2003 325xi no 5v crank signal - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 01-14-2020, 07:53 AM   #1
Beamerman99
I have no 5v reference as soon as I plug my crankshaft position in but if I unplug my sensor and test for it off the connector I have my 5v signal until I plug the sensor in then I have 0.1v and Ik it's not the sensor I've tried 3 of them can anybody help me out I'm a loss I've just spent upwards of $500 replacing all the ccv, vacuum lines, disa, valve cover etc and now I have a no start bmw that ran when I parked it to replace all that stuff
Beamerman99 is online now   Reply With Quote
Old 01-14-2020, 08:30 AM   #2
cvx5832
My Ride: 535i, 325Ci, C300
Sounds like a short. Try a new sensor.
cvx5832 is offline   Reply With Quote
Old 01-14-2020, 08:42 AM   #3
Beamerman99
I've tried 3 to no avail
Sponsored Links
Advertisement
Old 01-14-2020, 09:48 AM   #4
MrMCar
My Ride: E30M3 Track Car
Not seeing the car directly and that given all was fine when you started I'd suggest the KISS (Keep It Simple Stupid) method:
Have you gone back over all of your work and made sure that all is hooked up, hooked up correctly and nothing swapped inadvertently?
Are all of the wires and/or grounds correct on the top of the valve cover?
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Old 01-14-2020, 11:27 AM   #5
Beamerman99
Yes I've triple checked everything I can get the car to start if I unplug the crankshaft sensor but if I plug it it it drops my 5v to all the other sensors
Old 01-14-2020, 11:33 AM   #6
Beamerman99
Is there any chance the connector maybe shorting when I plug in the sensor
Old 01-14-2020, 12:42 PM   #7
TobyB
My Ride: 2004xit, 2001ci
yes, it's possible- I was going the other way, and thinking there was a loose connection somewhere in the engine harness box.
That thing is a pain in the butt when you're working in there, and it's easy to stress and strain the individual wires.
Try measuring current draw (milliamps)- troubleshooting isn't easy unless you open up the box, which is a pain in its own right...
t
"I'm sorry. I actually had to poop and ended up breaking the car."
- Hot Tub
TobyB is offline   Reply With Quote
Old 01-15-2020, 06:37 AM   #8
markusmarkus
My Ride: 2018 M240i
What brands of sensors have you tried?
Old 01-15-2020, 07:27 AM   #9
Beamerman99
Duralast but they've all ohmed out the same as my genuine bmw one I pulled from the car I have a pigtail coming in the mail visually I see freyed insulation on the wires but that doesn't explain why it only shorts when a sensors plugged in I've made sure none of the wires are touching
Old 01-15-2020, 02:23 PM   #10
Sapote
My Ride: 2000 323i auto wagon
There are 3 pins on the sensor; so which pin are you taking?
Sapote is offline   Reply With Quote
Old 01-15-2020, 06:38 PM   #11
Beamerman99
Update I did some more troubleshooting today I found my 5v is backwards for instance if I take my crankshaft sensor plug it in and backprobe my 5v signal wire I have 0.2 until I put a wrench over top of the magnet in the sensor then I get my 5v this is making no sense to me I can figure it out for the life of me
Old 01-15-2020, 07:09 PM   #12
Overboost
//Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
Seems you might be measuring the signal wire.
  • To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
The older I get... The faster I was...
No Fear
Overboost is offline   Reply With Quote
Old Yesterday, 08:38 AM   #13
Beamerman99
I am I have p0727 code no start I looked online I should have a constant 5v until I break the circuit with a wrench but it's backwards I don't have 5v until I break the circuit which it should be the other way around correct?
Old Yesterday, 07:43 PM   #14
Sapote
I repeat.
Old Today, 09:06 AM   #15
Beamerman99
Number 2 on the connector yellow wire
