Rough idle/power loss - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-15-2019, 12:36 PM   #1
McG5592
Hi all,
Although this is my first post, I have been using this site as a reference for a while now!
I have a 2002 318ci (n42 engine) automatic.
Iíve got an issue thatís now really bugging me!
The problem started about 2 weeks ago when my alternator packed up whilst driving home along the m6. Before this I havenít had any issues with the car apart from a small oil leak which Iíve been meaning to sort (I have a newborn so this stuff has been put on the back burner recently).
Car got recovered, took it to the garage who sorted the new alternator for me and got it all fitted. Great, job done. Driving it home, car felt fine and didnít think anything else of it.
The next day on my way to work, the car was really struggling to stay alive whilst waiting in traffic/at lights. On 2 occasions it actually died but started up again first time. I also noticed that pulling out of junctions the car was really hesitant and then would just kangaroo down the road for a a few seconds before kicking in properly and taking off. It does this now in the first few gears, and only seams to happen once the car has warmed up.
Now, Iím no mechanic, but do like to try and find issues and fix them for myself if I can, so looked on YouTube at some videos, read some posts on here and came to the conclusion that it could either be a vacuum leak or bad spark plugs. Iíve now changed my spark plugs and looked at the air intake boot for any potential leaks.
First thing I noticed was at the top of the intake boot there is a slight tear. New boot has been ordered. I also noticed the the massive rubber o ring between the boot and MAF is shredded. So Iíve ordered a replacement part for this too.
Now after changing the spark plugs, there is an improvement on the overall drive, but my issues of a rough idle and the car jumping forward hesitantly in the first few gears still remain. I know Iíd need to wait until my new parts get here to rule out a vacuum leak, but Iím now starting to think this could be a fuel issue?
Thereís a small air release valve on the top of the the fuel rail, and when pushing that in, fuel sprays all over the place. I also ran the car up to the petrol station to put in some fuel (as it was very low and I was rulling out simple options) and literally every couple of seconds the fuel pump would click as if the tank was full!? I tried different positions, and noticed when I was pulling the fuel pump out, fuel was backed up and leaking out before the fuel tank closed again? I know this could be unrelated, but was just very coincidental.
Has anyone else had this issue before? I know thereís lots of threads on here with similar issues, but I just havenít found an answer yet!
I have now check engine lights on my car, and have yet to get it plugged in as I know this alone is going to cost me more money. It will be my next step, but I just wanted to see if anyone could help me in here first.
I do have photos/videos of some of the issues Iíve found, but have not yet figured out how to upload them in here!
Thanks in advance.
McG5592 is offline   Reply With Quote
Old 04-15-2019, 05:10 PM   #2
NZ00Z3
My Ride: 2000 323i
Fit the new parts you have coming. You've done good to find these problems.
Buy a code reader so you can check your codes yourself. Best bet is a ODB2 to WiFi or Bluetooth (depending on your phone) emulator and the ODBfusion app.
Post the codes here so we can help you with the specific faults that they show.
NZ00Z3 is offline   Reply With Quote
Old 04-16-2019, 08:48 AM   #3
markusmarkus
My Ride: 2018 M240i
That ďair release valveĒ is actually a fuel pressure test port! The fuel pressure has to be at least 50psi at all engine speeds and loads. If the gauge (taped to the windshield/windscreen so you can read it while driving) shows anything less the pump is suspect. Also, the fuel filter could be partially clogged.
The problem your having when filling the tank could be any number of things. However, does the problem arise at other gas stations?
Sponsored Links
Advertisement
Old 04-16-2019, 09:23 AM   #4
dmax
dmax's Avatar
My Ride: '16 340i xD 6-spd
Year: 16
Model: 340i
Transmission: 6-spd
Very common for pump click off before the tank is full...especially, it seems, in the summer.
...and your known leaks might well be the cause for your issues...so as mentioned, replace them first and see where you get.
Good luck!
See Facebook for upcoming shows...and listen to my podcast!
Old 04-17-2019, 10:58 AM   #5
McG5592
Thanks all for the input. New parts have been delivered today I think, so will get them fitted tonight and hope for the best for now!
318ci, n42, power loss, rough idle, vacuum leak
Similar Threads
Thread Thread Starter Forum Replies Last Post
Starting problem, EML, rough idle, misfire dubcrazy88 General E46 Forum 23 10-04-2009 09:12 PM
Vitamins to maximize weight loss? e30m3izzle Health & Fitness 27 12-29-2008 11:22 AM
Rough downshift back into 1st dragoncoach General E46 Forum 4 12-26-2008 09:48 AM
I bet she likes it rough... joeski3d General Off-Topic 19 11-15-2008 04:52 AM
Just got car back, now cuts out and hunts (rough idle)? Tom|Nbk General E46 Forum 0 11-10-2008 01:56 PM
