More M54B30 Turbo for the Masses - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-13-2019, 04:18 PM   #1
CarbonZHP
Because Race...Convertible?
CarbonZHP's Avatar
My Ride: goes choo choo
Year: 2004
Model: 330Cic ZHP
Transmission: AT->5MT->6MT
Here is another thread on turboing the M54 motor on the cheap for the masses. Now, this is still not cheap, but it is less than the 7k that companies ask for the whole package.
The goal here is just above E92 M3 power, so we are targeting 380-400 whp on dynojet. The car currently dynos at 230whp.
We are now making 407 whp and 375wtq on 11psi, pure ethanol E85. AC was lost sadly
Here's the car now
Turbo Build Thread
Original Car: Silver Grey on Grey, A/T (1 of 186)
As it sits: Silver Grey on Black, M/T (1 of 51)
Instagram: @CarbonZHP
CarbonZHP is offline   Reply With Quote
Old 01-13-2019, 04:25 PM   #2
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
COST BREAKDOWN
As always, the cost will never end and there will be more down the line. Heres my build cost including very nearly everything.
  • Turbo (Used) - 200
  • Manifold, Downpipe CXRacing - 750
  • Wastegate, TIAL 38 (Used) - 180
  • BOV - 32
  • Rest of exhaust
    • V Bands - 13
    • Varex Muffler (Used) - 190
    • Flanges and gasket - 34
    • Vibrant Ultra Quiet - 88
    • Pipe - 112
    • Tips - 70
  • Intercooler piping
    • 2.5 inch kit - 95
    • 3 inch 45 - 18
  • 2 to 2.5 inch 45 - 12
  • Maf and pigtail
    • Maf - 210
    • Pigtail - 24
  • Boost controller/gauge AEM Truboost (Used) - 150
  • Innovate LC2
    • Kit (Used) - 100
    • New Sensor - 56
  • BavAuto Coil Packs - 270
  • Spark Plugs BKR7E 4644 - 21
  • Turbo Fittings
    • Braided feed line, banjo adapter - 57
    • AN to turbo flange - 13
    • Turbo Drain Flange - 10
    • Drain line w/adapters - 30
  • Turbo Blanket - 22
  • Heat wrap - 13
  • Intercooler CXRacing - 100
  • TurboGuard - 50
  • Injectors (Used) Bosch 0280158298 x8 - 200
  • Fuel Pump - 79
  • Tuning - 200
$3399
Turbo Build Thread
Old 01-13-2019, 04:26 PM   #3
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Building and results
Turbo Build Thread
Sponsored Links
Advertisement
Old 01-13-2019, 05:20 PM   #4
armenh7
My Ride: 2002 325i
I'm going turbo too. Nice! https://drive.google.com/folderview?...cW4EUbBIxfDELn. I'm using my B25 to learn how to turbo and will swap in a fully rebuilt B30 made for boost when I've gained the experience and knowledge
armenh7 is offline   Reply With Quote
Old 01-13-2019, 05:34 PM   #5
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Yup this will be a daily driver build with occasional autox/track use. Ive been playing with MS43 on TunerPro for a while but I'll go ahead and leave the real work to the professionals. All hardware work done will be by me at EAS (where I work), so I am keeping downtime to an absolute minimum. If necessary I will remove the wastegate spring until we can tune as I only live 3 miles from work.
Turbo Build Thread
Old 01-14-2019, 02:00 AM   #6
d_cleverzz
My Ride: Manual 2001 330ci
Year: 2001
Model: 330CI
Transmission: 5 Speed Manual
Iím assuming this is a top mount setup... why air to water intercooler?
IN SEARCH OF
CONVERTIBLE INTERIOR CARBON FIBER OR PIANO BLACK TRIM
ORIENT BLUE M3 VERT FRONT BUMPER
ORIENT BLUE VERT PRE-FACELIFT FRONT FENDERS
d_cleverzz is offline   Reply With Quote
Old 01-14-2019, 05:03 AM   #7
VitalyZHP
Ukrainian
My Ride: 04 330CI
+1, why aren't you going with fmic?
