Could having let the battery discharge too much caused my abs issue? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 09-11-2019, 07:39 PM   #1
used2bcrashed
My car (02 e46 325ci) was in a crash and I bought it and repaired it and when I first got it it didn't have an abs light. I pulled the car into the garage and it sat in there for about 3 months as I slowly worked on it each day after school. One day I was doing wiring (had some damages connectors) and I went to start the car and it did the click click thing meaning battery is dead so I charged it. The next time I got it started it had an abs light and bmw scanner 1.4 told me "abs control unit failure". This is listed as red. The only other issue in the abs tab is "battery reached below 9v". Could having let the battery do this screwed up the abs unit? And if so can I reset the abs computer somehow?
used2bcrashed is offline   Reply With Quote
Old 09-11-2019, 08:43 PM   #2
dmax
dmax's Avatar
My Ride: '16 340i xD 6-spd
Year: 16
Model: 340i
Transmission: 6-spd
I got the abs code recently after cleaning the idle control valve and throttle body...freaked me out. I drove about 100 yds. and it went off on its own.
If you haven't driven it yet, don't panic. Having low voltage, or having the wrong things disconnected when you have enough power might be enough to trigger the code.
I don't know what caused mine, but perhaps the abs system takes over control of the throttle when it's active?
See Facebook for upcoming shows...and listen to my podcast!
Old 09-11-2019, 08:53 PM   #3
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Clear the code and drive the car. See if the error comes back.
