Failed to replace engine mount, 325i SULEV - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-13-2020, 12:56 PM   #1
gagi
My Ride: E46 325i
I got a beatdown by my 325i M56 SULEV.
I knew about the passenger side being more troublesome. I thought it made more sense to tackle it first. I removed the nuts on the passenger side mount and loosen the nuts on the driver side without removing them. I used a jack under the oil pan to lift the engine. Looked promising until the front of the car started to lift off from the jackstands. I kept trying at least 10 more times placing the wood and jack at different spots. The oil pan isn't really that big so all my attempts failed.
Need to get an engine bar and try again next time.
The good news is, my mounts still seem to be in reasonable good condition after 15 years. In general, rubber parts are still good on my car. Being garaged in a warm and dry place like California might be the difference. My intake boots were still good when I replaced them.
gagi is offline   Reply With Quote
Old 02-13-2020, 01:08 PM   #2
Overboost
//Binary is in my DNA
Overboost's Avatar
My Ride: 2002 325i
No need for the engine support bar. Try loosening the right side mount bracket from the engine block and it will give you the room needed to get the mount out and back in. The left side is a little tighter as you can't easily loosen that bracket. I used this 50sKid video when I did mine.
  • To view links or images in signatures your post count must be 0 or greater. You currently have 0 posts.
The older I get... The faster I was...
No Fear
Overboost is offline   Reply With Quote
Old 02-13-2020, 01:21 PM   #3
gagi
My Ride: E46 325i
I have seen the video. 50sKid ran into the same issue when he had both mounts loose. His and other videos was the reason I tried to replace the mount one side at a time.
Unless I could find a jack point on the engine closer to the passenger side, I don't think I can get enough clearance without lifting the whole car up.
