ccv return line insulation crumbling - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 12-02-2019, 11:19 PM   #1
wfx32
My Ride: AWD
Model: 330XI 08/2004
Transmission: auto
should i be more worried about the crumbling insulation on the ccv return line? i have found pieces of it everywhere.
wfx32 is offline   Reply With Quote
Old 12-03-2019, 12:45 AM   #2
TR4G-
My Ride: E36/8 3.0i, E46 ZHP
not really. That stuff will crumble way before the line itself becomes compromised. You should be more worried about the lower line off of the oil separator. It's usually the first one to go.
TR4G- is offline   Reply With Quote
Old 12-03-2019, 06:51 AM   #3
RayPooley
My Ride: 320i SE Coupe
If it's not actually leaking I wouldn't worry about it as far as that is concerned but if it's old enough for that stuff to crumble perhaps it's due for a change.
Sponsored Links
Advertisement
Old 12-03-2019, 07:24 AM   #4
wfx32
My Ride: AWD
Transmission: auto
thanks, independent mechanic here replaced the ccv and other lines, but he left that crumbling top line. can’t say i blame him, because when i cleaned and replaced the icv, the ccv and one of the rear port caps fell apart creating massive vacuum leaks.
so now i am not so gung ho about the diy repairs on this old car. but i am working up the nerve to replace the coolant lines under the intake manifold as part of a full cooling system refresh. and replacing the ccv and plastic valve cover with the m56 aluminum cover.
Old 12-03-2019, 07:41 AM   #5
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
I would just remove the insulation. Better off without it IMO.
Old 12-03-2019, 08:12 AM   #6
markusmarkus
My Ride: 2018 M240i
That’s not a return line. It’s a vacuum line.
Old 12-03-2019, 08:42 AM   #7
wfx32
My Ride: AWD
Transmission: auto
Originally Posted by markusmarkus View Post
That's not a return line. It's a vacuum line.
i mean this one: realoem #7 or 11617504536 "return pipe"
*edit: isn't this where the air returns to the intake? with less or more oil depending on whether the ccv is working?
Old 12-03-2019, 08:49 AM   #8
MrMCar
My Ride: M-3 R1150 MCoupe
+1
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Old 12-03-2019, 09:30 AM   #9
66intheSky
66intheSky's Avatar
My Ride: BMW
Year: 2000
Model: 328i ZSP
Transmission: Manual
+2 As long as the hose itself isn't cracked underneath the crumbled insulation, you'll be fine. That one isn't too bad to replace if you go that route, and it's cheap anyway.
66intheSky is offline   Reply With Quote
Old 12-03-2019, 10:09 AM   #10
docnabimmer
My Ride: 2001 Acura 3.2 CL
@wfx- leave it alone until your next valve change , of the CVV lines that I have .the valve will crap out before that line breaks.Don't mind the insulation,just clean debris off that area when you take the manifold off.
docnabimmer is offline   Reply With Quote
Old 12-03-2019, 12:16 PM   #11
Archbid
My Ride: 330ci Convertible
Year: 03
Transmission: 5-Speed Manual
Good lord. Your mechanic isn't touching things because they are too brittle?!
Replace the line. It takes all of five minutes. And replace the caps.
Archbid is offline   Reply With Quote
Old 12-03-2019, 02:35 PM   #12
jmo69
My Ride: 03 325xi 98 328is
Insulation on CCV lines can cause more problems than it solves.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 12-03-2019, 02:56 PM   #13
wfx32
My Ride: AWD
Transmission: auto
i know i was thinking the same thing. as if the cold weather kit wasn’t already a bad idea.
Old 12-03-2019, 02:58 PM   #14
Archbid
Year: 03
One of the ways to make the CCV last longer is to aggressively clean the drainage channels at the bottom of the dipstick. Sadly, you can't just soak it in a solvent, but folks have had success with piano wire. When they back up, the CCV clogs and goes cattywumpus.
Old 12-03-2019, 03:17 PM   #15
wfx32
My Ride: AWD
Transmission: auto
good advice there, because most people will want to make the bmw solution work as designed. and extra points for the use of “cattywumpus”.
Old 12-03-2019, 03:18 PM   #16
Archbid
Year: 03
My favorite kind of "wumpus"
Old 12-03-2019, 03:20 PM   #17
Archbid
Year: 03
A slightly more aggressive solution:
https://www.fcpeuro.com/products/bmw...z4-11437565437
The redesigned dipstick has a different flow channel. I live in SF, so I don't need, but I have read that it has better drainage to lessen odds of backup.
Read more here:
https://www.bimmerfest.com/forums/sh...d.php?t=670651
Old 12-03-2019, 03:31 PM   #18
wfx32
My Ride: AWD
Transmission: auto
wow i didn’t know they came up with a cold climate dipstick tube as well. it’s like the bmw engineers were willing to redesign the whole car rather than give up on their low friction piston rings.
Old 12-03-2019, 03:35 PM   #19
jmo69
My drain channel is capped off, one of the advantages of the M56 valve cover mod.
1998 328is 5sp
Old 12-03-2019, 05:22 PM   #20
Overboost
//Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
Read more here:
Oy vey! $145 for a dipstick tube?
  • To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
The older I get... The faster I was...
No Fear
Overboost is offline   Reply With Quote
