Vaccum leak codes - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Go Back   E46Fanatics > BMW News from around the Web
Submit the latest BMW news from around the world for other E46Fanatics members to check out.
Old 01-21-2019, 02:14 PM   #1
Jasonkirrane
Vaccum leak codes
Did a smoke test and found smoke leaking from a place that's meant to have a vacumm hose I assume as loads of smoke bellowing out but don't seem to see a hose to put on it. Any ideas conversion to a 325 so wonder was pipe not put in.photo attached of pipe it's at back of engine under where micro filter is behind where intake boot.
Jasonkirrane is offline   Reply With Quote
Old 03-01-2019, 06:26 PM   #2
Superkeith76
My Ride: 01 E46 99 E39 Wagon
There's a vacuum cap that goes there. There's also 2 smaller ports back there. If there's a valve on the back of the intake next to it then it should hook up to the smaller port if not just cap them off
Superkeith76 is offline   Reply With Quote
Old 03-01-2019, 06:53 PM   #3
Ettinger
My Ride: 4 doors, 3 pedals
You are missing a cap. Secondary air issues are discussed here. If these vacuum lines are original, replace them:
https://forum.e46fanatics.com/showthread.php?t=1246105
https://blog.bavauto.com/12072/bmw-s...to-diy-obd-ii/
Ettinger is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-18-2019, 09:38 AM   #4
Archbid
My Ride: 330ci Convertible
Year: 03
Transmission: 5-Speed Manual
Good pictures here https://forum.e46fanatics.com/showthread.php?t=1074573
Archbid is offline   Reply With Quote
