questions on inpa error mem - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-15-2019, 01:10 PM   #1
Maddog71601
My Ride: 99 328i
i keep getting these error on inpa
E R R O R M E M O R Y R E P O R T -------------------------------------
Date: 04/15/19 11:50:32
ECU: MS420DS0
JobStatus: OKAY
Variant: MS420DS0
RESULT: 10 errors in error memory !-------------------------------------------------------------
0 --
Error frequency : 16
Logistic counter: 40
Warning: F_UW1_NR or F_UW1_TEXT donīt exist in result record 1 !
Warning: F_UW2_NR or F_UW2_TEXT donīt exist in result record 1 !
Warning: F_UW3_NR or F_UW3_TEXT donīt exist in result record 1 !
Warning: F_UW4_NR or F_UW4_TEXT donīt exist in result record 1 !
Warning: F_UW5_NR or F_UW5_TEXT donīt exist in result record 1 !
Errorcode: 00 E4 10 28 00 8B B3 1E B1 3D
55 avtivate Lambda probe heating before KAT Bank 2
Error frequency : 2
Engine speed 768.00 1/min
load 125.28 mg/Hub
lambda probe voltage control probe Bank 0.42 V
temperature cooling water 88.50 Grad C
appear before (rel.) 0.20 h
Leitungsunterbrechung
CARB-Fehler
Fehler nach Entprellung gespeichert
Fehler momentan vorhanden
sporadischer Fehler
Errorcode: 37 F4 02 28 18 17 55 B6 B1 3D
25 avtivate Lambda probe heating before KAT Bank 1
Error frequency : 1 Logistic counter: 39
Engine speed 800.00 1/min
load 119.84 mg/Hub
CARB-Fehler
Fehler momentan nicht vorhanden
sporadischer Fehler
Errorcode: 19 B4 01 27 19 16 55 B6 B1 3D
228 lambda contol tolerance Bank 2 to big
Error frequency : 1 Logistic counter: 40
Engine speed 736.00 1/min
load 114.39 mg/Hub
temperature cooling water 66.75 Grad C
lambda contol tolerance Bank 2 26.95 % appear before (rel.) 0.20 h
Abweichung fett
CARB-Fehler
statischer Fehler
Errorcode: E4 71 01 28 17 15 99 C5 B1 3D
68 avtivate Solenoid Valve tank ventilate
load 114.39 mg/Hub
temperature cooling water 67.50 Grad C
tank purge valve - activate 0.00 %
CARB-Fehler
sporadischer Fehler
Errorcode: 44 B4 01 27 18 15 9A 00 B1 3D
203 lambda control Bank 2 control block
Error frequency : 1
temperature cooling water 69.00 Grad C
load 114.39 mg/Hub
lambda probe voltage control probe Bank 0.04 V
Abweichung fett
CARB-Fehler
sporadischer Fehler
Errorcode: CB B1 01 28 18 9C 15 08 B1 3D
8 Signal air flow meter
Error frequency : 4
Throttle-valve angle 7.97 Grad DK
duty cycle Idle adjuster 19.14 %
intake air voltage 0.00 V appear before (rel.) 0.20 h
Signalleitung Kurzschluss gegen
Masse oder Leitungsunterbrechung
CARB-Fehler
sporadischer Fehler
Errorcode: 08 B2 04 28 18 11 31 00 B1 3D
14 Signal sensor Intake air temperature
Error frequency : 9
Engine speed 992.00 1/min
load 288.70 mg/Hub
temperature cooling water 16.50 Grad C
temperature cooler outlet 143.25 Grad C
Kurzschluss gegen U-Batt. oder Leitungsunterbrechung
CARB-Fehler
sporadischer Fehler
Errorcode: 0E B1 09 28 1F 35 56 FF B1 3D
242 burning fail Cylinder 5
Error frequency : 1
temperature cooling water 80.25 Grad C
revolution upper limit 768.00 1/min
Airmass upper limit 108.94 mg/Hub
Airmass under limit 103.49 mg/Hub
Verbrennungsaussetzer CARB, KAT-schaedigend
CARB-Fehler
sporadischer Fehler
Errorcode: F2 B1 01 28 AB 18 14 13 B1 3D
243 burning fail Cylinder 6
Error frequency : 1
CARB-Fehler
sporadischer Fehler
Errorcode: F3 B1 01 28 AB 18 14 13 B1 3D ============================================================ =
the first error code i can not find anything one and was also looking for a lil better expination at what im looking at
Maddog71601 is offline   Reply With Quote
Old 04-15-2019, 05:02 PM   #2
NZ00Z3
My Ride: 2000 323i
Looks like a large vacuum leak on bank 2, O2 at 26.95% with misfires on cylinders 5 and 6. Get this fixed first then clear the codes and see what comes back.
NZ00Z3 is offline   Reply With Quote
Old 04-15-2019, 07:31 PM   #3
armenh7
My Ride: 2002 325i
You have vacuum leaks, a o2 sensor heater has failed, maf plug might be bad, air temp sensor not plugged in good. Do a smoke test and change whatever part where smoke comes out of. Clear the codes. Use a generic obd2 scanner and get the P codes. You might need new o2 sensors
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-15-2019, 07:35 PM   #4
Maddog71601
My Ride: 99 328i
Ok I’ve done some digging and traced the wires from Ecu to mass air flow and the ground wire pin 17 on the 52 pin and there is resistance showing is that a reason for the mass air flow
Similar Threads
Thread Thread Starter Forum Replies Last Post
Oil Change related questions Tun3r_N3wb General E46 Forum 9 12-01-2008 11:01 PM
i got rear-ended today..questions about my bumper.. 615bimmerboy General E46 Forum 6 12-01-2008 08:44 PM
New to Photography. General Questions =-) alex1524 Photography 2 12-01-2008 08:42 AM
Back up light and paint questions Jefftc14 Car Care & Detailing 3 11-05-2008 08:07 PM
Questions for Montreal, Canada fanatics Laylow General Off-Topic 8 11-04-2008 07:49 PM
