Reasonable rear rotos and pad - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-15-2019, 03:52 PM   #1
kaankoyun
I have a 325 ci convertible , can you guys give me advise to get rear rotor and pad around 100-120$
kaankoyun is offline   Reply With Quote
Old 04-15-2019, 04:03 PM   #2
RayLivingston
My Ride: E46
Can't help you with rear rotors only for $100, but I can help you with all four rotors, and pads for $88:
https://forum.e46fanatics.com/showthread.php?t=1252347
Regards,
Ray L.
RayLivingston is offline   Reply With Quote
Old 04-15-2019, 04:06 PM   #3
kaankoyun
thank you so much but it is sold out
Sponsored Links
Advertisement
Old 04-15-2019, 05:04 PM   #4
jmo69
My Ride: 03 325xi 98 328is
Check Amazon, a friend got all four for his 330xi for about $120, don't know the seller. Not these but if you're desperate https://www.amazon.com/Callahan-Prem...gateway&sr=8-9
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 04-15-2019, 05:37 PM   #5
fanatichuman
My Ride: 2001 e46 330xi
Go on fcp euro. 2x meyle coated rotors for 40 something each, plus meyle ceramic pads for 30 or so
fanatichuman is offline   Reply With Quote
Old 04-15-2019, 05:50 PM   #6
VpointVick
My Ride: '03 325iT Mysticblau
https://smile.amazon.com/dp/B000BZZQ..._t1_B000BZXS8A
Coated Centric blanks for $26/ea. Pads of your choice and you're still under $100 total.
VpointVick is online now   Reply With Quote
Old 04-15-2019, 06:53 PM   #7
dmax
dmax's Avatar
My Ride: '16 340i xD 6-spd
Year: 16
Model: 340i
Transmission: 6-spd
Just fyi, many rotors, especially in the rear, might take a second set of pads. Have you measured them to see if they're above min. thickness? Mine were only halfway there at around 120,000 miles (in a manual). But, blank Balo rotors have been good for me...and get Textar pads ( OEM maker) at around $80 for rotors (pair) and $40 for pads.
Probably the most important part of your car for safety. Don't buy crappy stuff and don't worry about getting dust on your wheels either. Just saying! Lots of guys more fussy about how their wheels look than how they stop.
See Facebook for upcoming shows...and listen to my podcast!
Old 04-15-2019, 07:23 PM   #8
armenh7
My Ride: 2002 325i
Zimmerman rotors and textar pads from fcpeuro
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
Old 04-15-2019, 07:35 PM   #9
VpointVick
This is true for pads, but there's nothing more to expensive rotors than there is in the cheapest Chinese blanks on the market. They're just chunks of cast iron. Get the cheapest you can find and spend the savings elsewhere.
Old 04-15-2019, 09:26 PM   #10
RayLivingston
My Ride: E46
But they do list the rears only:
https://www.ebay.com/itm/Rear-Brake-...item2869013c6f
If you want the whole set of 4, send them a message, and see if they will list a set. I'm sure they must have them.
Regards,
Ray L.
Old 04-15-2019, 09:36 PM   #11
05SMG
My Ride: E90,F30,F80
Model: O5' 330ci (RIP)
Transmission: SMG
Zimmerman rotors. Pagid or Textar pads. Zero issues.
05SMG is offline   Reply With Quote
Old 04-16-2019, 12:45 AM   #12
jmo69
This is the same basic kit I bought, but mine came with new wear sensors.https://www.ebay.com/itm/Front-Rear-...7d531fdce9b594 About $20 more but they are very sensitive to water. Twice the worn pad light has come on, once after a car wash under body flush and again in the rain. Otherwise they work fine. Won't fit a very though.
1998 328is 5sp
