Sunroof Fix…. Anti trapping issues - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 05-04-2007, 03:03 PM   #1
JmAbshire
My Ride: 01 330i Jet Black
Exclamation Sunroof Fix…. Anti trapping issues
If you have ever messed around with your sunroof i.e. replaced the clips and the sunroof stops half or 75% of the way, I have finally (with the help from by brother-in-law who works at a dealership in MD) figured out how to properly initialize it. Everywhere you look they tell you to hold the button in for 20 seconds and then that's it. If you have an 01~02, this as you know does not work. It might work for a bit, but it will eventually stop again later down the road. I've just been dealing with it, pretty annoying . So here is how you do it:
1. Turn your ignition to on but do not start the engine, AC position
2. Hit the button and hold it in retract position, the sunroof will go back now, once its there keep holding the button back for about 20-30 seconds.
3. Next push the button forward while holding it the whole way, the sunroof will go forward, once its there keep holding it forward until the sunroof goes up to the vent position.
4. Now depress the button to lift the sunroof (I know its already up,) hold for approximately 20~30 seconds until it goes up one more level.
So in essence what you are doing is training the motor in all three positions. Another note.. Lubing up the rails is also a good idea, however this alone will probably not fix the anti trapping (it has surprisingly enough has for some on here ). Give it a shot and see if it works.
J
JmAbshire is offline   Reply With Quote
Old 05-04-2007, 03:31 PM   #2
flyinj3x
flyinj3x's Avatar
My Ride: 03/03 330ci
Send a message via MSN to flyinj3x Send a message via Yahoo to flyinj3x
i tried it, and for the time being, it seems to work. thanks for the tip.
my obligatory
and
links.
flyinj3x is offline   Reply With Quote
Old 05-04-2007, 03:33 PM   #3
jbeurotech
Past Site Sponsor
My Ride: 2000 E46 with 254K
Yup they updated the control units to the ones on the E39 what you just posted is the same for an E39 there are alos TSB's about this so it shouldn't have been hard to figure out
jbeurotech is offline   Reply With Quote
Sponsored Links
Advertisement
Old 05-04-2007, 03:36 PM   #4
nuwde
My Ride: 2001 330Ci
Everything was going well for me until step #4. My sunroof would not lift "one more level." It wanted to (I heard a twitch-like sound) but it didn't. Any suggestions? Thanks!
J
nuwde is offline   Reply With Quote
Old 05-04-2007, 04:31 PM   #5
LambMadras
My Ride: 2001 330Ci
Great post! Seems to have worked so far on my '01 330Ci. Didn't really want to try the clips DIY yet and this looks to have solved my problem for the time being!
LambMadras is offline   Reply With Quote
Old 05-04-2007, 05:33 PM   #6
kittybitme
My Ride: sweet german sled
same thing
Mine did the same thing on step 4
kittybitme is offline   Reply With Quote
Old 05-04-2007, 06:45 PM   #7
nuwde
My Ride: 2001 330Ci
anyone got answers?
Old 05-04-2007, 11:54 PM   #8
MysticBlau330Ci
My Ride: 330Ci '04 & M4 2016
Good info
MysticBlau330Ci is offline   Reply With Quote
Old 05-07-2007, 02:15 AM   #9
nuwde
My Ride: 2001 330Ci
bump for an answer to this.
Old 05-07-2007, 02:18 AM   #10
davidwarren
Halfway to 2L
davidwarren's Avatar
My Ride: 2010 335i
I changed my clips, but now the shade does not retract on it's own when the sunroof goes from closed to vent.
You down with UCC? Ya you know me!
sowing the seeds of jiggery pokery
davidwarren is offline   Reply With Quote
Old 05-07-2007, 07:02 AM   #11
shortyb
My Ride: Has blue lights
Just a bit OT, but does anyone have or can direct me to pics showing were to lube the S/R tracks? Tried lincomatic's and others DIYs, but none show really clear areas to lube, unless I'm missing something. I have found the ones for the interior shade but can't seem to locate the ones for the glass panel. TIA.
shortyb is offline   Reply With Quote
Old 05-08-2007, 03:48 AM   #12
nuwde
My Ride: 2001 330Ci
bump again. can't get past step 4...
Old 10-13-2009, 10:49 AM   #13
stedes
My Ride: None yet
Sorry to resurrect an old thread with my first ever post, but I've just got my first E34 (1999 318i - lowly I know) and the sunroof was staying an inch or so down...
Tried the above procedure and worked 100% first time.
You guys are awesome! I cannot believe it was that simple to fix!
stedes is offline   Reply With Quote
Old 10-13-2009, 11:42 AM   #14
n2Bimmer
My Ride: Loves Corners
after replacing the clips on my sunroof the visor/cover does not open all the way, the glass does slide but the interior panel does not open. Anyone know why.
Old 01-24-2012, 09:07 PM   #15
220k330
My Ride: 2001 330ci ZSP
anyone still following this?
220k330 is offline   Reply With Quote
