Not the right forum, but i'm asking anyhow - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-13-2020, 04:49 PM   #1
jdstrickland
My Ride: '94 325iC & '00 323i
My neighbor has a 535 (I think it is the F10). He rear ended somebody and killed a headlight. The problem is, the headlight assembly he has has round connector pins, but the replacement part he is finding has flat pins -- round pins vs. spade pins, for lack of a better description. NOT the shape of the connector with rounded or square corners, the actual pins are a different shape. I believe he has zenon with leveling and turning around corners.
My question is, are the pins different to prevent the wrong headlight assembly from being used?
What would be the better forum to go to?
Old 01-13-2020, 05:00 PM   #2
TerraPhantm
My Ride: M3
Could be a facelift vs pre-facelift thing?
Old 01-13-2020, 05:22 PM   #3
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
I would get the VIN and look up the part number on realoem.com, or maybe stop by the dealer parts department.
Sponsored Links
Advertisement
Old 01-13-2020, 06:37 PM   #4
kd7iwp
My Ride: 2001 325i, 2009 535x
You could try 5series.net or bimmerfest.com to get more 5-series specific help.
kd7iwp is offline   Reply With Quote
Old 01-13-2020, 08:37 PM   #5
jdstrickland
The 5 Series 535 has a facelift or not? The headlamp fits, he said, but the connector is wrong.
My question is if anybody knows why the connector pins change...
Old 01-13-2020, 08:46 PM   #6
TerraPhantm
My Ride: M3
Yes there was a facelift. Pretty much every BMW since the 90s has had a facelift mid production.
Old 01-13-2020, 10:07 PM   #7
jdstrickland
Okay, but the shape of the connector pins would not be the red line in the sand where one headlamp can be used but another cannot. The issue I'm trying to understand is, why are the pins inside of the connector a different shape?
Old 01-13-2020, 10:13 PM   #8
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
I donít think youíre getting the point here. The headlights likely changed between pre- and post- facelift, and hence different connectors. Get the VIN and look them up on realoem.
Old 01-13-2020, 10:53 PM   #9
jdstrickland
I'm clearly not getting it, the shape of the headlamps would prevent them from being used, without regard to the shape of the pins inside of the connector. Pre- and post-facelift would not play a role here. Pre- and post-facelift are certainly an issue, but my question is not related to that. Assume, for the sake of conversation that the car has some level of lamp, pre-facelift. Would the shape of the connector pins prevent the incorrect type of headlamp (also pre-facelift) from being used?
If you don't know, then don't answer. I'm trying to stop the guessing by asking people that might have an experience that I have not come across yet. It occurs to me that more than one kind of headlamp can be used in the car, and they could change the shape of the pins to prevent one type of lamp from being installed in a car that does not have the LCM that supports it. I don't know that to be true, it's the question that I'm asking.
Old 01-13-2020, 11:26 PM   #10
TobyB
My Ride: 2004xit, 2001ci
Yes there was a facelift. Pretty much every BMW since the 60s has had a facelift mid production.
Fixed that for ya, Terra. Altho, the E21 facelift was pretty subtle....
heh
t
ps, a connector change is a pretty big change in the BMW werlt- I can't explain it either, but traditionally, the connectors didn't change other than populating or not populating the pins...
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
