blitzsafe aux adapter trunk wiring diy (with photos) - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Thread Tools Search this Thread Rating: Thread Rating: 17 votes, 5.00 average. Display Modes
Old 04-12-2010, 09:03 AM   #1
thatsonlyme
My Ride: 2001 330Ci Sport pkg
Well, finally I figured, after 2 years of using this forum to learn everything I needed to know about my car, it is my turn to give a little contribution to the community.
Even though this is very simple diy and I believe most of you guys don't really need to be told how to route piece of cable from the trunk to your center console, here it is, take it or leave it:
First off, let me skip disclaimer, you know the drill, I'm not responsible... yada, yada.
I decided to go with BLITZSAFE Aux adapter instead of DICE for three reasons. First, it was half price of the DICE, second I don't really use Ipod but rather listen to my music on my phone and third, I don't care or need song names displayed on the radio.
My radio is pre 09/03 so I had to go for the trunk install.
Here is the tools you need: flat head and phillips screwdriver, small torx screwdriver (dunno what size it doesn't say on it), small wire cutters, soldering iron and solder, some electrical tape (or heat shrink tubing if you prefer) and a piece of metal wire for fishing the aux cable.
Also you need: Blitzsafe Aux adapter ($75), 12ft audio Y cable ($10), RCA stereo cable ($5-10 if you want retractable) and 3.5mm stereo phone jack ($5 for 2 of them @ radio shack)
DSC_2695
Here we go:
Once you pop your trunk you might want to start by removing tail light assembly.
DSC_2696 DSC_2697
I didn't and I started pulling the carpeting out which resulted in broken clip on my tail light assembly.
DSC_2698DSC_2699
Using flat head screwdriver, remove two rivets holding the carpeting and pull the carpeting out.
DSC_2704
Be careful not to break plastic clip in the corner. I couldn't figure out how to remove it but it wasn't necessary anyways.
DSC_2707
Locate cd changer harness and plug it in your blitzsafe adapter to make sure it works properly. Plug in your mp3 player and press mode or CD button on your head unit until it shows CD 1-99. You should be able to play music through your speakers at this point.
DSC_2705DSC_2706
Now it's time to do a little wire cutting and soldering. first I used ohm meter as continuity tester to find out where to solder wires on my phone jack. You need to use common sense to figure this out as I can't explain it in simple words. Feel free to add detailed explanation to this diy if you want to.
DSC_2709
Then I cut the cable
DSC_2710
and determined where each wire has to be soldered on the phone jack.
DSC_2711
solder it all together and wrap it with electrical tape or heat shrink tubing.
DSC_2712DSC_2713
Now remove the back seat by pulling it out. Sides can be slightly bent for easier removal.
DSC_2708
Remove the corner of the back seat by pulling out at the bottom first. It is clipped in place and feels like it's gonna break if you pull to hard.
DSC_2715
You don't want to route your cable through this hole because the seat clips in there! Notice where other wires go and use that route instead.
DSC_2716
Plug Cd changer harness and y cable into your blitzsafe adapter, bundle it together with some zip ties and you can also zip tie adapter itself on the chassis. Route the cable to the cabin.
DSC_2717DSC_2718DSC_2719
Now it's time to start taking apart center console. Let's start with the rear ashtray. Simply pull it out, disconnect the harness and remove two phillips screws. My center console was FILTHY as you can see, so I cleaned everything up upon assembly.
DSC_2720DSC_2721
Remove the shifter boot by pressing from both sides and lifting it up. Unscrew two phillips screws and remove the trim. Under the trim you will find another two screws. remove them as well
DSC_2722DSC_2724
Remove the e-brake boot in the same fashion as shifter boot and remove plastic trim that holds rear ashtray in place. This trim has sharp edges so be careful not to scratch your armrest or your seats.
DSC_2725DSC_2726
Removing center console will require some fiddling and playing with armrest so take your time on this one.
DSC_2727
Remove sunglass tray by applying pressure upwards and pulling it out.
DSC_2728
Remove two phillips screws and pull entire assembly out. disconnect the harness and cigarette lighter.
DSC_2730DSC_2731
Now that we had done all this hard work, it's time to take a little break. So why not go fishing? Cable fishing that is.
I fount it to be easiest if you stick a piece of aluminum wire under the carpet, starting near e-brake and pulling it out on the other side, then hooking up your soldered cable and carefully pulling the aluminum wire back.
