Installed LSD now have bad drone - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-13-2020, 10:08 PM   #1
fr1t0
My Ride: 2001 325i
Year: 2001
Model: 325i
Transmission: 5 speed Manual
My rear end blew out and I made a huge mistake of taking it the transmission shop that had recently rebuilt the rear end in my Avalanche vs. to my regular BMW guy. Dumb, dumb, DUMB.
Anyway, I had them install a Turner LSD. After I got it back I am getting a horrible drone above 60 MPH with it really bad around 75. It has a slight vibration too. The source of the drone seems to be coming from the front of the car. When I took it in for the follow up they replaced the driver side rear axle (which I replaced 14,000 miles ago). He also said he thought it was the front wheel bearing which I also replaced 14,000 miles ago. Luckily I caught him before he installed them and I replaced them again. Long story short, it made no difference. The guibo looks solid and it looks like it was hooked up right based on the arrows. Any ideas what the probable source might be?
Thanks,
'01 325i - Bare bones & fun to drive... Sport Package, Sunroof, CD Player & Rear Fold Down Seats with Ski Bag. Added H&R springs & Bilstein shocks, CDV delete and Turner 3.46 LSD. No unnecessary frills. Sit down, buckle up, shut up & hold on.
fr1t0 is offline   Reply With Quote
Old 01-13-2020, 10:25 PM   #2
smolck
My Ride: 2003 330ci (manual)
Thanks,
Yep, the backlash and pinion depth are probably not set up correctly which causes the noise in the rear diff.
Check out my BMW Blog
Check my Youtube channel for DIY's and fun stuff
smolck is offline   Reply With Quote
Old 01-13-2020, 10:36 PM   #3
fr1t0
My Ride: 2001 325i
Year: 2001
Model: 325i
Thanks. I'll either have them check that or take it to my BMW guy like I should have done in the first place.
Sponsored Links
Advertisement
Old 01-13-2020, 11:31 PM   #4
TobyB
My Ride: 2004xit, 2001ci
First, make sure the csb is preloaded forwards, and then loosen the center driveshaft gland, give everything a good wiggle, and then retighten.
A diff does not drone, usually- it'll whine, howl, sizzle or grind, depending on how it's mis- set. I'd be far more suspicious of the driveshaft, since it would have
been pulled and reinstalled by a non- specialist. It may also have a binding u- joint.
If it's a high- frequency vibration (way over what you'd get with a tire) it's almost guaranteed to be driveshaft.
hth
t
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
Old 01-14-2020, 03:18 AM   #5
Alex323Ci
OE ///MEMBER PLUS
My Ride: M3 & 323Ci (sold)
well first thing that comes to mind when saying you have noise after putting in a LS diff is the diff. gear builder doesn’t set r & p perfectly you’re gonna get noise. limited slip unit same thing.
but you said the drone is from the front. so that doesn’t fit. so I suggest you pinpoint the area of the drone and proceed after that.
it could certainly be the something in the driveline, but that usually has vibration issues related.
and then who knows if they messed with your exhaust hooking up your diff and driveline? this is much less likely as it would be more heard.
curious did you get your gear ratio switched too? something shorter and not as tall?
Old 01-14-2020, 08:41 AM   #6
MrMCar
My Ride: E30M3 Track Car
You're going to need to diagnose where the noise is coming from and then why.
Driveshafts are pesky noise transmitting tubes and have the ability to take a differential noise (if that's the issue?) and send it very far forward.
You can test it at home, but it's dangerous. Raise up the car onto jackstands with the rear suspension compressed. Run the car in gear and get to the 'zone" where the noise happens and gather clues. Running the car with the suspension drooped will stretch the rear axles and A) put unwanted force on the bearings/cages. B) produce false conditions for testing.
Should at any point it fall off of the jackstands...........
I see you're in Cincinnati. Brett Anderson of Koala Motorsport builds hundreds of differentials, albeit the Turner one you have is from another guy. You will likely counter some resistance if you seek out his diagnosis. Albeit supremely qualified to do so.
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Old 01-14-2020, 09:32 AM   #7
fr1t0
My Ride: 2001 325i
Year: 2001
Model: 325i
Thanks all. While not a BMW specialist, the shop is a transmission/drivetrain specialist. The only reason I took it to him is because they did a good job on my Avalanche rear end and I noticed an E46 in their lot when I was picking it up. The LSD was bought as a complete unit (housing and all) from Turner Motorsports.
TobyB - Thanks. I was thinking either guibo or center support bearing as well.
Alex325ci - I'm sure it's not the exhaust. That thought did cross my mind. To test it, I got it up to 70 and once the drone was really going, I took it out of gear and let off the gas. The drone only fluctuates with rotation, not with engine speed. Oh, and yeah, I did switch to a 3.46 gear ratio. I wanted something with a bit more pep without killing fuel economy.
MrMCar - Thanks. I thought about what you mention regarding testing on jackstands but I don't have the guts to try it. This is an argument to get a full lift (jk).
I'll see if the CSB is something I feel comfortable with. If not, I may give them one last chance to make it right or do what I should have done initially and take it to my regular BMW guy.
Old 01-14-2020, 10:34 AM   #8
TheRiddle
Sofa-king-what
My Ride: M52TUB28-Vert
maybe they separated the trans shaft without marking it, with the result of an unbalanced shaft??
TheRiddle is offline   Reply With Quote
Old 01-14-2020, 02:42 PM   #9
Alex323Ci
OE ///MEMBER PLUS
like I said, you’re going to have to pinpoint the area of “drone”.
I don’t have the car in front of me but my money is on the new 3.46 LSD.
