Driver Side Door Lock Problems - Page 3 - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 22 votes, 5.00 average. Display Modes
Old 02-26-2008, 11:43 PM   #41
bediteam
My Ride: X5 3.0 2001
I still have this problem with Keyless, as it wont work at all. i bought a new key fob, and tried re-programming, and still nothing,. the car still beeps after i shut it off and remove keys. any suggestions? thank you
bediteam is offline   Reply With Quote
Old 02-27-2008, 02:00 PM   #42
gwburke
My Ride: 1999 BMW 328i
Sounds like it may be your actuator then. Have you tried removing the door panel to see what happens when you press the button from the remote, as well as the button from the center console? If it was a cable out of place you would still see some movement.
gwburke is offline   Reply With Quote
Old 08-13-2008, 12:07 PM   #43
twka90
My Ride: 2003 M3Cic
Now I have this issue as well -- the remote works intermittently, and the passenger door did not unlock this morning (even via inside door handle). From what I understand, there are at least two unrelated problems with doors -- one is the actuators, and another is the "body control module" AKA "GM5". Here is a great write-up of the GM5 problem: http://www.revoxremotes.com/BMW/BMW_GM5.htm. New GM5 is $350, plus from what I understand it needs to be "programmed" by the dealership (figure additional couple hundred $, I guess). The guy who did the write-up promises to fix the thing for $100.
twka90 is offline   Reply With Quote
Sponsored Links
Advertisement
Old 08-13-2008, 12:13 PM   #44
Snik
Snik's Avatar
My Ride: IR M3 Vert.
DUDES, the center console lock/unlock button is dirty, clean it or get a new one for around $40. problem solved.
it is not the actuator, its years and years of coffee and juice and water spilled on the console button, when that switch goes bad, it fux the entire central locking system up.
The Snikster posted sexy wiminz
Do you ride a
Do you have a question about Jamaica?
Old 08-13-2008, 12:28 PM   #45
twka90
My Ride: 2003 M3Cic
This would be the third unrelated problem then. There definitely were people who got their problem resolved by fixing/replacing GM5...
Old 08-13-2008, 12:32 PM   #46
Snik
Snik's Avatar
talk to BMW tech, theyll tell you, this is a common problem
Do you ride a
Old 08-13-2008, 12:59 PM   #47
twka90
My Ride: 2003 M3Cic
I am not saying that the problem you describe does not exist (or is not common). All I am saying is that it is not the only problem with doors failing to lock/unlock. The actuators ARE crap, and relays in GM5 DO fail...
Old 08-13-2008, 01:09 PM   #48
Snik
Snik's Avatar
i hear ya bor, but from what ive learned, more often than not, its the console button
Do you ride a
Old 08-13-2008, 01:33 PM   #49
twka90
My Ride: 2003 M3Cic
Are there any pics/steps on how to check/clean it?
(I suspect that it's probably rather straightforward, but since my mechanical skillz generally don't go beyond changing lightbulbs and fuses, I have to ask for directions )
Old 08-17-2008, 12:05 AM   #50
twka90
My Ride: 2003 M3Cic
A quick update: I do, for a fact, have a faulty GM5 (a.k.a "GM V") -- a mechanic read the error codes of the "central locking computer", and there were errors specifically saying that relays in GM V module failed sporadically.
Old 08-25-2008, 02:54 PM   #51
twka90
My Ride: 2003 M3Cic
And another update -- I sent my GM for repair, and got it back in two days. The locks work fine now. To me, this was totally worth a benjamin.
To recap -- if you have problems with your door locks not locking/unlocking properly, there is a chance you have a "GM 5" (a.k.a "GM V") issue described at http://www.revoxremotes.com/BMW/BMW_GM5.htm. If you do, in fact, have this kind of problem, Scott does indeed fix it.
Old 08-25-2008, 03:09 PM   #52
Snik
Snik's Avatar
so are the door locks basically inoperable when the GM5 is out?
Do you ride a
Old 08-25-2008, 04:19 PM   #53
twka90
My Ride: 2003 M3Cic
Yes. Better make sure that you unlock the doors you want to use before getting the GM5 out. Also, neither windows (nor the roof, if you have a 'vert) work. Most importantly, though, note, that windshield wipers do not work at all (while headlights are, strangely, unaffected). BTW, Scott mentions all this on his page.
Old 08-25-2008, 05:07 PM   #54
Snik
Snik's Avatar
damn thats a lot of crap that wont work.
but the key method with the driver side is the only way in and out?
Do you ride a
Old 08-25-2008, 10:45 PM   #55
twka90
My Ride: 2003 M3Cic
Did I mention interior lights, parking distance sensor, power seats and remote trunk opening?
To tell you the truth, I did not try to lock the driver's door while GM5 was out (did not want to push my luck ). The second door needed to be unlocked anyway, so it did not make any difference from the "security" point of view.
Seriously though, the only thing that can really bite you is the windshield wipers. If you get into rain on a highway, it's not fun (RainX might be an option for places where it's guaranteed to rain every day).
Old 09-06-2008, 05:45 PM   #56
Snik
Snik's Avatar
hahah, hey you gave me a shout out on your webiste. cool
yeah, mine started doing it again. so yep, you were right. tho i am convinced that my lock/unlock button was fuctup too.
im working on aquiring another GM5 so i can still use my car while i send mine to you.
oh, btw, does the transmition type matter, if im getting a GM5 from another car?
Do you ride a
Old 09-06-2008, 05:46 PM   #57
Snik
Snik's Avatar
or doing bout 80moh that pushes the water right off
Do you ride a
Old 09-11-2008, 06:56 PM   #58
MoTo178
My Ride: 2002 325Ci
Send a message via AIM to MoTo178
Dammit... I knew getting the keyhole delete mod on my coupe would come back to bite me in the ass someday.
So I would essentially have to climb through my trunk until I get the GM5 back?
....fack.
(I got the same issue. Drivers side will lock but not unlock, although I can hear the unlock process happening it just never pops up. Passenger side is getting slow to pop. Sometimes it comes halfway and I have to lock and unlock again to pop it.)
MoTo178 is offline   Reply With Quote
Old 09-11-2008, 06:58 PM   #59
Snik
Snik's Avatar
put your lock back on until then.
Do you ride a
Old 10-07-2008, 03:18 PM   #60
x13atma17x
x13atma17x's Avatar
My Ride: E46 323i
Did anyone have problems taking the GM5 out? It looks simple & easy here but a local BMW Indy told me that it is very difficult.
Can someone share his or her experience on removing these??
Thanks in advance!
-omar-
x13atma17x is offline   Reply With Quote