DSC_2732DSC_2733
Now simply route the cable to the front. 12ft was perfect length for this job.
DSC_2734DSC_2735
I was so excited at this point that I forgot to take pictures of a few steps in a process. However, it's very straight forward and you shouldn't have any problems figuring this out.
Remove button assembly by unscrewing two torx screws and remove front and rear panel using a flat head screwdriver.
DSC_2736
Cut the hole on the back panel and stick phone jack through it. I made this ugly cut because I was using dremmel and wire cutters, but it doesn't bother me as it will be hidden behind the dash anyway.
Now the part that is not pictured, carefully position and drill the hole in the front panel for the phone jack. Stick the threaded part of the jack through and secure it with provided nut.
DSC_2737DSC_2738
At this point it's probably a good idea to test if everything works properly.
DSC_2739
Reassemble everything in reverse order and you're all done!
here is a few photos of finished install:
DSC_2740
I'm very happy with my new setup. Sound quality is great and I don't have any cables hanging around.
Let me know what you think
thatsonlyme is offline   Reply With Quote
Old 04-12-2010, 09:04 AM   #2
thatsonlyme
few more pix, I didn't know there was a limit of 40 pix
DSC_2742DSC_2743
Old 04-12-2010, 11:06 AM   #3
33beto
My Ride: 08 328i Sedan(R.I.P)
Send a message via AIM to 33beto
Nicley done. Thank you!
33beto is offline   Reply With Quote
Sponsored Links
Advertisement
Old 04-12-2010, 12:04 PM   #4
smolck
My Ride: 2003 330ci (manual)
Bookmarked! Thanks so much, I have a pre 03 myself and have been wanting to do this since I got my HTC Hero, Pandora in the car anyone?
Check out my BMW Blog
http://smolckbmw.blogspot.com/
Check my Youtube channel for DIY's and fun stuff
http://www.youtube.com/user/flipfinish?feature=mhee
smolck is offline   Reply With Quote
Old 04-12-2010, 04:57 PM   #5
ZZen330
My Ride: 2002 330Ci
Cool DIY. Good pics too.
I did something similar but you could have saved some time and work on a few of your cable running steps that were unnecessary.
Nice work though!
ZZen330 is offline   Reply With Quote
Old 03-03-2011, 12:43 AM   #6
uvahaole
My Ride: 2002 330xi
Great DIY! I'm about to start this project. I am planning to use some premium audio cable with a 12mm x 6mm thick cable body. Given the size of the jack that was routed and fished, I don't anticipate this will be a problem.
ZZen330, can you comment on which steps are not necessary? Thanks.
uvahaole is offline   Reply With Quote
Old 03-03-2011, 07:41 AM   #7
auto180sx
My Ride: '02 Steel Blue 330Ci
Nice DIY! I shall be doing this sometime in the future!
Steel Blue FTMFW!!
OKI BMW
BMW CCA Member #444186
auto180sx is offline   Reply With Quote
Old 04-07-2011, 09:29 AM   #8
uvahaole
My Ride: 2002 330xi
Job done... thanks again.
I'm really happy with the results of following this DIY. I used two RG-59/U cables and they fit along the same cable route. Thanks again, thatsonlyme.
Old 07-12-2012, 06:41 PM   #9
NinjEskimo
My Ride: 2001 BMW 325i
Heeeeeeelp!
I bought my Blitzsafe adapter and opened up my trunk...Then I unfolded the bundle of cables and there was no 6 pin plug?! Only a 3 pin, two like... 8-12 pin. And a thick single pin plug. I am very confused... I drive a BMW 325i 2002. I emailed Blitzsafe and they said that the adapter I bought was the correct one...? I'm very confused.
NinjEskimo is offline   Reply With Quote
Old 07-25-2013, 06:39 PM   #10
Lemenkidd
My Ride: 2003.5 e46 M3 AW
2001 BMW 330i
I have a 2001 BMW 330i can we get a more detailed picture of the wires please and thank you
Lemenkidd is offline   Reply With Quote
Old 06-26-2014, 12:12 PM   #11
th0mp
My Ride: 2001 330Ci Sport Pkg
First off, thanks for the great tutorial. Second, anyone who doesn't want to deal with soldering the 3.5 mm plug, there is a site that sells a 12' RCA to panel mount stereo jack here:
http://www.showmecables.com/product/...lug-12-FT.aspx
I have yet to dig into the installation, but my cable arrived today with no issues._nr_
th0mp is offline   Reply With Quote