VitalyZHP is offline   Reply With Quote
Old 01-15-2019, 09:24 PM   #8
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
To keep AC requires extensive relocation. Nearly everyone deletes ac. This should allow it to stay
Turbo Build Thread
Old 01-16-2019, 01:00 PM   #9
cwarel
My Ride: 330ci coupe
From cx racing I suggest just getting the manifold , because their downpipe is 2.5 inch and it fits like sht and the pipe after downpipe sit waaay too low and will be scraping in the ground ( i had 1 inch of clearance) , I threw mine out and bought mandrell bent pipe 3inch and to make a downpipe it took me 45 degree bent and a little straight piece and it fits perfect , although i still have their bottom pipe but since i redid my downpipe it got it to sit much higher ( but the flex has been destroyed so i might redo that part too) , then the problem with my turbo which is gtx3582r is that it has 4 inch intake port and there is no way you can fit a filter on it without cutting stuff out , I did bought a filter and a turbo guard I took the filter part from the housing and put it over the turbo guard but that killed the performance by a lot , and I can see that filter got black in 1 week driving the car which means it sucks a lot of dirt So filter is a must , I just dont know how to run at this point because I need someone to custom make the pipe to go from turbo to the other side of the engine 4 inch to 3 inch with a sharp turn.
I had ac with cx racing manifold , I had to bend the ac lines a bit to get them off manifold because they were touching , moved it away half an inch , although I fcked up because the v band clamp from turbo rubbed through the rubber portion of ac line and it exploded on the road and the car shut off in the middle of the traffic in nyc , but a simple restart got me going tho))) Then i just deleted the ac cuz im a ***** i guess and drilled the block where ac was sitting for a turbo drain , because i had problems with drain line getting cooked from the heat and cracking , so I tapped the the drain hole( aluminum piece ) and ran 6 inch brass line from pluming store straight to the block with a little be of rubber in between to compensate for movement
cwarel is offline   Reply With Quote
Old 01-17-2019, 01:51 PM   #10
d_cleverzz
Year: 2001
Model: 330CI
My understanding is that the turbo itself sits in the way of the AC lines. So they would need to be rerouted. And Iíve seen only very little success with this, and I mean VERY LITTLE with no details. Iíve decided to go bottom mount just like armneh7. I guess weíll see how this goes lol
IN SEARCH OF
Old 01-17-2019, 02:18 PM   #11
cwarel
Id say if you brave enough to bent a/c line at the compressor jsut to get them out of the way you be alright , but issue is running a drain to the oil pan with top mount , ive tried timing covers but i didnt find them efficient enough because everything is in the way
Old 01-17-2019, 02:19 PM   #12
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Already bent the ac lines. Easy. And I'm draining to the drain plug
Turbo Build Thread
Old 01-17-2019, 08:06 PM   #13
armenh7
My Ride: 2002 325i
Me too. I bought my "adapter" (M12x1.5 to -10AN) from treadstome performance. What about you?
Old 01-17-2019, 08:07 PM   #14
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Either that or a barbed adapter
Turbo Build Thread
Old 01-19-2019, 03:58 AM   #15
jdjg
My Ride: e39, m52tub30
Year: 1999
Model: e39
Transmission: Manual 5 speed
how you made 230 WHP in a m54b30 without Force Induction?
jdjg is offline   Reply With Quote
Old 01-19-2019, 09:33 AM   #16
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Good tune. Headers, Intake, zhp cam
Turbo Build Thread
Old 01-19-2019, 10:38 AM   #17
armenh7
My Ride: 2002 325i
Please don't get an ebay wastegate. That's the one piece (along with boost gauge and wideband) that I am willing to spend big money on. A bad wastegate could either blow your engine or prevent you from making boost
Old 01-19-2019, 08:56 PM   #18
DBAMF
I have the exact same problem with a cx manifold and a 4 inch inlet. I am having a really hard time making any kind of filter work.
DBAMF is offline   Reply With Quote
Old 01-19-2019, 09:22 PM   #19
332
My Ride: 332
Contact AFE, they will make you any filter you can afford. I have had several made and they are perfect. https://afepower.com/build-your-own-filter here is the link that allows you to make everything custom https://afepower.com/build-your-own-filter/contact
332 is offline   Reply With Quote
Old 01-21-2019, 10:08 PM   #20
CarbonZHP
CarbonZHP's Avatar
Year: 2004
Model: 330Cic ZHP
Intercooler arrived and i picked up injectors Bosch 0280158298. Still need the manifold, downpipe, oil feed and drain, and bov. Wideband going in this week
Turbo Build Thread
