[SOLVED] Crank, but won't start (after engine swap) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-23-2020, 10:05 AM   #1
mega_stihl
My Ride: E46 & E32
Swap is done. M54B30 is in the car, everything is connected. Car cranks, but won't start. Not even one "poof" or anything.
Well, not everything is connected, but the important things needed to start the car, are. The MAF is not yet connected, which does not seem important, as many disconnect it to diagnose if it's working or not, and simply drive off without one. LPG injectors are not connected, but all (vacuum) holes/tubes have been shut off. Primary OČ sensors are connected. There is fuel pressure.
When I hit the throttle pedal with ignition on, I don't hear the throttle valve opening/closing. Is this normal?
Is there anything I can check in INPA? I'm asking, as I find INPA one of the most confusing software used to diagnose a car ...
Also: DME and wiring harness are the same as before, so for the electronics, nothing should have changed.
E46 320Ci FL swapped to 330Ci
Bilstein B12 - H&R sways
mega_stihl is offline   Reply With Quote
Old 05-23-2020, 10:22 AM   #2
infoboy
My Ride: 325ci
If your car was 325/320 before and you still running the 325/320 software on the ecu sometimes it wont start with m54b30 injectors like in my case it didnt start so i did reuse the b25 injector temporary and started the car.next day b30 software was uploaded on the car and i did instal the b30 injectors again and everything was fine.
Sent from my SM-J415F using Tapatalk
infoboy is offline   Reply With Quote
Old 05-23-2020, 11:07 AM   #3
mega_stihl
My Ride: E46 & E32
SOLVED!
I forgot that the wiring of the fuel injectors goes through the LPG module, as the injectors need to be shut off once the car runs on LPG. I didn't connect the LPG module yet. Connected it, starts and runs fine! Still some issues I might have to look after, like alternator light that stays on for some reason.
