whistling sound from window at highway speed - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-15-2019, 06:18 PM   #1
Joedigity
My Ride: 2001 330ci
I've got a 2001 330ci that I have replaced just about every single gasket, seal, and rubber part on since I bought it. I replaced the weather stripping on both drivers and passengers doors shortly after I bought the car and it is still whistling like crazy when the windows are completely closed at highway speeds. Does anyone here have any solutions to create a better seal when the window is completely closed? The whistling sound is starting to bug me.
Joedigity is offline   Reply With Quote
Old 04-16-2019, 08:42 AM   #2
markusmarkus
My Ride: 2018 M240i
Do the windows go up that last 1/2 when you close the door? Are you sure the noise is coming from the windows?
Old 04-16-2019, 12:38 PM   #3
Joedigity
My Ride: 2001 330ci
Yes, the windows go up another 1/2" or so when the door is closed. Not sure if the window itself needs to be adjusted or tightened on the track inside the door or what? Yes, it's definitely coming from the window/ seal.
Sponsored Links
Advertisement
Old 04-16-2019, 01:33 PM   #4
Bpat1218
My Ride: 325i Touring 5spd
Year: 2002
Model: 325i
Transmission: Getrag 250g
If you can't tell where it's coming from you could try shimming different areas from the inside to see where pressure is needed to get a full seal
Sent from my Pixel 2 using E46Fanatics mobile app
Bpat1218 is offline   Reply With Quote
Old 04-16-2019, 01:59 PM   #5
TobyB
My Ride: 2004xit, 2001ci
Or use tape to cover things.
Mine had a damaged mirror mount. It didn't really show from the outside,
but when I took it apart, the mounts were bent slightly. A little hammer
and dolly work, a bit of filing of the mirror itself, and it sits back inside
the trim line, and doesn't whistle.
I found it by taping over seams until the noise went away, then
taking the tape off again in the reverse order until it came back.
Yes, it's a pain in the ass to climb over the center console, and yes,
I drove around with tape on the outside of the mirror mount for longer
than I'd care to admit...
hth,
t
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
Old 04-16-2019, 02:24 PM   #6
Joedigity
My Ride: 2001 330ci
Ahh, TobyB, I am almost certain that my mirror mount is damaged. I will take it apart and have a look. Thanks for the feedback.
Old 04-16-2019, 02:27 PM   #7
IceWhite
My Ride: 2004 330i
You can also park your car in the garage, turn on the car to the 1st position (Don't start the car). Turn on the fan on full, step out the car and close the door.
Now while the fan is blowing on the inside of the car and you are outside of the car, you can feel around the window area for flowing air. If it's dead quiet, you might even hear a slight whistle.
Hope this helps!
IceWhite is offline   Reply With Quote
Old 04-20-2019, 03:56 PM   #8
Joedigity
My Ride: 2001 330ci
Hey Ice, I tried your suggestion and could not hear any air escaping around the weather stripping. Hmmm
Old 04-21-2019, 04:40 AM   #9
paraklas
paraklas's Avatar
My Ride: B30_TS2++
Year: 2001
Transmission: 5-Getrag
I treat all rubber seals with silicone grease (or gummy pfledge) and it creates a much better seal as the rubber becomes softer. Cured a similar issue I had with my Opel Astra.
Old 04-21-2019, 05:14 AM   #10
74123
Guest
My Ride: 320i SE Coupe
Could it be coming from the gap between the wing mirror and the A pillar? Tape something in that gap and see if it stops it.
EDIT: Just read TobyB's comment. I used to have an E36 and the part of the wing mirror body that faced the gap had small bumps moulded into it. I asked BMW why they were there and I was rold it was to create turbulence and prevent whistling. So I would focus on the wing mirror.
74123 is offline   Reply With Quote
Old 04-21-2019, 06:56 AM   #11
sefeing
My Ride: 2002 BMW 325i Sedan
Year: 2002
Model: 325i
Transmission: Automatic
Check the black rain gutter trim - this is what caused it for me. The trim can slide forward & create a bad gap / seal. just push it back towards the rear of the car.
sefeing is offline   Reply With Quote
Old 04-21-2019, 07:10 AM   #12
jfoj
My Ride: 330CiC, M5, X5, E93
Try the dollar bill trick and also use a mechanic stethoscope to narrow in on the noise.
Using a dollar bill, roll it up in the window across the window gasket and attempt to pull out the dollar bill, it should not pull out. You will need to re-position and move the dollar bill along the entire edge of the glass and try the same procedure.
This is the stethoscope you need - https://www.amazon.com/Lisle-52500-M...s%2C319&sr=8-1
You remove the plastic transducer at the end of the stethoscope and then you have an open hose that you can move around and search for the noise while driving, a bit tricky at times, do on a deserted section of road for safety reasons.
But also understand you may be chasing the wrong problem. As mentioned trim and other things can cause whistling noise. Blue painters tape to mask off trim around the windshield and other places is a useful tool. Also rule out the brake booster, HVAC fan, climate control head unit fan and DME fan as possible sources of noise.
Solve your misfires, lean codes, rough idle -
Fuel pump failures -
Temp Info -
Hidden OBC Menu - Check Voltage, Temp, Fuel Level -
E46/E39 GM5 Door Lock Info -
Old 04-21-2019, 08:45 AM   #13
jfoj
Not a car window, but same idea, use a dollar bill.
Temp Info -
Old 04-22-2019, 01:19 PM   #14
IceWhite
My Ride: 2004 330i
Ahh crap. I hoped it would help.
Thanks for your feedback/reply.
Old 04-22-2019, 01:57 PM   #15
ctlikon
My Ride: 2005 330Ci Coupe
Year: 2005
Model: 330CI ZHP
Transmission: ZF S6-37
My coupe whistles through the vertical door window seal where the drivers door window rests against the rear quarter window. There is an adjustment inside the door mechanism that tilts the window in and out and also front to back. I haven't fixed it yet but it was evident when I compared the closed position of the window to the passenger side same area. It is right next to the drivers shoulder and ear while you are driving.
Mine leaks at the bottom red arrow area in the pic.
"We at BMW do not build cars as consumer objects, just to drive from A to B. We build mobile works of art." Chris Bangle
ctlikon is offline   Reply With Quote
Old 04-22-2019, 05:05 PM   #16
Alex323Ci
My Ride: M3 & 323Ci (sold)
coupe windows can get out of adjustment over the 10 plus years since there's no frame. i have adjusted my driver's glass and it made a huge difference. there's a DIY out on this.
also as mentoned the coupe (non-M) mirrors have air foils built into them. if your mirror is damaged it might also be the cause of whistle.
Similar Threads
Thread Thread Starter Forum Replies Last Post
Help this~~~ Car has woo sound at low speed and feel folating skipping~~ Rickljc General E46 Forum 16 06-05-2009 04:58 PM
Vibration at highway speed? sam5357 General E46 Forum 18 12-06-2008 01:39 PM
330XI oscillation at highway speed botaman General E46 Forum 3 11-21-2008 04:13 PM
whistling sound when accelerating...? tyler5921 General E46 Forum 3 11-05-2008 06:55 AM
Help! Doing my window regulator but the window was not bolted down! xflashjr DIY: Do It Yourself 1 11-03-2008 01:13 PM
