SMG reset do it!! - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
///M3 Forum
Old 01-31-2011, 05:39 PM   #1
Redman M3
My Ride: M3 - Individual -
SMG reset do it!!
A reminder was given from a forum member on another site who reminded all SMG owners to reset their SMG settings and nearly all members with SMG on that thread noticed the juddering you get moving off in 1st gear disappeared.
Basically the recaliberation of the clutch change resets and bites as it was programmed when Your car was first purchased.
The manual states to do this after every tyre change. But it's part of maintaining your SMG, so here's my reminder...
When I tried it the bite was noticeably better and the juddering did go!
BMW M3 - Individual Atlantis Blue
Redman M3 is offline   Reply With Quote
Old 01-31-2011, 05:41 PM   #2
IFX
My Ride: M156
i'm not touching it.
don't ask me why..
IFX is offline   Reply With Quote
Old 01-31-2011, 06:34 PM   #3
FrenchyfromFL
My Ride: 2003 E46 M3 vert
I used to do it. Haven't done since I got headers and software, car is running smoother now
2003 E46 M3 Vert JB/IR,OEM Nav, BSW subwoofer, VMR VB3 CSL rep 19" Gunmetal, Borla Muffler, Borla Midpipe, Fabspeed headers, AA Tune, K&N intake, ST Coilovers
FrenchyfromFL is offline   Reply With Quote
Sponsored Links
Advertisement
Old 01-31-2011, 08:05 PM   #4
rcsummers
My Ride: M3
do tell how.
rcsummers is offline   Reply With Quote
Old 01-31-2011, 08:23 PM   #5
Redman M3
Drive to approx 30/40mph, stick her into neutral when the screen shows gear '0' hold both paddles together for 3-5 secs. Stick her back in to gear and your SMG will be reset.
Then give her a go and see what I mean about biting the clutch perfectly with no judder throughout. The car will then recognise your driving style and adjust to you accordingly, until you reset again...
Old 01-31-2011, 09:29 PM   #6
rcsummers
My Ride: M3
thanks^
ill give it a try tomorrow.
Old 01-31-2011, 10:35 PM   #7
turbokid
My Ride: 2005 325i
Regards,
turbokid is offline   Reply With Quote
Old 01-31-2011, 11:24 PM   #8
mooninite
My Ride: M3, X5
Doing a reset every week is just the butt dyno effect and has a higher chance of performing more wear on your clutch and SMG parts.
Just keep driving your car normally. It will continously adjust on its own like it is supposed to. If you needed to do this often, I doubt BMW would design it so you have to unplug your battery or drive 30-40mph to reset it. They would have made it a $150 dealer-only feature.
mooninite is offline   Reply With Quote
Old 01-15-2012, 09:23 AM   #9
Irishdb
My Ride: ///M3
Originally Posted by rcsummers View Post
thanks^
Revive the old post...did you notice a difference?
Also - after you hold the paddles for 3-5 secs...do you get a message or some sort of signal that the reset took?
- Danny
2006///M3Vert/AO8/Nappa/SMG/19's/HK/NoYokes/MatteGills&Grills
Irishdb is offline   Reply With Quote
Old 01-15-2012, 05:57 PM   #10
Irishdb
My Ride: ///M3
Ok - I took the ///M out for a spanking! Did the SMG reset - I was skeptical hence why I am doing it only now.
Wow! What a difference. 1st to 2nd is much smoother. Going through the gears feels about the same. 1st to 2nd - significant difference!!
As the title says - do it!!
- Danny
Old 01-29-2015, 04:58 AM   #11
Mrjudd77
My Ride: 325ci
lets revive this one.
Is this the same procedure for the non \\\M?
Mrjudd77 is offline   Reply With Quote
Old 01-29-2015, 08:18 AM   #12
Guest021715
Account closed.
My M3 doesn't have paddles, is it totalled?
Old 01-29-2015, 08:26 AM   #13
killa_e46
My Ride: E46 M3
lol, ditto
killa_e46 is offline   Reply With Quote
Old 01-29-2015, 09:33 AM   #14
joeysm3
My Ride: ///M3 02
hahaha good one
joeysm3 is offline   Reply With Quote
Old 01-29-2015, 02:15 PM   #15
WOLFN8TR
My Ride: 05 M3
You guys need to get the SMG Tuning from Frank Smith at Tuning Techs. They charge $189 and its a completely different car! Highly recommended.
BAVSOUND Stage 1 - UltraGauge - Valentine One - Orion V4's - ARC-8's
TTFS Engine/SMG Tune/CSL 255 - SGT Headers/Sect 1/SCZA - Evolve Eventuri
VIS XTS CF Hood - CF Lip/Console/Diffuser - OE CSL Trunk - BWS 500S 9k/11k
WOLFN8TR is offline   Reply With Quote
Old 01-29-2015, 03:00 PM   #16
e46dinan
My Ride: E46 M3, E53 4.6is
How different? Thanks
e46dinan is offline   Reply With Quote
Old 01-29-2015, 04:18 PM   #17
WOLFN8TR
My Ride: 05 M3
The shifts are faster and firmer with rev matched down shifts.
Read this thread. There's several videos showing what these tunes do.
http://www.m3forum.net/m3forum/showthread.php?t=467544
Good SMG info.
Lets start with maintenance:
-What do you do to maintain your smg2? I assume most will answer nothing, even though they want to say otherwise
The truth is there is very little to maintain although the few things that do need attention most often does not get the attention it should.
1. Have you changed your SMG fluid? Why not?
-make a habit of turkey basting fluid in the smg reservoir. Fresh additives are needed to protect. Simple as that.
2. Have you replaced the compression springs? Were they broken or just worn out?
3. How often do you run an SMG adaptation with INPA or GT1? (this is NOT the paddle soft reset)
-this is needed to keep your transmission calibrated to function properly. I suggest doing it yearly if not every six months.
Read more: http://m3support.net/thread/232/e46-...#ixzz3ew5erYut
Old 01-29-2015, 05:20 PM   #18
SKR7
My Ride: E46 MY04.5 SMG M3
+1. What WOLFN8TR said. Massive difference. Best value for money mod you can do imho.
///M
2004 E46 M3
SKR7 is offline   Reply With Quote
