Newer LCM on a 04/2001 model - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-22-2020, 09:41 AM   #1
MrPlow442
My Ride: 325Ci
Year: 2001
Transmission: Manual
So I'm trying to get Xenons and LEDs for my 04/2001 325ci. Now I've read that my stock LCM does not support Xenons and LED's (dash will light up and will probably cause flickering) without some resistor ****ery. I've also read that apparently 09/2001 models do support after flashing, and fcl models all support those types of lights. My question is, can I fit an LCM from a fcl model (let's say from 2005) and the lights will work?
MrPlow442 is offline   Reply With Quote
Old 05-22-2020, 10:24 AM   #2
TerraPhantm
My Ride: M3
Needs to be coded, but yes
Your stock one can be coded for xenons (minus autoleveling which you don't have the wiring for anyway), but LEDs need an 09/2001 or newer.
Old 05-22-2020, 11:26 AM   #3
mega_stihl
My Ride: E46 & E32
I had the same issue not that long ago. What you need is an LCM that supports LEDs and xenon. It IS possible that it supports LED but is not yet programmed as it came out of a car without leds. If that is the case, you need to code it for leds (with NSC Expert). As NSC Expert didn't work on my computer, I had to find an LCM that came out of a car with leds, so it was already coded properly. All I had to do then was code the mileage and VIN number into it, and tadaa.
E46 320Ci FL swapped to 330Ci
Bilstein B12 - H&R sways
mega_stihl is offline   Reply With Quote
