Top radiator hose - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 02-13-2020, 07:01 PM   #1
esa1969
Top radiator hose
So after running the car for awhile with the heat on the low coolant light starts coming on and off. Only after running for 30 minutes or so( no over heating and gauge in the middle) I turn the car off and a few minutes later it moves the top radiator hose back from the settled position causing it to leak.
Any advise would be appreciated.
esa1969 is offline   Reply With Quote
Old 02-13-2020, 07:14 PM   #2
swordsman11868
My Ride: 2003 325i
Transmission: Autotragic
Sounds like the hose is not fully seated in the radiator.
Pull up the clip and seat the hose. Then push the clip back down so it engages the locking rings.
I'm just here to change the world.
BMW Wiki:
Are you getting hot air no matter where you set your A/C in your E46? Check out this ancient thread! Chime in with your experience:
swordsman11868 is offline   Reply With Quote
Old 02-13-2020, 07:20 PM   #3
esa1969
Did that twice and some how pressure is pushing it back causing a leak.
Sponsored Links
Advertisement
Old 02-13-2020, 07:23 PM   #4
esa1969
What would cause this back pressure and the low coolant light coming on and off while driving and no coolant lost.
Old 02-13-2020, 08:27 PM   #5
Newbimer
My Ride: 2005 325i
You do not need to lift the locking clip to install the hose. Actually, you should leave it down when installing so you hear it click when its full inserted. Back pressure can be caused by air in the system that expands when heated, combustion leaks into the cooling system, could also be a bad rad cap not releasing excess pressure in the system. Let it cool completely, check the cold level, add if needed then make sure you bleed the system properly.
Newbimer is offline   Reply With Quote
Old 02-13-2020, 08:55 PM   #6
Sapote
My Ride: 2000 323i auto wagon
It moves the hose; what moves the hose?
Lube the radiator port and the hose connector O-ring with brake grease (synthetic grease) and with the clip fully inserted, push the hose on the radiator port until the clip is clicked over the port barb.
You still have air in the system which might cause the coolant light on/off.
Sapote is offline   Reply With Quote
Old 02-13-2020, 09:06 PM   #7
esa1969
The radiator cap is after market. How would I tell if it's releasing the pressure correctly?
I replaced the overflow box and thermostat 2 months ago and this is the first of my issues.
Old 02-13-2020, 11:21 PM   #8
77'911
Had this issue when a shop installed after market coolant parts(tank, cap , upper hose t-stat, etc) on our car. Installed factory BMW parts, no leaks after 12+ months. Our car would leak coolant if you just touch the upper hose, the connection fit was that poor. Welds on the reserve tank were bad when new.
regards
77'911 is offline   Reply With Quote
Old 02-14-2020, 01:37 AM   #9
jmo69
My Ride: 03 325xi 98 328is
The system should be building enough pressure to vent through a stock 2.0 bar cap. Never vented with my 1.4 bar cap. Sounds like you need a new hose, you can get a Rein at Autozone, around here it's $48 or Amazon for $31 https://www.amazon.com/CRP-Automotiv...2003+BMW+325xi A friend just replaced his with that one. Has the system been bled properly or been over filled. Air in the system will compress but the coolant wont.
Alternative to expensive xi control arm bushings
Bad outer xi ball joint?
2003 325xi auto Stahlgrau
1998 328is 5sp
jmo69 is offline   Reply With Quote
Old 02-14-2020, 04:55 AM   #10
MrMCar
My Ride: E30M3 Track Car
The O ring is worn (shrunk) from age. If OE hose and young there is no movement.
The movement is caused by expansion/contraction.
Don Fields
////MrMCar
www.mrmcar.com
MrMCar is offline   Reply With Quote
Old 02-14-2020, 06:52 AM   #11
markusmarkus
My Ride: 2018 M240i
The installation of aftermarket cooling system parts is strictly verboten!
