* Upper/Lower Air Intake Boots - 3/18
* Front/Rear Textar brake pads and Meyle rotors - 11/17
* Behr radiator, BMW expansion tank, hoses - 6/15
* Polk Audio db651s speakers
* Electric Fan Swap (CoolXpert)
2001Silver330CI is offline   Reply With Quote
Old 06-28-2018, 01:16 PM   #2
Spannerhead
My Ride: '02 330i/5 slicktop
Does it turn at all? Is your spark plug socket 6- or 12-point? Have you tried soaking it with a penetrant like PB Blaster?
Current:
Past BMWs:
Past Other: '85 GSL-SE '88 JZA70 '86 4K quattro '85 RX-7 S '85 RX-7 GSL
Spannerhead is offline   Reply With Quote
Old 06-28-2018, 01:16 PM   #3
kevinpereira79
My Ride: 2002 e46 325i stick
Those spark plugs don't look good man. I think you might have a serious problem. Also, it sounds like the spark plug is seized. Try tightening it back in a little and then twist it out further. If that doesn't work, well then maybe it's better to just leave that spark plug be. If you want to continue loosening it then I'd suggest a long breaker bar. Just keep going until it's out. Don't use a small ratchet.
kevinpereira79 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 06-28-2018, 01:17 PM   #4
kevinpereira79
Spanner, I don't think he should be trying pb blaster in this situation, because it's going to get into the cylinder, and we don't want that getting into the cylinder.
Old 06-28-2018, 01:26 PM   #5
Spannerhead
Per his previous thread, he is battling a misfiring issue. Otherwise the spark plug look like most plugs that haven't been touched for 100K...
Why not? It's combustible and will burn off in about 2 seconds once he starts the car.
Current:
Past BMWs:
Old 06-28-2018, 01:35 PM   #6
2001Silver330CI
Year: 2001
Model: 330Ci
Transmission: Auto
It moved a little, but got tighter. I almost felt like something was going to break if I kept going.I'm using a 3/8" medium ratchet with a 6 point 5/8" spark plug socket.
ID:	747528   Click image for larger version
* Meyle FCAB - 9/18
* BMW CCV - 7/18
Old 06-28-2018, 01:36 PM   #7
2001Silver330CI
Year: 2001
Model: 330Ci
Transmission: Auto
Here is the troublesome plug!
* Meyle FCAB - 9/18
* BMW CCV - 7/18
Old 06-28-2018, 02:03 PM   #8
MJC12
My Ride: 2001 330i
Transmission: 5 Speed
When you try to loosen it counter-clockwise it feels like it's tightening? Obviously that shouldn't be the case, it's a standard thread like the other 5 you already did.
I'm thinking maybe it was cross threaded when it was installed so many miles ago and it's not going to thread out nicely. You can just try to apply more force and it'll probably come out but it'll likely destroy the threads in the process. Not sure what other option there is.
You probably know it's important to hand thread the plugs before you start torquing them because cross threading with the E46's aluminum head is not fun.
2001 BMW 330i
2004 Subaru FXT
MJC12 is offline   Reply With Quote
Old 06-28-2018, 02:26 PM   #9
b3m4
My Ride: E46 323i 99(Dec/98)
Year: 1999
Model: 323i
Transmission: Auto
What about putting a little ATF oil on it. I doubt it will hurt anything. ATF penetrates really well. I'd put some oil on it and wait at leastan hour maybe 2. Let it penetrate. Even if cross threaded will help. People use ATF to clean engines... It dissolves burnt residue! It can reduce torque required by 20 to 30 ft-lbs.
b3m4 is offline   Reply With Quote
Old 06-28-2018, 02:43 PM   #10
bmwbob89
My Ride: M-5 325 X3 528 740
Tighten it and drive the car. See if your faults are coming back. If you continue you may be pulling the head to fix the problem.
bmwbob89 is offline   Reply With Quote
Old 06-28-2018, 02:50 PM   #11
b3m4
Year: 1999
Model: 323i
Transmission: Auto
Don't underestimate penetrating oils and ATF oil. They work extremely well! I would not try this dry. They will only penetrate to half or 3/4 of the threads. I don't think you need to worry about these oils.
Old 06-28-2018, 03:20 PM   #12
Sapote
My Ride: 2000 323i auto wagon
don't use the ratchets wrench but a solid bar (as breaker bar) instead, then just go CW and CCW, back and forth until the movement increased, but don't force it too much or it might break.
Sapote is offline   Reply With Quote
Old 06-28-2018, 04:17 PM   #13
Spannerhead
Originally Posted by 2001Silver330CI View Post
Do I use some PB Blaster penetrating oil and go back and forth with a breaker bar? I have a 1/2" breaker bar and my socket is 3/8" so I would need to use an adapter. Is that an issue?
It's only an issue if you're trying to torque/remove a fastener with much higher limits (think: suspension) than a spark plug. The advantage of a breaker bar over a ratchet for the kind of back-and-forth rocking movement you'll be putting on the spark plug is that you won't have to constantly keep switching the ratchet from "loosen" to "tighten" as you rock.
Current:
Past BMWs:
Old 06-28-2018, 04:18 PM   #14
b3m4
Year: 1999
Model: 323i
Transmission: Auto
That's the right approach but make sure you use penetrating oil. Don't even try without it. I don't get why you would even consider not using penetrating oil considering the risk.
Old 06-28-2018, 04:32 PM   #15
2001Silver330CI
Year: 2001
Model: 330Ci
Transmission: Auto
Cool! I will use penetrating oil. Let it soak overnight?
* Meyle FCAB - 9/18
* BMW CCV - 7/18
Old 06-28-2018, 04:48 PM   #16
All2kool
My Ride: 2002 325Ci
It won't hurt but a warm head is an expanded head. As per the previous post, drive the car and then try to remove it from a warm engine.
When I changed my plugs, I found one plug was difficult to remove. After I had them all out, I saw that one of the plugs was missing the washer. Yep, it had never been on in the first place. It had fallen off when the plugs were put in and was jammed against the plug well.
Previous:
All2kool is offline   Reply With Quote
Old 06-28-2018, 05:48 PM   #17
Silver02
My Ride: 2002 325i
^X2
Heat + penetrating oil are your friends in general for seized parts. Good luck.
Silver02 is offline   Reply With Quote
Old 06-28-2018, 06:09 PM   #18
2001Silver330CI
Year: 2001
Model: 330Ci
Transmission: Auto
Do I let it just for 15 minutes or do I need to drive it? I don't feel like putting it all back together again.
* Meyle FCAB - 9/18
* BMW CCV - 7/18
Old 06-28-2018, 06:12 PM   #19
All2kool
My Ride: 2002 325Ci
Warm is warm, it won't know you didn't drive it.
Previous:
Old 06-28-2018, 09:19 PM   #20
Sapote
Hot head has soft aluminum threads!!! Beside the plug also expanded too, so gain is little but risk is high of softer threads. If you like, fire it up for 5 minutes idling, wait for 5 minutes then work.
