Where does this vacuum hose go? - E46Fanatics E46 BMW Social Directory E46 FAQ 3-Series Discussion Forums BMW Photo Gallery BMW 3-Series Technical Information E46 Fanatics - The Ultimate BMW Resource BMW Vendors General E46 Forum The Tire Rack's Tire Wheel Forum Forced Induction Forum The Off-Topic The E46 BMW Showroom For Sale, For Trade or Wanting to Buy
Old 04-07-2012, 10:38 PM   #1
mcopenha
My Ride: '01 325xi, '73 2002
Where does hose B go?
I removed the intake and despite researching this site and realoem can't seem to figure out where hose B in the picture goes.
I do know that hose C goes to the secondary air pump near near the exhaust manifold.
A is blocked off on my car (2001 325xi).
mcopenha is offline   Reply With Quote
Old 04-07-2012, 11:54 PM   #2
dslboomer
My Ride: 2001 BMW 330I
It connects to the black vacuum tank #9 under the intake manifold.
That hose is #8 in this diagram.
http://www.realoem.com/bmw/showparts...28&hg=18&fg=20
dslboomer is offline   Reply With Quote
Old 04-08-2012, 06:49 AM   #3
mcopenha
dslboomer, you are the MAN. thank you. I don't think I would ever have found this without this bit of info.
Sponsored Links
Advertisement
Old 09-03-2015, 10:51 AM   #4
BKL070
My Ride: 2001 330 xi
This has helped me also. My hose is disconnected and plugged at the tail pipe. When I needed to get at the crank position sensor the vac canister needed to be moved. At that time I noticed the hose from manifold to canister is going bad. I just went back to plug it but was having difficulty finding where the hose started.
Label "A" is a vacuum cap with a squared off top? This points to the back of the car when installed? If it is the same thing my cap was all cracked and no good (Hit the gas quick and it would want to stall. Tough in a man trans). I put another cap on. It was a little loose. Started the car, everything seemed fine. Went out next day to make sure it was secure; it was gone. I put a little sticky stuff on it. Hopefully it will hold. Just thought it odd that a vac port would blow the cap off and also has no barb on the stem.
BKL070 is offline   Reply With Quote
Old 09-03-2015, 11:46 AM   #5
Dave1027
My Ride: '06 IR zhp coupe
Should not be blowing the vacuum cap off. Could it be you have the wrong size cap on it? It should be a somewhat tight fit.
Old 09-03-2015, 01:02 PM   #6
SilberVogel
My Ride: 2002 330Ci Conv.
BKL070, I'd make sure you're using the correct size cap if yours is falling off.
Vacuum cap size/part number for letter "A" is 7.0mm and #11611727176.
Vacuum cap size/part number for letter "B" is 3.5mm and #11611437560.
See this thread for more info: https://forum.e46fanatics.com/showthread.php?t=1074573.
Also, if that vacuum port is capped off, there's no need to cap the hose at the tail pipe, or have that line/vacuum canister on the car at all. You may also want to consider epoxying the vacuum port on the intake manifold if you don't want to worry about vacuum caps in the future.
In regards to the original thread, here are some additional diagrams and their corresponding vacuum lines that might be a useful reference in the future, as well: http://www.bimmerfest.com/forums/sho...d.php?t=574814.
DIYs help you save money with repairs; let www.bmwpnpc.com help you save money with the parts.
SilberVogel is offline   Reply With Quote
Old 09-04-2015, 05:16 PM   #7
BKL070
The cap was loose. It was just what I had. Someone else plugged it at the tailpipe. Seeing how the old one was cracked up and super loose and it stayed. The one I used was a slight taper so that was probably part of it.
What kind of epoxy would you trust to stay as a permanent fix?
