M54b25 vanos - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-21-2020, 11:19 PM   #1
crocs
M54b25 vanos
Hey guys, so ive bought an used double vanos unit, ive changed the rubber gaskets and stuff. Im about to swap this one with the one on my car. My question is do i need to lock the engine if im only swaping the units? or i can just remove it, put on the new one bolt in and go?
crocs is offline   Reply With Quote
Old 05-21-2020, 11:32 PM   #2
ptsao
My Ride: 2003 M3
when I did mine w/ VC job, I just remove and install, those 2 bolts are reverse thread
ptsao is offline   Reply With Quote
Old 05-21-2020, 11:42 PM   #3
crocs
Yeah i know that those 2 bolts are reverse. Ill wait for more opinions tho, i mean i could do timing aswell, but dont have the time for it now ***x1f615;
Sponsored Links
Advertisement
Old 05-22-2020, 12:57 AM   #4
LeverThis
My Ride: 2004 325i automagic
Timing is not affected when removing & installing the vanos ... just don't turn the engine over while it's out.
20mm OD x 12mm ID x 4mm W : Viton O-Ring
3/4" OD x 1/2"ID x 1/16" Thick : Thrust Bearing/Washer
LeverThis is offline   Reply With Quote
Old 05-22-2020, 01:59 AM   #5
BaliDawg
Here to serve y’all
BaliDawg's Avatar
My Ride: E39 E46 E84
^This. Remove, no turny engine-y, replace, job done!
Old 05-22-2020, 03:41 AM   #6
crocs
Alrighty, thanks ***x1f642;
Old 05-22-2020, 11:37 AM   #7
DBecker
My Ride: e30,e34,z3,e39
To echo the answers: when you remove the VANOS unit you unscrew the connection to the helix cups, leaving them behind. It's those helix cups which adjust the cam timing.
Even if do something (e.g. strip the screw head) so that you have to remove the helix cups with the VANOS unit, they are keyed on the M52tu / M54 / M56. It's only a little fiddling to put them back in with the cam timing unchanged.
This makes it much easier to service than the older single VANOS, where the unkeyed helix cup was removed with the VANOS unit.
DBecker is offline   Reply With Quote
Old 05-22-2020, 12:02 PM   #8
Newbimer
My Ride: 2005 325i
To be on the safe side, put scratch marks in the chain and gears to align them, and zip tie the chain to the gears in two places so they can't move.
Newbimer is offline   Reply With Quote
