Cooling System Refresh in Colder Weather - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 03-26-2020, 10:16 AM   #1
JoshUpNorth
My Ride: 2001 BMW 325xi Touri
Year: 2001
Model: 325xiT
Transmission: 5-SPD Manual
Hi, I own a 2001 BMW 325xi Touring and I have some questions about doing a cooling system refresh. I live in Minnesota and the temps are still in the 30's to high 40's. I've done as much research as I can and found that most people say to do the refresh in warmer temperatures but I haven't been able to find a specific reasoning for that.
Would it be okay if I replaced the water pump, coolant lines, radiator, expansion tank, thermostat, and the coolant distilled water mixture in 40-50 weather? The reason I don't really want to wait is I have seen small coolant puddles on the ground and the coolant light has come on every once in a while. I want to take care of it before something bad happens.
All help is appreciated.
JoshUpNorth is offline   Reply With Quote
Old 03-26-2020, 10:31 AM   #2
lllRazorlll
My Ride: Accord Coupe
The specific reasoning is that the coolant level is supposed to be checked at 68 Fahrenheit. Just fix what is needed, add coolant, bleed the system, and check back later after the engine is cooled down and after a couple of days.
lllRazorlll is offline   Reply With Quote
Old 03-26-2020, 10:39 AM   #3
BaliDawg
DEADBEEF BAADF00D
BaliDawg's Avatar
My Ride: E39 E46 E84
Should be fine. When I lived in Minnesota (many years ago) we worked on cars in all temperatures, and it was NOT fun when it gets cold.
I wouldn't hesitate to fix an important issue like a cooling system leak.
FYI: the coolant bleed procedure calls for having the key on, heater on, and fan at lowest setting. But this isn't necessary on an E46 because its heater valve is open when unpowered.
Sponsored Links
Advertisement
Old 03-26-2020, 10:40 AM   #4
Knight
My Ride: SL63 | SHO | E46
40F is fine. Keep in mind, the expansion tank and venting cap are there to accommodate coolant level fluctuations driven by ambient temperature.
Two critical safeguards:
  1. Keep the coolant level to the minimum (top of the float right at the neck of the ET).
  2. Use a 1.4 Bar ET Cap.
Knight is offline   Reply With Quote
