Difference between Xenon/Halogen Headlight lenses? Anyone know? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-11-2019, 05:57 PM   #1
se93
My Ride: BMW 328ci AW MTECH2
Hi guys,
I am just wondering what the actual difference is between the Xenon/Halogen headlight lenses on the pre-facelift 99-01 E46 coupes.
They look exactly the same and just about 2 years ago i had to replace the lenses of my Xenon lights and purchased a set of aftermarket lenses which were not for a “Xenon” headlight. They fit fine and have not encountered any issues with them until recently the passenger’s side headlight got some condensation after i sprayed water with my garden hose over the RH side edge of the hood and had forgotten the turn signal lens had been removed. I did notice the fastening tabs are very easy to slip off the headlight housing so it may be time to do an inspection of the headlight to see what may be the issue.
Regards,
Mark
se93 is offline   Reply With Quote
Old 09-11-2019, 08:22 PM   #2
Spannerhead
My Ride: '02 330i/5 slicktop
The replaceable plastic cover/lens for the front of the headlight housing is the same between halogens and xenon, AFAIK.
Sounds like the seal between the housing and the lens needs replacement if you're getting condensation.
Current:
Past BMWs:
Past Other: '85 GSL-SE • '88 JZA70 • '86 4K quattro • '85 RX-7 S • '85 RX-7 GSL
Spannerhead is online now   Reply With Quote
Old 09-11-2019, 08:54 PM   #3
se93
The ETK lists different part number for Xenon/Halogen lenses but like you said, they are the same.
I just checked the locking tabs on the other headlight and they do not slide off easily as does the passenger’s side unit. Those seals are the genuine ones, and for a 20 year old car i think the seals have done a fabulous job. Might be time to replace at least the one on the headlight that got condensation.
Regards,
Mark
Sponsored Links
Advertisement
Old 09-12-2019, 03:36 AM   #4
armenh7
My Ride: 2002 325i
Theoretically the xenon ones are thicker to withstand more heat but my halogen lenses survived fine with quad 55W projectors
Not so complicated install of BMW Tools (Windows XP, 7, and 10)
PA Soft
Driver:
Program:
armenh7 is offline   Reply With Quote
